Manta LED3204 - does not start, s-by diode every 12 sec. blink
zebro 16125 15
Why does a Manta LED3204 with CV9203H-A42 not start, ignore the remote and keypad, and only blink the standby LED every 12 seconds even after SPI replacement?
The fault is likely not the SPI memory; the forum answer points instead to the U2 converter or the adjacent 12 V supply section [#16349351] U2 on this board was identified as a six-pin WB6DV / similar step-down regulator, and one reply suggested checking it as the supply source near the inverter/power section [#16351855][#16351135] A later check said the expected rails should be about 3.3 V at L1, 1.05 V at L2, and 5.21 V at L3, so these voltages should be verified on the board [#16352041] The USB/SPI firmware attempts reported in the thread did not solve the problem, which supports a hardware power-converter fault rather than a bad dump [#16332344][#16349351]
  • #1 16330576
    zebro
    Help: 51
    Rate: 139
    I have already changed him a few SPI batch downloaded from this forum and unchanged. The TV has a main board CV9203H-A42 and a matrix CX315DLEDM with the designation of the plate with flexes VVH32H147G00-3. The sticker with the given tv model also has the code LED3204vELE00AF06171.
    The TV does not respond to the remote control and local keyboard, only the s-by diode as I described in the title automatically every 12 seconds. blink. Voltage on SPI correct and other on stabilizers also approx. Slightly warm. The SPI Winbond 25Q32 memory that was removed could be read, but it could not be deleted at all, so I uploaded new batches to a completely new bone. And I don't know if the main board is dead or if the SPI batch must be dedicated to this TV. I am asking for suggestions.
  • #2 16331014
    stacho57
    Help: 168
    Rate: 444
    Maybe you need USB what's attached. And if not this file for SPI.
    • S2_506.code.bin (3.88 MB) You must be logged in to download this attachment.
  • #3 16331648
    lisek
    Service technician RTV
    Help: 6332
    Rate: 6843
    This one you uploaded
    link
  • #4 16332344
    zebro
    Help: 51
    Rate: 139
    Thanks gentlemen, both the file indicated by stacho57 and fox uploaded to SPI and made an attempt via USB - unfortunately no effect. I will try to return to the original memory, which did not want to be deleted, and give the above files via USB and we will see.
    Added after 1 [hours] 12 [minutes]:
    It didn't work, unless you need to look for a new main board ??
  • #5 16349351
    bydlak
    Help: 52
    Rate: 36
    This is not the fault of any memory slam.
    The u2 converter or more precisely the adjacent 12v voltage is to be blamed.
  • #6 16350527
    zebro
    Help: 51
    Rate: 139
    Maybe something will tell a friend more, what does this U2 converter mean ??
  • #7 16350929
    grubas
    Level 40  
    Help: 647
    Rate: 552
    U2 is a symbol described on the TV disc. This is how integrated circuits are marked.
  • #8 16351115
    stacho57
    Help: 168
    Rate: 444
    But you helped !!!!! A colleague of zebro wrote 789 posts and has been on the forum since 2005. You didn't notice it. Sorry. Try harder.
  • #9 16351135
    lisek
    Help: 6332
    Rate: 6843
    Which U2 system is it? / * yellow arrow
    - it's some kind of stabilizer in ob. SOT25-? (3-pin or 5-pin), what's the power supply?, Description on the housing?
    * connector for DVD option
    ps
    Single chip Chinese chassis, cpu + scaler all in one BGA
    Main CV9203H-A42
    CPU SPV9203
    Audio RT9108NB
    LED L3022M driver / * something like the HV9910, BIT3260, CVB42001?
    SPI 25Q32FVSIG
    * AC-DC PU1 SOT23-6 power supply, GNV + field code 7N65
    *? SG6859a
    AP3125A, V, L, R> code: GLS GLU GNB GNC
    AP3125B> code GLV
    AP3125HA, HB> code GNP GNQ
    AP31261> GPE code
    AP3127, H code GPH GSH
    matrix: CX315DLEDM
    * LED L3022M driver
    The CV9203L-A was used
    - + 5V line> SY8120B
  • #10 16351855
    emeryt2
    Help: 717
    Rate: 2300
    U2 on this board is WB6DV, six pins.
  • #11 16351939
    lisek
    Help: 6332
    Rate: 6843
    I do not have such a description smd, under this arrangement. (Probably Chinese designation)
    You have to draw the layout on a piece of paper and then according to link
    Because it's next to the invert connector. or power supply?
    - then LED UB302 driver, .... / * there are topics on the forum
  • #13 16899860
    almou
    Rate: 55
    Mr STACHO57 this update don't work on my OCEANIC. 32" board CV9203H-A42
  • #14 16978556
    AdamSiedlecki
    And on this plate someone may know also U2 is responsible for the same symptoms?
  • #16 19863896
    akuila
    NOW U HAVE A BIN ....
    • W25P32 CV9203H-A42 MANTA.bin (4 MB) You must be logged in to download this attachment.
✨ The Manta LED3204 TV is experiencing a failure to start, indicated by a standby diode blinking every 12 seconds. The main board is identified as CV9203H-A42, and the matrix is CX315DLEDM. The user has attempted to upload various SPI firmware files without success and is uncertain whether the issue lies with the main board or the SPI firmware compatibility. Suggestions from the forum include checking the U2 voltage converter, which may be responsible for the symptoms, and verifying the voltage levels at various points on the board. The U2 component is identified as a six-pin WB6DV stabilizer. Further troubleshooting involves returning to the original memory and testing the voltages at specific points to diagnose the problem.
