Choosing 4-Zone Induction Hob, Large Capacity Built-In Oven & 60cm Dishwasher: Electrolux, BEKO
sampler 6240 8
  • #1 16602430
    sampler
    Help: 22
    Rate: 80
    I would like to help with advice on what to choose the equipment from the topic:
    1) 4-zone induction hob.
    I would like it to be free from defects related to touch control, i.e. when something spills, it would not regulate itself or if it turns off it should signal it. There is a 400V connection in the house. I watched Electrolux with 4 independent fields regulation. Do you recommend?
    2) Built-in electric oven. The largest possible capacity is known. Here I have no idea what to pay for. With the electrolux plate, I was shown a 72l oven with steam. Do you recommend?
    3) dishwasher size 60 cm. 2 baskets plus a cutlery drawer required. Relatively economical in terms of water consumption and not too loud.
    I was watching an electrolux with an eccentric water jet system. Some praise others claim that it washes poorly. Unfortunately, it is not the quietest and uses only 11l of water.
    What about BEKO equipment? What other brands can I consider?
  • #2 16602502
    szymon122
    Help: 302
    Rate: 761
    Take the most expensive ones, you can see that the budget is not a problem for you, since you did not provide it.
  • Questioning dishwasher spray design and hob power control
    #3 16603682
    sampler
    Help: 22
    Rate: 80
    I did not give the budget because it asks about technical aspects. I will also say right away that it targets the medium shelf, not the most expensive devices.
    I repeat the question about dishwashers with additional water spray. Eccentric like in Electrolux or as I saw today in BEKO DIN29330. In Beko, it is a movable head on only one half.
    Is it true that the electrolux hob is the only one on the market with smooth regulation of the thermal power of the field?
  • #4 16604382
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    Consider a ceramic hob instead of an induction hob. The fact of induction is faster, but they have one drawback. In standby mode, depending on the company, they consume from 60 to even 150 watts. I checked samsung yesterday and shock 165 watt. It's like turning on a 150 watt light bulb and never turning it off.
  • #5 16604800
    sampler
    Help: 22
    Rate: 80
    I do not know about electrolux but I quickly checked some model from Bosch and Gorenje and they take less than 0.5W in stand-by mode. But I see that I will have to pay attention to it when choosing a specific model :)
  • Induction hob standby draw seems overstated
    #6 16604810
    krzysztofh
    Help: 101
    Rate: 937
    Somehow it doesn't seem likely.
    If this is the case, then the board must be damaged, or maybe you measured the current consumption right after turning off where there is still a signal of hot halfs, but it is too much.
  • #7 16606901
    sampler
    Help: 22
    Rate: 80
    Pre-selected:
    1) Electrolux EHL 6740FOK induction hob. 2x230V power supply, shutdown signal, field connection.
    The question of controlling the power of the coils remains. Sellers praise that Electrolux is the only one that really controls the power of the field without working on the principle of operation-does not work.
    2) BEKO BIR35400XMS oven. Capacity 82l. Nice system of removable walls for cleaning. Warm air is also blown on the sides.
    3) BEKO DIN29330 dishwasher. Three drawers (2 for dishes + cutlery). Bottom spraying system with additional movable head (only on half). Loudness 42 dB. I wonder if the heater is integrated with the pump.
  • #9 16607379
    sampler
    Help: 22
    Rate: 80
    It's almost the same as I chose. There are probably not only side blowers and I do not know if the sides are removable for washing.
The discussion revolves around selecting a 4-zone induction hob, a large capacity built-in oven, and a 60cm dishwasher, focusing on brands Electrolux and BEKO. The user seeks an induction hob with reliable touch control, specifically the Electrolux EHL 6740FOK, which features a shutdown signal and independent field regulation. For the oven, the BEKO BIR35400XMS is recommended for its 82L capacity and easy cleaning features. The user also considers the BEKO DIN29330 dishwasher, which has a bottom spraying system and a noise level of 42 dB, but questions its washing efficiency. Alternatives from Bosch and Gorenje are mentioned, particularly regarding standby power consumption. The user is also interested in the Beko BIM36300XCS oven for its telescopic guides and XXL capacity.
