Manta DVB-T Tuner: Remote Control Malfunction and Non-Online Purchase Options
16482 11
How can I determine whether a Manta DVB-T tuner remote has failed, and can I buy a working replacement or universal remote in a physical store without using an online shop?
First check whether the remote is actually emitting infrared: point a phone camera at the remote and press a button, because the camera can “see” IR and will show whether the remote sends anything; if it does, the tuner’s sensor may be damaged instead [#16929860] If you buy a replacement in a stationary shop, take the tuner with you so you can test it on the spot and verify whether the fault is in the remote or the decoder [#16929982] The recommended option is a dedicated replacement remote from Elmak; these are not universal remotes, may look different, but should have the full functionality of the original and work after inserting batteries [#16929860] [#16929982] A universal remote can also work if it has code search: some models let you search until the tuner turns on, which can take a while because many remotes support around a thousand codes [#16933034] If the tuner’s IR sensor is the problem, it can sometimes be replaced and the sensor itself costs only a few zlotys, but the repair may be not worthwhile if you cannot diagnose or repair it yourself [#16929982]
  • #1 16929848
  • #2 16929860
    PiotrPitucha
    Help: 201
    Rate: 424
    In Rzeszów you can buy Elmak, they make replacement remote controls.
    The question is whether the remote control got off or the sensor in the device?
    Set the camera in the cell on the remote control and press the button, the cameras in the cells "can see" infrared and you will see if the remote control emits something, if not, then look for the remote control, if so the sensor in the device may be damaged.
  • #3 16929875
    michalek1988
    Help: 68
    Rate: 181
    The remote control is flooded, broken? Have you tried cleaning it? Some keys do not work, or quite dead, maybe just the battery basket is corroded? If you are focused on buying a new one in a stationary store, take this decoder with you. First of all you will be able to check if all functions work, after 2 you will confirm or exclude the guilt of your remote control. Do not suggest the mere appearance of the remote control, Manta may change their appearance but the code RC5 or RC6 will match. PS in the remote controls often get damaged by the rubber bands, located under the buttons (such black discs), then you can also check if the most used function, e.g. volume change, does not work.
  • #4 16929896
  • #5 16929928
    michalek1988
    Help: 68
    Rate: 181
    It depends whether you can do diagnostics and repairs yourself, if not, the costs may be close to the value of the device. Start by checking the remote control as suggested by Colonel PiotrPitucha, if there is a problem in the decoder then you can ask someone to check it and then decide to repair or replace it. Original or replacement is in my opinion a secondary matter if this and that will work. I have a personal aversion to universal, if it is used by a low-tech person, I might accidentally reprogram it and you need to search the code again. On a dedicated one, you do not have this problem, because you will insert the batteries and it will work.
  • #6 16929982
    PiotrPitucha
    Help: 201
    Rate: 424
    I would like to emphasize that Elmak makes replacement remotes, they are not universal remotes so there is no risk of reprogramming, they may differ in casing but have the full functionality of the original.
    The sensor costs a few zlotys, there may be only a problem with the dimensions of the sensor to fit it in the housing, there is no electronic problem with replacement, but to not massacre the housing you need to gently disassemble the equipment.
    Did you check if the producer doesn't sell his pilots?
  • #7 16932371
  • #8 16932406
    michalek1988
    Help: 68
    Rate: 181
    Have you checked if Manta's remote control is definitely damaged? You can buy a remote control that can work with your decoder for PLN 10-15 on the auction site.
  • #9 16932420
  • #10 16932440
    michalek1988
    Help: 68
    Rate: 181
    This is already # 10 statement and in 2 you got information on how to check if it is a remote control, you want to waste time searching for code and programming it, the way is free but I would start with what I can do the easiest and fastest.
  • #11 16932797
  • #12 16933034
    PiotrPitucha
    Help: 201
    Rate: 424
    All universal remote controls that I had in my hand had the option of searching for a code, after entering this function press the ON / OFF button on the remote control until it turns on (the tuner turns on) and we remember the code found. It takes a while, because good remote controls support about a thousand codes, but in the end there is a chance to hit.
The discussion revolves around a malfunctioning remote control for the Manta DVB-T tuner. The user initially suspected battery issues but confirmed that replacing them did not resolve the problem. Suggestions include checking the remote control's functionality using a smartphone camera to detect infrared signals, cleaning the remote, and examining for physical damage or corrosion. Users recommend purchasing a replacement remote from Elmak, which specializes in non-universal remotes that maintain full functionality. There are also discussions about the possibility of using a universal remote, with advice on how to program it. The conversation highlights the importance of diagnosing whether the issue lies with the remote or the tuner itself before deciding on repairs or replacements.
