Best Used SLR Cameras Under PLN 500: Top Models & Tips for Choosing the Right One for Beginners
fiona17 20547 20
Which used SLR camera costing no more than PLN 500 should a complete beginner choose, and what should they consider when buying one?
At up to PLN 500, the main recommendation is a Nikon D80 with an 18–55mm kit lens; a set with a 50mm f/1.8 lens can provide greater brightness and image quality but less flexibility. [#17516151] The D80 is now very old and may have high mileage, so compare its condition carefully with newer alternatives such as the Canon 40D. [#19886979] Search OLX, portalemy.pl, oglaszamy24.pl, Allegro, and local private listings, since worthwhile deals may appear outside Allegro. [#17607312] A beginner should be prepared to learn manual operation and practise, because an SLR is heavier and more demanding than a compact camera. [#17617731] If an SLR is not essential, the Samsung NX1100 with its 20–50mm lens was praised as a cheap, relatively current alternative, while the Fujifilm FinePix S6500fd is a bridge compact rather than an SLR. [#17617613][#17606261]
  • #1 17503153
    fiona17
    Rate: 8
    I'm new to the forum. I have been thinking about buying a used SLR for some time. I am completely green when it comes to topics related to photography, which is why I am asking you for help ;) Any examples of models up to PLN 500? And what to look for most when choosing.
    Thank you in advance for your answer.
    Regards
    panczo272
    I would recommend Sony slt-a37 slightly above 500 PLN but the camera is worth attention.
  • #3 17505486
    fiona17
    Rate: 8
    Thank you for the suggestion.
    But still something up to PLN 500?
    Any examples?
    panczo272
    If so, up to PLN 500 as the first learning apparatus and more I would recommend a mirrorless camera
  • #6 17515149
    fiona17
    Rate: 8
    Used SLR camera, there are a lot of them on the website. However, I don't want a compact camera anymore.
    marcode
    Help: 88
    Rate: 76
    Nikon D80 will probably be optimal, it beats the quality of other companies like sony, pentax or canon, in addition you will find the price of PLN 500 with an 18-55 lens, maybe you could buy a set with a 50mm 1.8f lens which gives less possibilities from the perspective side but the brightness and quality equals modern sets.
    shap
    If you were to search the web, I recommend the olx.pl, portalemy.pl, oglaszamy24.pl and all local portals. It's worth spending some time browsing because there are opportunities. Allegro is becoming expensive and at least less or in whole private ads.
  • #9 17612717
    fiona17
    Rate: 8
    What do you think about Sony Alpha 350 or Canon Eos 400D?
  • #10 17612766
    marcode
    Help: 88
    Rate: 76
    Much worse than Nikon D80.
  • #11 17617472
    fiona17
    Rate: 8
    And when it comes to some compact, which quality of photos would be similar to a SLR, what do you recommend?
    marcode
    Help: 88
    Rate: 76
    Take a look at the Samsung NX1100, you can buy a set with a 20-50mm lens at such a price, and the quality of the picture is a revelation, it's quite timely equipment, and cheap because Samsung withdrew from photography.
    I used this set myself as a travel camera and I was very pleased.
  • #13 17617731
    D214d3k
    Help: 543
    Rate: 633
    With zero knowledge SLR will do nothing. Regardless of the price, this is advanced equipment showing a claw in the hands of an informed user. It's worth it if you are determined to quickly absorb knowledge and exercise. Exercise is a situation when you do not have to take pictures but master some functions, techniques ...
    Looking from a different angle, when it comes to something more than a photo for a family album or a social networking site, it is worth going into a SLR camera. If only then the SLR will disturb the weight but also because it puts more requirements than the compact which takes everything by itself and if you move it will stabilize.
    Compact restrictions? You won't print a1 poster, but you probably won't print it. Anyway, a SLR camera with kit for 500 zlotys will not cope either. The second limitation of compactness is difficult lighting conditions. Small lights shine up to 2-3 meters.
    Quite a few drawbacks, right?
    There is something else sometimes called a bridge camera. It's such a cool compact. Fuji, who suggested above, is such a cool compact (not a SLR!). It differs from an ordinary compact camera in that the lens is not miniaturized and therefore may have better parameters. For a large lens, a larger matrix is often hand in hand. The size of the matrix is worth paying attention to even when compact. Simplifying the larger the more light it catches. Simplifying because without simplifying someone can stuff too many pixels on this larger matrix and then loiter from catching light. The 30x zoom, 30 million pixels sound nicely marketing. Only a small zoom makes the lens very dark. Many pixels require more computing power, a larger card, more current and at the same time spoils a very important parameter - useful sensitivity. And this is especially important in a machine that can afford to set a little too high ISO and then skim.
