Manta DVB-T Decoder: Green LED Flashing, Not Turning On, Unresponsive to Remote Control
wooojtek97 7071 7
  • #1 16281651
    wooojtek97
    Hello, I suddenly stopped working Manta decoder. I can't turn it on, only the green LED is flashing. Does not respond to any power disconnection or remote control buttons.
    Manta DVB-T Decoder: Green LED Flashing, Not Turning On, Unresponsive to Remote ControlIMG_201702...200851.jpg (3.36 MB)You must be logged in to download this attachment. Manta DVB-T Decoder: Green LED Flashing, Not Turning On, Unresponsive to Remote ControlIMG_201702...200836.jpg (3.04 MB)You must be logged in to download this attachment.
  • #2 16281782
    sosarek
    Help: 9320
    Rate: 15534
    Undress, check the voltage ... unless you count on Fairy's help.
    Z
    Pka, Poznań, 60-850
  • #3 16282522
    wooojtek97
    After dismantling, I noticed that the 10uF condenser has such a dark clot, is it possible that it just spilled? With electronics is just beginning also if any errors are sorry in advance. I count on help such as undress, check the voltage. Because expectations for fairies help unfortunately did not come true.
  • #4 16282575
    maksar
    Help: 177
    Rate: 1030
    wooojtek97 wrote:
    that there is such a dark clot at the 10uF capacitor
    With such knowledge, even a fairy will not help. :D
  • #5 16282662
    wooojtek97
    If unnecessary comments of this type are to be made, please moderate the whole post. I was counting on help :)
  • #6 16282694
    maksar
    Help: 177
    Rate: 1030
    In what? How you can't tell the difference between a glue and a damaged capacitor.
  • #7 16282955
    LeDy
    Help: 1992
    Rate: 2940
    And instead of writing a model, he made some pictures and what you can learn is described and called a clot? This is not medicine.
  • #8 16283064
    wooojtek97
    Maybe I will no longer offend you with my statements. And as I wrote in this post, "if any errors, I'm sorry in advance." It would look better if you wrote that it is glue, not a clot. I only inserted two pictures. Thank you for your help. We close the topic.
The Manta DVB-T decoder is experiencing issues where it fails to power on, indicated by a flashing green LED and unresponsiveness to both power disconnection and remote control commands. The user suspects a faulty capacitor, specifically a 10uF component that appears damaged. Responses from the forum include suggestions to check the voltage and identify the nature of the capacitor damage, with some users expressing frustration over the lack of clarity in the user's descriptions. The discussion highlights the importance of proper terminology in electronics and the need for clear communication when seeking technical assistance.
