Under-cabinet hood - a well-known and good hood brand - which one?
JacekSiatkowski 23643 18
Which proven brands make good 60 cm under-cabinet kitchen hoods for a small apartment renovation?
Start by matching the hood type to your budget and installation method, because the best choice depends on whether it will be extended, recessed into the cabinet end, or mounted under the cabinet, and whether it will vent to a chimney [#16303431] Good brands mentioned for better quality are Elica, Faber, and Falmec [#16303431] If you want to stay near PLN 1000, one reply says it is hard to get top parameters and design, but suggests KERNAU KBH 07602 X as a cheap and fairly quiet option, plus LOFETTI 60.1 INOX EKO MAX as a decent price/quality compromise; more expensive examples were FRANKE FBI 537XS LED and Elica Hidden 52 [#16343084] Another user eventually chose Nortberg Amadis Inox and reported that it arrived quickly and works well so far [#16736917] In a block of flats, also check the building rules first, because some housing associations do not allow hoods connected to the ventilation chimney and require a carbon filter insert instead [#16738476]
  • #1 16303242
    JacekSiatkowski
    Hello, I am looking for advice on under-cabinet hoods. I am planning a renovation and looking for an under cabinet cabinet, mainly because I do not have much space in the kitchen - I live in a block of flats, and as you can guess, every space is at a premium. So I'm looking for some hood, preferably one up to 60 cm wide. Do you have any proven brands that don't make masks best, but rather specialize in hoods? I will be grateful for advice.
  • #2 16303431
    ar2d2
    Help: 6
    Rate: 17
    It all depends on your budget. The second thing is write if the hood is to be extended, recessed into the end of the cabinet or typically screwed under the cabinet ....
    Very good hoods are produced by, for example: Elica (I have island), Faber, Falmec.
    Write what amount you have, do you cook a lot, what type of hob and how many cm will the hood hang from (furniture do you already have?) And will it be connected to the chimney.
  • Seeking a budget 600 m³/h glass cabinet hood recommendation
    #3 16342872
    AgataNak
    I have the same problem or which cabinet hood to buy. I knew the internet there are Falmec, Elica hoods but these hoods cost over PLN 2,000 and they don't do crazy but the carpenter says they are fairly ok. Personally I would prefer something cheaper around PLN 1000 and that it would be best made of glass would be easier to maintain and the efficiency would be as minimal 600m3 / h. Someone may have something to recommend? Any Chinese or other trash.
  • Hood recommendations across three price ranges
    #4 16343084
    ar2d2
    Help: 6
    Rate: 17
    Unfortunately, but if the hood is to have very good parameters and design, for 1000 PLN it will be hard to find a compromise.
    From my own experience I can recommend if you do not want to overpay:
    KERNAU KBH 07602 X - about 450 inexpensive and quite quiet for the price - it is quite enough with normal cooking.
    LOFETTI 60.1 INOX EKO MAX - about 750 - decent price / quality ratio.
    Here's a more expensive proposal:
    FRANKE FBI 537XS LED - around 1700
    Elica Hidden 52 - around 1700
  • Considering telescopic hoods under PLN 1,000
    #5 16348991
    AgataNak
    Well, this Elica seems cool to me, but probably not my budget. After thinking about it, I decided that I didn't want to spend more than PLN 900-1000. I am now thinking about the option typically built-in, e.g. a telescopic hood. I am able to give up the look in favor of quality of action. After all, it will not take up much space for me, or at least it will work as it should. I am thinking about one of the cheaper ones you wrote to me and the NORTBERG Amadis Black hood.
    Comparing the parameters, I see that they are very similar. However, I am still thinking about this type of telescopic and I still have doubts, and I have to make a purchase soon, because renovation is already in progress
  • #6 16594485
    an.nowak
    I think I join the thread a little late, but I have a similar problem. Unfortunately, my hood must not only absorb unpleasant odors (because I only have a kitchenette), and also perfectly illuminate the entire zone. I care about the hood, which I can attach under the cabinet and not lead to the chimney.
