Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone
staanislaws 4743 11
How can I recover a Galaxy S6 that only shows a cm.bin secure download fail blue screen and stays stuck in Download Mode?
Try Samsung Smart Switch emergency software recovery first: enter the model as SM-G920F, provide the phone’s S/N, then put the phone into Download Mode and let Smart Switch reinstall the software [#16601053] [#16601094] If that repair also fails and the same cm.bin / secure download error remains, the thread suggests it may be a memory or other hardware problem, so software recovery may not fix it [#16601566]
  • #1 16601016
    staanislaws
    Rate: 43
    Galaxy S6 crashes such messages when attempting to upload a software.
    cm.bin and FAIL
    This is probably some secure download (cm) Fail
    It is impossible to enter the phone settings hanging only on this blue screen with the words or you can only enter the dowload mode. I still don't know how to bring my S6 back to life.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 20170721_203724.jpg (694.28 KB) You must be logged in to download this attachment.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 20170721_203704.jpg (701.78 KB) You must be logged in to download this attachment.
  • #2 16601053
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Try it through Smart Switch as prompted.
  • #3 16601061
    staanislaws
    Rate: 43
    He throws such a message.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 2017-07-21 21.14.10.jpg (7.11 MB) You must be logged in to download this attachment.
  • #4 16601070
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    What does the message throw? Smart Switch or odin?
  • #5 16601072
    staanislaws
    Rate: 43
    Smart switch
  • #6 16601083
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    What information does the smart switch provide, correctly sees the model and version of the software?
  • #7 16601094
    staanislaws
    Rate: 43
    I do not recognize but I did so I gave emergency software recovery then I entered the SM-G920F model and called for S / N so I gave it and threw in that it would release new software and restart the factory settings. Then he ordered the phone to be in download mode and something was uploaded. Waiting for the final result.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 2017-07-21 21.28.43.jpg (7.38 MB) You must be logged in to download this attachment.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 20170721_212419.jpg (6.69 MB) You must be logged in to download this attachment.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 20170721_212411.jpg (7.95 MB) You must be logged in to download this attachment.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 20170721_212247.jpg (8.17 MB) You must be logged in to download this attachment.
  • #8 16601117
    staanislaws
    Rate: 43
    Unfortunately, the software repair was broken and such messages showed and I still do not know what to do.
    I'm at the same point again.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 20170721_213634.jpg (9.16 MB) You must be logged in to download this attachment.
    • Galaxy S6 Crashes: cm.bin Error, Secure Download Fail & Blue Screen - How to Revive Your Phone 20170721_213629.jpg (886.71 KB) You must be logged in to download this attachment.
  • #9 16601135
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    What happened that the phone broke? Multi-file soft if it doesn't help, something hw will be.
  • #10 16601142
    staanislaws
    Rate: 43
    You don't have multiplier bearing for this model
    Added after 6 [minutes]:
    The software started freaking out and when I tried to upload the software odinem crashed it and since then there is a blue screen with this message
  • #11 16601566
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Here you have: https://www.androidfilehost.com/?fid=24459283995297996
    There may be a memory problem and no software will help here.
  • #12 16601587
    staanislaws
    Rate: 43
    Nothing gave the disc it would be damaged
The discussion revolves around issues faced by users of the Galaxy S6, specifically related to crashes indicated by cm.bin errors, secure download failures, and persistent blue screens. Users suggest using Smart Switch for software recovery, but some encounter difficulties recognizing the device model or software version. One user attempted emergency software recovery by entering the SM-G920F model and providing the serial number, but faced further issues with software repair. There are indications that the problem may be hardware-related, as one user noted potential memory issues that software solutions could not resolve. Links to software files were shared, but some users reported that their attempts to fix the device were unsuccessful, leading to continued blue screen errors.