  • #14 17618348
    fiona17
    Rate: 8
    Samsung NX1100 seems to be quite a good solution. Any suggestions for cheaper compacts?
    marcode
    Help: 88
    Rate: 76
    Do not bother with compacts because you will take better pictures with your phone now.
  • Sony A-mount bodies can use cheap Minolta autofocus lenses
    #17 19862045
    LightOfWinter
    Help: 369
    Rate: 935
    marcode wrote:
    Do not bother with CDs because you can take better photos with phonem now.
    Unfortunately, in most cases this is not true.
    Although there are phones with decent cameras.
    And photos from phones in most cases are sufficient and always at hand.
    Examples of Sony SLR cameras:
    sony-alfa-a33
    sony-alfa-a390
    Nikons are very good, but for Sony you can buy old Minolta lenses cheaply and they will work with autofocus.
  • #18 19886474
    zarzew
    In the same budget for today's years, would anyone recommend anything? I am wondering about this Nikon D80. Should I look for something else? Photos like that, 90% people and half in the apartment (where it is rather dark) and the other half is a manor house and rather daylight.
  • #19 19886979
    Preskaler
    Level 40  
    Help: 492
    Rate: 1057
    Yes, look for! This is a very old camera and probably with a lot of mileage. Maybe the Canon 40D can be found.
  • Pentax K10D or K20D for still photos
    #20 19897519
    ken-wawa
    Rate: 141
    It should be for photos and filming? Only for photos? If the latter, then I definitely recommend the Pentax K10D or K20D. A prism, not a mirror array, so you can see everything luxuriously in the viewfinder. Housing sealing. Solid construction (you can almost hammer nails). Lots of modes. Everything is thought out to the last possibility. There are no artificial simplifications, we will not give it, because the user has to buy a more expensive camera. In addition, the Pentax system is not very popular, so it is cheap (although also less developmental, unfortunately because the company is releasing very little).
  • #21 21520203
    DiLOG
    >>17612717 Been using my Canon of a similar model with no issues whatsoever for the past decade, I know the Sony model you mentioned is good but I'd 100% reccomend the Canon.
    >>21520203 Edit: Just seen how long ago this was posted, thought it was recently you asked this, I'm sure you've probably decided now, haha.
The discussion focuses on recommendations for used SLR cameras under PLN 500 suitable for beginners. The Nikon D80 is frequently highlighted as an optimal choice within this budget, often available with an 18-55mm kit lens or a 50mm f/1.8 lens, offering superior image quality compared to Sony Alpha 350 or Canon EOS 400D. Pentax K10D and K20D are also suggested for their robust build, prism viewfinder, and extensive manual controls, though less popular and with limited system development. Mirrorless alternatives like the Fujifilm FinePix S6500fd and Samsung NX1100 are recommended for ease of use and good image quality, with the Samsung NX1100 praised for its 20-50mm lens kit and affordability due to Samsung's exit from the camera market. Compact cameras are generally discouraged as modern smartphones often provide comparable or better image quality for casual use. Advice includes searching local classified portals (olx.pl, portalemy.pl, oglaszamy24.pl) for better deals than Allegro. The discussion also emphasizes the learning curve of SLRs, noting they require user knowledge and practice to exploit their capabilities, especially in challenging lighting conditions.
TL;DR: Under PLN 500, built‑in flashes reach 2–3 meters, and "With zero knowledge SLR will do nothing." Start with a simple DSLR kit (e.g., Nikon D80 + 18‑55) or a bridge like Fuji S6500fd; check lens and flash limits. This FAQ helps Polish beginners choose and inspect a used pick. [Elektroda, D214d3k, post #17617731]
Why it matters: Tight budgets can still yield capable cameras if you target the right models and avoid worn‑out bodies.
What are the best used DSLR models under PLN 500 for beginners?
Look for a Nikon D80 with the 18–55 kit lens around PLN 500. It’s a straightforward way to learn exposure, focus, and composition. Many beginners add a 50 mm f/1.8 later for portraits and low light. Start with one lens and practice core techniques first. [Elektroda, marcode, post #17616151]
Is it worth stretching the budget to a Sony SLT‑A37?