  • Recommending NORTBERG hood and asking cleaning specs
    #7 16667685
    Grzegorz Walkiewicz
    A friend has a hood from Groenje fume or something and she is very happy with it. I myself am not very delighted with its visual side (but it is not the visual side that is to be liked, but the functionality). However, my wife and I invested in the NORTBERG hood, which we just liked for visual and practical reasons. I admit that we wanted to modernize our kitchen very much, which is why the hood has a touch screen display on a glass plate. And most importantly for me - the price was very good. That's why I recommend this company myself.
    However, I have a small problem with finding the right specifics to clean the hood. I will add that the hood is made of tempered glass.
    Added after 54 [seconds]:
    companies*
  • Nortberg hood recommended for price and touch display
    #8 16667728
    an.nowak
    And what model?
    we have invested in the NORTBERG hood, which we just liked for visual and practical reasons. I admit that we wanted to modernize our kitchen very much, which is why the hood has a touch screen display on a glass plate. And most importantly for me - the price was very good. That's why I recommend this company myself.
    Rather with a display, it will not be a cabinet cabinet.
  • #9 16667777
    Grzegorz Walkiewicz
    an.nowak wrote:
    And what model?
    DK63CLB http://www.gorenje.pl/produkty/duze-agd/okapy/modeli/dk63clb/492947 - I think it's this one, but I'm not sure. At least very similar.
    Well, it's not under cabinet. My hood is Ivo Black - chimney.
    https://nortberg.pl/o,177,ivo-black.html
  • #10 16667804
    an.nowak
    Detriment. Can anyone recommend a hood?
  • #11 16669174
    jennnifer
    Any dimensions?
  • #12 16669919
    an.nowak
    60-70 cm. I won't get any more :(
  • #13 16734774
    Grzegorz Walkiewicz
    And how? Did you find the right hood?
  • #14 16736917
    an.nowak
    I found. I thought for a long time, but I think I chose the best - Amadis Inox from Nortberg - https://nortberg.pl/o,265,amadis-inox.html. The hood came quite quickly and I can honestly say that I was afraid that it would not be nice or would not fulfill its function. So far (knock) everything works ok and I'm happy. Also, thank you very much for your help and advice. I think you can close the topic.
  • Ventilation-duct hoods can backdraft into neighbors
    #15 16738476
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    A colleague writes, I live in a block of flats. In some housing associations, it is forbidden to install kitchen hoods connected to a ventilation chimney. You can only mount kitchen hoods based on a carbon insert. If you mount the hood for ventilation when starting the fan and in bad weather conditions, you inflate the neighbor living above all content from your kitchen. Every half year, there is a draft check in the ventilation duct in the apartments by an external company which, after disclosing the mounted hood to the ventilation duct, issues an order to close the hood within a specified time and notifies the housing cooperative. If the block is 4 storeys, on the fourth floor, if you live, you turn a blind eye .
  • #16 18038421
    Moskika
    Rate: 14
    Let me raise the thread a little because I'm looking for an opinion on the Electrolux hood with the Hob2Hood option, anyone uses and knows how such an hood integrated with an induction hob works?
  • #17 18190071
    jacekRCA
    Help: 14
    Rate: 35
    I have something like this, great thing, one thing to watch is off, i.e. the hood, it turns on automatically when it detects cooking, adjusts the power of the hood and also sets the lighting. I like such novelties and in this case I think that it is not only cool but practical.
  • #18 18190126
    Ryszard49
    Help: 312
    Rate: 1011
    kierbedz4 , in blocks of large panels, ventilation ducts are separate for each apartment. This applies to the kitchen, bathroom and toilet.
  • #19 18194271
    Moskika
    Rate: 14
    I wonder what the power of such a hood is with an open kitchen. Is this so important that it is able to prevent the spread of odors? And since it works automatically, you can turn it on or off manually also without a problem?
The discussion revolves around selecting an under-cabinet hood suitable for small kitchen spaces, particularly in apartment settings. Users express concerns about budget constraints, with many seeking options under PLN 1000. Recommended brands include Elica, Faber, Falmec, KERNAU, LOFETTI, and Nortberg, with specific models like KERNAU KBH 07602 X, LOFETTI 60.1 INOX EKO MAX, and Nortberg Amadis being highlighted for their performance and price. Users also discuss the importance of functionality, such as odor absorption and lighting, and the need for hoods that do not require chimney installation due to building regulations. The Electrolux hood with Hob2Hood technology is mentioned for its automatic operation linked to induction hobs.
