inverter - How long will a car battery with 220v inverter last?
schranz21 57846 6
  • #1 16278201
    schranz21
    Hey. I would like to know how long a 12v 74ah battery will last. Taken out of the car, i.e. without charging. On a 12v-220v / 1000W converter connected to it, e.g. to which a laptop will be connected. Parameters on the laptop adapter are: Input: 100-240v 1.5A 50 / 60Hz Output: 19v 4.74A. And it draws 90W because I checked the power consumption meter. Thank you for your help
  • #2 16278230
    dedito
    Help: 527
    Rate: 595
    Measure the current on the battery side, then divide the 74Ah capacity by the measurement result in amperes, you will get the theoretical operating time of the set.
  • #3 16278265
    sanfran
    Help: 963
    Rate: 3004
    Little attention here. I have a similar system that has implemented protection against complete battery discharge and the inverter will shut down if the battery voltage is lower than a certain value. It is about leaving energy in the battery to start the engine without fear.
    So, the inverter may not use the full capacity of the battery, so in addition to theory, you still need to test it in practice.
  • #4 16278276
    Wlodek22
    Help: 78
    Rate: 526
    It depends on the condition of the battery and its current level of charge. Assuming 70% capacity and 70% charge, this inverter, with a load of about 10A can withstand about 2.5-3h.
  • #5 16278592
    schranz21
    I mean, I do not have a meter, I have something: https://elektrotanya.com/files/DSCN0074.JPG HERE INSTRUCTION: https://www.elektroda.pl/rtvforum/topic1108576.html and on the AMP function there is 0.400 and on the function WATT is between 50 and 90 depends what I do on a laptop. Maybe this will help you calculate how much such a set will pull.
  • #6 16278643
    sanfran
    Help: 963
    Rate: 3004
    It all depends on the efficiency of the inverter, the behavior of the battery under load, and the inverter shutdown voltage (if any).
    It's hard to count.
  • #7 16278667
    maurycy123
    Conditionally unlocked
    Help: 226
    Rate: 744
    schranz21 wrote:
    To which the laptop will be connected.
    If the inverter is to be used only to power the laptop, buy a suitable car adapter. In this case, it is shooting from a cannon to a mosquito. Unless you plan to use the inverter for other purposes.
The discussion revolves around estimating the operational duration of a 12V 74Ah car battery when connected to a 220V inverter, specifically for powering a laptop that consumes approximately 90W. Key factors influencing battery life include the inverter's efficiency, the battery's condition and charge level, and any built-in discharge protection features of the inverter. Users suggest measuring the current draw to calculate theoretical runtime, which could be around 2.5-3 hours under certain conditions. Additionally, it is recommended to consider using a dedicated car adapter for the laptop to avoid unnecessary use of the inverter.