Yes, if you can stretch a bit above PLN 500, the SLT‑A37 is worth attention. You get a modern shooting experience in a compact body. It’s a solid alternative when entry Nikon kits are scarce. Consider total cost, including a memory card and spare battery. [Elektroda, panczo272, post #17504494]
Which non‑DSLR option feels close to a DSLR at this price?
Consider a bridge camera like the Fujifilm FinePix S6500fd. Bridge models use larger lenses than pocket compacts and can offer better optics. They’re still simpler than DSLRs, with fixed lenses. Watch out for extreme zooms, which often mean darker lenses and higher noise. [Elektroda, D214d3k, post #17617731]
Are compacts still worth it compared to a modern phone?
Thread advice: skip cheap compacts. "Do not bother with compacts because you will take better pictures with your phone now." If you want a small camera, consider a bridge or mirrorless instead. Evaluate stabilization and low‑light performance before buying. [Elektroda, marcode, post #17618372]
Sony Alpha 350 vs Canon EOS 400D vs Nikon D80 — which should I pick?
The thread favored the Nikon D80 over Sony A350 or Canon 400D for image quality. If all three are within budget, prioritize a clean D80 kit. Check condition, shutter count, and lens glass before deciding. Add a fast prime later if you shoot indoors often. [Elektroda, marcode, post #17612766]
Where should I search for used camera deals in Poland?
Spend time on OLX.pl and local portals to spot bargains. Check portalemy.pl and oglaszamy24.pl as well. Allegro tends to be pricier and has fewer private listings. Meet locally when possible and inspect gear in person. [Elektroda, shap, post #17607312]
Will a DSLR help if I’m a total beginner?
A DSLR rewards learning and practice. "With zero knowledge SLR will do nothing." Plan exercises to master exposure, focus modes, and ISO. If you want more than social‑media snapshots, it’s worth the effort. Expect to practice even when you don’t need a picture. [Elektroda, D214d3k, post #17617731]
Is the Nikon D80 still worth buying now in this budget?
It’s very old and likely to have high mileage. Consider alternatives like the Canon 40D if you can find one. Age brings risks: worn shutters, weak batteries, and dated high‑ISO performance. Inspect carefully and prefer well‑documented copies. [Elektroda, Preskaler, post #19886979]
I only shoot photos (no video). What body is a strong choice?
Look at Pentax K10D or K20D. They offer a bright prism viewfinder, weather‑sealing, and robust build quality. Controls are well thought out for photographers. The system is cheaper but less expandable today. [Elektroda, ken-wawa, post #19897519]
Can Sony A‑mount DSLRs use old Minolta lenses with autofocus?
Yes. Older Minolta AF lenses mount and autofocus on many Sony A‑mount bodies. They’re often inexpensive on the used market. This keeps your starter kit affordable while expanding focal lengths. Verify lens condition and AF function when testing. [Elektroda, LightOfWinter, post #19862045]
Will a compact or bridge camera handle indoor events?
Indoor light challenges small sensors and weak flashes. Built‑in flashes reach about 2–3 meters, so subjects beyond that stay dark. Expect higher ISO noise and motion blur in dim rooms. A fast lens or external flash helps significantly. [Elektroda, D214d3k, post #17617731]
What first lens should I add for portraits and low light?
Add a 50 mm f/1.8. It limits perspective flexibility but gives strong image quality and brightness. That speed helps indoors and separates subjects nicely. Keep your 18–55 kit for general use. [Elektroda, marcode, post #17616151]
How do I check a used DSLR before buying?
Follow this quick test:
  1. Inspect body, lens glass, and mount; shoot a blank wall at f/16 to reveal dust.
  2. Test AF and exposure on a high‑contrast scene; check LCD, buttons, and card slot.
  3. Review sample images at 100%; confirm battery/charger work and ask about returns. [How to Buy a Used Camera]
Should I buy a compact like Nikon Coolpix A100 instead of a budget DSLR?
A compact such as the 20.1 Mpix Coolpix A100 is an option if you prioritize size and simplicity. The poster was skeptical about DSLRs under PLN 500 and suggested Nikon if you insist. Decide based on condition and your learning goals. Phones may still rival basic compacts. [Elektroda, Kuba367, post #17513476]
