Mercedes ML 350 cdi Bluetec - Adblue, threatens to immobilize the engine for 500
looko 22380 8
  • #1 16278219
    looko
    Rate: 8
    I have a problem with ML 350 cdi from 2012, the error appeared on the meter? Check engine? and the message that little Adblue, I added to full, and after some time, showed that it will be impossible to start the engine after driving 500 km, and this display gradually decreases after 430km.
    After connecting cheap equipment, some autocom or something, it displays the error:? Too low adblue level? and yet it is poured into full. There is an option for some calibration, but it does not give anything, because the error immediately returns.
    After connecting the car to Star Diagnose, it displays the error:? The remaining available mileage is limited due to a fault in the adblue system.
    It is not going to be fired because it's coming back all the time.
    In addition, Diagnose Star in the parameters of NOX sensors, displays their measurement values, however, the state: "not ready?
    Has any of you met with a similar problem? Does anyone know a solution? Maybe some reasonable suggestions?
    PS I entered the service mode (conversion) and there the adblue level displays as its lack, and it is full of tank.
  • #2 16278280
    ALIBABA I
    Help: 223
    Rate: 537
    After connecting the car to Star Diagnose, it displays the error:? The remaining available mileage is limited due to a fault in the adblue system. After connecting cheap equipment, some autocom or something, it displays the error:? Too low adblue level? and yet it is poured into full. There is an option of some calibration, but it does not give anything because the error immediately comes back ... in here and here is the problem because both equipment is good show the same, hm, cables, adblue sensors.
  • #3 16278659
    looko
    Rate: 8
    I replaced the Nox sensor (the first one) and it's the same.
  • #4 16278799
    manta
    Help: 463
    Rate: 1533
    What for? After all, there was no performance message out of range.
  • #5 16278967
    szymitsu21
    Help: 343
    Rate: 1299
    And you can exchange it for a long time.
    Take care of your problem or Adblue.
  • #6 16279790
    looko
    Rate: 8
    I found such a sensor in the garage, i.e. nox, so I decided to change it to check it out. Or maybe some adblue level sensor in the tank was cut. What do you think?
  • #7 16279807
    kkknc
    Help: 1915
    Rate: 6698
    Indications you have clearly. Although you can also replace the left rear window or whatever you have in the garage. The effect is the same.
    I do not think about it at the moment. It's time to act.
  • #8 16279834
    looko
    Rate: 8
    What do I have clear? The Adblue system is a concept of relative ... it consists of elements that have been checked, except for the level sensor. So do not paste stupid text on the glass, because it's not important. I wrote a post to get help, not stupid comments. If you have not processed the topic in 350cdi, do not take the voices.
  • #9 16279844
    kkknc
    Help: 1915
    Rate: 6698
    looko wrote:
    .... and the message that little Adblue .... ..
    After connecting cheap equipment, some autocom or something, it displays the error:? Too low level of adblue?
    After connecting the car to Star Diagnose, it displays the error:? The remaining available mileage is limited due to vulnerabilities in the adblue system ?.
    PS I entered the service mode (conversion) and there the adblue level displays as missing.
    Yes, I'm just reading ...... I do not know ...
    Have fun playing fejsikiem, exchange for the trot you have there. If you get bored, fix it right. Starka with ViS leads well after repairs.
    It's time to get your hands dirty.
✨ The discussion revolves around a 2012 Mercedes ML 350 CDI Bluetec experiencing an Adblue system error, indicating low Adblue levels despite being filled. The user reports a warning that the engine will be immobilized after 500 km, with diagnostic tools confirming a fault in the Adblue system. Attempts to calibrate the system have failed, and the user has replaced the NOx sensor without resolving the issue. Suggestions include checking the Adblue level sensor in the tank, but responses also include dismissive comments about the user's approach to troubleshooting.