TL;DR: If your Manta DVB‑T remote died, try code‑search on a universal remote—“good remote controls support about a thousand codes.” Use ON/OFF to auto‑scan until the tuner powers on, then save. [Elektroda, PiotrPitucha, post #16933034]
Why it matters: This FAQ helps you quickly decide whether to fix the remote, replace it, or repair the tuner sensor—without guesswork.
How do I tell if the remote or the tuner is at fault?
Use your phone’s camera to view the remote’s IR LED while pressing a key. Visible flashes mean the tuner sensor may be faulty. No flashes suggest the remote is dead. This quick test isolates the failing side in seconds. [Elektroda, PiotrPitucha, post #16929860]
What should I inspect on the remote before buying a new one?
Open the remote and check for corrosion in the battery holder, damaged rubber pads under keys, or stuck high‑use buttons like Volume. Clean contacts gently and re‑test. Mechanical wear here is a frequent failure point in older remotes. [Elektroda, michalek1988, post #16929875]
Can a universal remote work with a Manta DVB‑T tuner?
Yes. Many universal remotes include auto code search that can locate a working profile for the Manta. Start the search and use the ON/OFF key until the tuner powers on, then store the code. This covers about a thousand codes on better models. [Elektroda, PiotrPitucha, post #16933034]
How do I auto‑search the right code on a universal remote?
  1. Enter your remote’s code‑search mode per its manual.
  2. Aim at the tuner and repeatedly press ON/OFF until the tuner turns on.
  3. Save the found code using the remote’s store command. This scans large code libraries efficiently. [Elektroda, PiotrPitucha, post #16933034]
Where can I buy a non‑online replacement remote?
Look for dedicated replacements from brands like Elmak in local electronics shops. One example cited is availability in Rzeszów. Bring your tuner to verify full function in‑store before purchase. This avoids mismatches and returns. [Elektroda, PiotrPitucha, post #16929860]
Are Elmak remotes universal or 1:1 replacements?
They are dedicated replacements, not universal remotes. They may look different but keep the original remote’s full functionality. Install batteries and use them without programming. This reduces setup time and user error. [Elektroda, PiotrPitucha, post #16929982]
How much should I budget for a replacement remote?
Expect approx. PLN 10–15 for a compatible replacement sold online. In‑store prices vary by region and stock. Factor travel and testing convenience if you buy locally. This keeps total cost realistic for older tuners. [Elektroda, michalek1988, post #16932406]
Could the tuner’s IR sensor be the problem, and is repair worth it?
Yes. An IR receiver can fail while the remote still emits. The part costs only a few zł, but fitting the sensor into the existing housing needs careful disassembly. Labor may exceed device value if you cannot DIY. [Elektroda, PiotrPitucha, post #16929982]
What are RC5 and RC6 in this context?
RC5 and RC6 are common infrared command protocols used by many remotes. Manta may change remote casings while keeping these compatible codes. A replacement using the same protocol should operate your tuner correctly. [Elektroda, michalek1988, post #16929875]
Should I bring the tuner to the store when buying a remote?
Yes. Testing on the spot confirms all functions and proves whether the original remote or the tuner is at fault. This saves repeat trips. It is especially helpful if some keys previously failed. [Elektroda, michalek1988, post #16929875]
My remote lost some buttons but still worked. What does that suggest?
Missing caps can still allow internal pads to actuate, so the remote may function until deeper wear or contamination stops contact. If cleaning fails, replace the remote or test the tuner’s sensor next. [Elektroda, Anonymous, post #16929896]
Are universal remotes a bad idea for less technical users?
They can be. Some universals get accidentally reprogrammed, forcing you to reenter codes. Dedicated replacements avoid this by working immediately after installing batteries—no configuration required. “Insert the batteries and it will work.” [Elektroda, michalek1988, post #16929928]
Where do I find Medion universal remote codes for DVB‑T tuners?
Check the Medion manual that came with your remote. Models differ widely, and the codes live in their specific instructions. Without the manual, use the remote’s auto‑search function to find a working profile. [Elektroda, 1098678, post #16932797]
What’s a quick at‑home IR test I can do right now?
Point your phone camera at the remote’s LED and press any key. You should see a flicker on the screen. No flicker indicates a dead remote or power issue; flicker points to a tuner sensor problem. [Elektroda, PiotrPitucha, post #16929860]
Any edge cases I should know before replacing parts?
IR sensors vary in size and pin layout. An otherwise cheap swap can become difficult if the new sensor does not fit the tuner’s housing. Plan for careful disassembly to avoid cosmetic damage. [Elektroda, PiotrPitucha, post #16929982]
What’s the success rate of auto code search on universals?
Good models cover about 1,000 codes, so auto‑search often finds a match. The process may take a while, but it typically succeeds if the tuner uses a supported protocol like RC5/RC6. Save the code once it powers on. [Elektroda, PiotrPitucha, post #16933034]
