- Setting Up a Workshop in Basement: Connecting Electrical Outlets in a PRL Apartment Block
16875 18
How can I legally supply power to a basement workshop in an apartment block?
Get permission from the cooperative/manager and your legal guardian first; then the proper solution is to run one cable through the shaft to the cellar, route it in a PVC pipe, and if needed have a sub-meter installed for the cell [#16301858] [#16301884] [#16301979] [#16301995] Do not use a “thief”/illegal tap or multiple extension cords from the apartment, because that is not a proper or safe installation [#16301995] [#16302013] If the guardians or administration do not agree, you should not do anything on your own with the electrical installation [#16301919] Cable should be marked on each floor, and the cellar section should be neatly protected in PVC so neighbors cannot object to a makeshift setup [#16301979]
  • #1 16301753
  • #2 16301858
    Gitner
    Help: 90
    Rate: 200
    Go to the cooperative, write a letter about the installation with a sub-meter to your cell. The second option is to pull the cable (not a few extension cords, only one cable) with a shaft to the barn and there you lead it in a PVC pipe to your cell.
  • #3 16301872
  • #4 16301878
    Gitner
    Help: 90
    Rate: 200
    Call my father and I will explain.
  • #5 16301879
    technikabasenowa
    Help: 138
    Rate: 444
    Ksawery Filipiak wrote:
    Gitner wrote:
    Go to the cooperative, write a letter to perform the installation under the counter to your cell. The second option is to pull the cable (not a few extension cords, only one cable) with a shaft to the barn and there you lead it in a PVC pipe to your cell.
    I don't intend to cooperate with the cooperative, do you think they will do it on the orders of a 14-year-old? I'm thinking about a thief threaded, but I have such neighbors that I'm afraid to screw out a light bulb for a thief so that no one will catch on the kennel, especially since they are quite often in my block.
    Reply you have increased :D
  • #6 16301883
  • #7 16301884
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4286
    From this you have legal guardians e.g. mother, grandmother etc.
    I am thinking about a threaded thief, but I have such neighbors that I am afraid to twist the bulb for the thief, so that no one will catch the kennel, especially since they are quite often in my block.
    I suggest you start using the right words. This is a technical forum.
    If you want electricity in the basement, you must have the consent of the manager and adapt to any connection conditions.
  • #8 16301893
  • #9 16301919
    Łukasz-O
    Help: 654
    Rate: 4286
    Since the guardians do not agree, unfortunately the topic is over, you do not have the right to do anything on your own, let alone bury in the electrical installation.
  • #10 16301920
    CYRUS2
    Help: 1230
    Rate: 3487
    You have to pay for the energy you use.
  • #11 16301933
  • #12 16301959
    Łukasz-O
    Help: 654
    Rate: 4286
    I mean to agree, maybe I can persuade
    Then go to the manager and ask what it is and if there is the possibility of supplying power to the cell.
    I do not intend to steal electricity, everyone pays for the light in the basement, so everything except the thief probably falls off.
    One contradicts each other.
  • #13 16301970
  • #14 16301979
    Gitner
    Help: 90
    Rate: 200
    You don't read what is being written to you. I have used shafts more than once, you can run the installation from yourself through the basement to your cell. The cable should be labeled on each floor. In the basement you lead in a PVC pipe to your cell. This can be done with the consent of the legal guardian and cooperative, then your neighbors can do nothing to you. If you are afraid of a cooperative then maybe it's worth being socially active there? Show that you can also give yourself, not only demand.
  • #15 16301991
  • #16 16301995
    Krzysztof Reszka
    Help: 609
    Rate: 1548
    However, you need to talk and they will ask the administration for such permission. Remember you are underage so all your mistakes go to their account.
    The second thing is these "thieves" as you call them, it's not a good idea. Because this lighting installation will burn out the switch sooner or later even though you write about 20 W. Because it is always at the beginning so that then you need to cut something, drill, etc. You write about the role of the workshop, so it's better to do it from the beginning well. The idea of the workshop is good and worth praising.
  • #17 16302008
    CYRUS2
    Help: 1230
    Rate: 3487
    Złodzejka is also stealing electricity.
    The electricity supplier for the luminaire wants to pay only for the energy consumed by the 25-60W light bulb.
  • #18 16302013
    Gitner
    Help: 90
    Rate: 200
    And I don't have the equipment to mount the pipe in the basement.
    And there are no people to make the cable in the pipe; /
    Well, you have the only right concept - a visit to the cooperative. Don't play thieves.
  • #19 16302381
✨ A young handyman is seeking advice on setting up a workshop in a basement of a PRL apartment block, measuring 1.5m x 2m with a height of 2.3m. He is considering options for connecting electrical outlets, including the possibility of using a porter’s socket or running extension cords from his apartment. Responses emphasize the necessity of obtaining permission from the housing cooperative for any electrical installations, as unauthorized connections could lead to legal issues. Suggestions include running a single cable through a shaft to the basement, using PVC piping for safety, and avoiding illegal connections. The discussion highlights the importance of following legal protocols and the potential costs associated with electricity usage.
