Activating Data Transmission for MMS on Samsung S5610 - GSM/UMTS/Auto Settings?
gklub 10209 3
  • #1 16423789
    gklub
    Help: 311
    Rate: 771
    Hello, my wife has a phone S5610
    Somewhere in a year, it does not support MMS. It became more necessary now so I tried to run. I searched the net and it turned out that you need to unblock the data transmission. The phone does not have the option of unlocking the transmission as such.
    BOK claims that there is no blockage on their part.
    Maybe it's about setting the GSM / UMTS / auto operating mode? The configuration file and manual set up and typing did not help :(
    WAP, MMS, internet - just a MMS and internet just used?
    Anyone have an idea - a method?
  • #2 16423995
    sosarek
    Help: 9320
    Rate: 15541
    Auto, in the phone settings enable data transmission (although incoming should be received automatically).
    Z
    Pka, Poznań, 60-850
  • #3 16424031
    nutergsm
    Help: 1034
    Rate: 1666
    In which network sim card? Do you have GPRS enabled?
  • Play MMS handling change suspected after data settings check
    #4 16425951
    gklub
    Help: 311
    Rate: 771
    @sosarek
    In android, I do this and ok, but in this phone in the menu there is no command "enable data transmission" or similar - there is only the choice of GSM / UMTS / auto - supposedly this is to allow the transmission
    @nutergsm
    Play subscription - a fairly old tariff from before 3 years - annoying that it once worked.
    Yesterday in one of the PLAY points was advised to submit an official complaint, because Play changed something in the handling of MMS. I am waiting for a response.
