Audi A4 B6 2001 2.4 ABS Pump Issue: Red Exclamation Mark, ABS & ESP Lights On - Cold vs Hot Car
Pix 78 8505 2
  • #1 16285166
    Pix 78
    Rate: 8
    Hello. I have an audi a4 b6 2001 2,4, the red exclamation mark is lit on the display, then abs, esp. .I noticed that when the Audi stood in frost, after starting the car, the exclamation mark went out and the abs, esp worked. But when the car got hot, the problem returned. What may be the reason.
  • #2 16285177
    andrzej20001
    Help: 1578
    Rate: 6669
    Diagnostics, ask him for errors.
  • #3 16286414
    patryk44gks
    Help: 11
    Rate: 74
    It would be nice to do a scan with the interface.
    Probably some sensor at the wheel, damaged or dirty, or the crown on the wheel is damaged, it should be checked
