[Solved] Passat B6 2005 1.9 TDI BKC Handbrake Error - ABS & ESP Issues, Button Replacement
bercikus1 38532 5
  • #1 17356411
    bercikus1
    Rate: 21
    Hello, I was looking on the forum and I did not find an identical case, so I decided to write today while driving, a parking brake fault error appeared to me! see owner's manual and the indicator (p) crossed out, ABS and ESP appeared. When I turned off the engine and restarted the message, the message still appeared and the crossed P, while ABS and ESP went out when I exceeded 100 km / h, ABS and ESP lit up again. The manual gun locks both wheels, I replaced the button from the manual one and it's still the same. Has anyone had such a case before? What could it be?
  • #2 17356420
    sk700
    Help: 173
    Rate: 420
    Start by reading the error codes from the epb driver and writing down the abs pump coding sheet.
  • #3 17356455
    bercikus1
    Rate: 21
    Unfortunately, I am on vacation now and have limited access to it
  • #4 17356494
    sk700
    Help: 173
    Rate: 420
    In the EPB controller box under the central tunnel there is a sensor that ESP uses. Freaking in this sensor or loss of communication with epb can cause esp failing, resulting in its shutdown. You will learn nothing more without reading the errors from the car.
  • #5 17356521
    bercikus1
    Rate: 21
    Ok, I understand, I have one more question, which OBD2 cable is best to buy for this car, the program is VCDS lite
  • #6 17363658
    bercikus1
    Rate: 21
    The problem solved by the error turned out to be the plug to the ABS sensor in the left rear wheel
