How to Send High-Quality MMS Video from Samsung S6 to Smartphone - Android Guide
daroz078 47286 11
How can I send a short video from a Samsung Galaxy S6 as an MMS without reducing its quality?
You generally can’t send a video as a high-quality MMS without compression, because MMS messages are usually limited to about 300 KB and no app can reliably bypass that limit [#16294636] Some apps such as ChompSMS or Raiisak’s may increase the allowed MMS size, but the operator can still block an oversized MMS anyway [#16294620] [#16294643] On the Samsung Galaxy S6, the sender reported no option to change the MMS size limit [#16295623] The practical solution is to use an instant messenger such as WhatsApp, Viber, or Skype instead of MMS [#16294315] [#16295899]
  • #1 16292971
    daroz078
    Rate: 47
    I warmly welcome! Well, I would have such a small question, how is it possible to send a short video in the form of MMS from Android to a smartphone without losing quality? I have a Samsung s6, wanting to send a few seconds long video, a message appears that the file must be clipped and after sending the quality of the video is very uninteresting. I tried to do something with Video Coppress but nothing like that. Greetings.
    bubu1769
    Help: 1177
    Rate: 2374
    Check in the MMS settings if you can turn off the size limit.
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    What model of the phone gives this possibility?
    Use WhatsApp, Viber, or Skype instead of MMS
    #4 16294315
    AxelNext
    Help: 265
    Rate: 454
    daroz078 wrote:
    from android to smartphone without losing quality? I have a Samsung s6
    And what smartphone does the recipient have?
    The easiest way to install an application on both WhatsApp, Viber or Skype style smartphones and then you can upload a video even a few minutes.
    Personally, I sent up to 15 minutes, and I do not even know if there are any limits.
    Sending videos via MMS is not a good idea ;-)
    bubu1769
    Help: 1177
    Rate: 2374
    It's not a device issue but applications, standard have limitations on the size of sent files but a few times I met that it was possible to disable it, unfortunately I'm not able to say in what applications it was and whether it used packet data or Wi-Fi.
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    I ask out of curiosity because I have not met in order to increase the size of the file in mms.
    bubu1769
    Help: 1177
    Rate: 2374
    Apparently, the chompsms application should give an installment such a thing, but there is also the question of whether the operator has no upper limits on the message.
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    The maximum size of mms is usually 300kb and no application will help here. The videos are easiest to send through any instant messengers.
    AxelNext
    Help: 265
    Rate: 454
    The standard maximum size of MMS is 300 KB, once it was 100 KB
    There are programs like eg Raiisak`s that double the size of MMS https://forum.xda-developers.com/showpost.php?p=2284485&postcount=12
    but I know from experience that the operator will lock up such an MMS anyway so I have long abandoned the fun with MMS in favor of the WhatsApp application
  • #10 16295623
    daroz078
    Rate: 47
    Huge thanks to everyone for the answers. Well, as I mentioned before, I have a Samsung Galaxy s6 and no possibility to set the size of MMS. For now, I was sending myself short videos to see how it looks. So today is not possible, so you recommend WhatsApp. Greetings.
    AxelNext
    Help: 265
    Rate: 454
    I recommend WhatsApp because I use it every day. It is a very good communicator, not only with the help of which you can send videos, but also pictures, sound messages, you can call, for example, abroad for free on the Internet, etc.
  • #12 16298320
    daroz078
    Rate: 47
    Thank you and the topic, I think it's closed.
The discussion revolves around the challenges of sending high-quality MMS videos from a Samsung Galaxy S6 to other smartphones. Users highlight the limitations of MMS, particularly the standard size cap of 300 KB, which often necessitates video clipping and results in poor quality. Suggestions include checking MMS settings for size limits, using alternative messaging applications like WhatsApp, Viber, or Skype, which allow for larger file transfers without quality loss. Some users mention specific applications like ChompSMS that may help, but emphasize that carrier restrictions often negate these solutions. Ultimately, the consensus favors using instant messaging apps for sending videos over MMS due to inherent limitations.
