[Solved] Induction Hob: Electrolux EIS62441 vs Bosch PXE631FC1E - Which One to Choose for Reliability?
Piotr1. 33303 18
Which of these two induction hobs should I choose if my priority is reliability?
Choose the Electrolux if your priority is reliability, because several forum users preferred it over Bosch and described BSH/Bosch hobs as more expensive to repair and less durable. One reply says Electrolux/AEG/Husqvarna/IKEA are essentially the same inside, while Bosch/Siemens/Kupferbusch/Gaggenau belong to the BSH family and can cost more mainly for the brand name [#19052287][#19054629][#19066891] Another user specifically warned that BSH induction hobs can have failures in the first year, with expensive parts and repairs that are not proportionate to the product price [#19051580] A further comment noted Bosch/Siemens hobs have had issues such as burned inductor connectors, leading to costly repairs that can approach three-quarters of a new hob [#19052854] The main practical caveat mentioned was to check whether the hob uses full-power on/off control or smooth regulation, since this affects how pleasant it is to use [#19050667][#19052666]
  • #1 19050604
    Piotr1.
    Rate: 139
    I want to buy an induction hob and I am thinking about two models, namely:
    1. Electrolux EIS62441
    https://www.electrolux.pl/kitchen/cooking/hobs/induction-hob/eis62441/
    2.Bosch PXE631FC1E
    https://www.bosch-home.pl/lista-produktow/cooking-and-baking/hobs/induction-hobs/PXE631FC1E
    I deliberately do not give pages with the price because in this case it is indifferent to me. I would like to have a disc that will serve me without failure. Please help me choose.
    Warranty-era reliability concerns for both brands
    #2 19050667
    adamjur1
    Help: 772
    Rate: 1003
    Forget about safely. These are not Junker stoves from 20 years ago..
    Now the equipment is to work for a maximum of several years and after a new one to the store.
    I happened to repair both brands, usually just after the warranty ...
    Comparing the two, there is no information whether it works with the full power on and off method and the regulation is the operating time or the smooth regulation of the magnetic field power ...
    Regards J
  • #3 19051066
    Piotr1.
    Rate: 139
    After all, if a colleague had to choose one of these two, which one would he choose and why?
  • #4 19051348
    abuhamza
    Home appliances specialist
    Help: 383
    Rate: 1032
    Electrolux without a doubt.
    Regards
  • #5 19051529
    Piotr1.
    Rate: 139
    Why electrolux? Maybe just one sentence.
    abuhamza
    Help: 383
    Rate: 1032
    If you buy inductions on a good cheetah/tiger, you will avoid expensive operating costs, as in the case of BSH, where circuses occur in the first year of operation.
    BSH inductions are expensive to repair, not durable, the price of the parts is not adequate to the whole.
    adamjur1
    Help: 772
    Rate: 1003
    Buddy Specialist - can you (for educational purposes of the forum) expand on the meanings of these abbreviations cheetah / tiger, BSH and describe their operation a bit, plus-minuses?
    Regards J.
  • #8 19051899
    Piotr1.
    Rate: 139
    So I have one very strong vote for Electrolux
    Added after 1 [hours] 36 [minutes]:
    Buddy abuhamza, if you propose Electrolux from these two, maybe like AEG. The product is supposedly the same but the company is more prestigious and maybe the quality of workmanship would also be better. What do you think?
    Same internals across brands, with Cheetah modules most reliable
    #9 19052287
    abuhamza
    Help: 383
    Rate: 1032
    Whether you buy husqvarne, aeg, electrolux, ikea, you will get the same inside and a different brand inscription. Price difference.
    Cheetah/tiger the best power modules assembled in the elux concern.
    BSH - Siemens group Bosch kupperbusch gaggenau. So for Bosch Siemens you will pay that much and for a rump or gagen you will pay a little more and you will get the same thing inside.
    Throughout my term of office, I have never replaced transistors in chetaah power modules. Other brands are common and expensive faults. Here, if something falls on you and you have a head, you'll get it in cottage conditions..
  • #10 19052351
    Piotr1.
    Rate: 139
    Thank you for the hint. Then it will be Electrolux. Regards
    adamjur1
    Help: 772
    Rate: 1003
    Question - do they all work with full power keying or are they with smooth regulation?
    Regards J.
    piotrnowakowski1
    If I had to choose between the two, I'd go with the Electrolux
    Slider controls are less accurate than plus-minus selection
    #13 19052854
    cuuube
    Help: 36
    Rate: 267
    Using the sliders can be difficult, I have Electrolux for the second year and I swear that hey.
    I used to have a Mastercook with power pre-selection and +/- support, it was much more accurate, i.e. I still have it, for a rainy day.
    Bosch with the initial selection of the field and only the power setting will be a pain.
    I use a 90 cm slab, a fairy tale!
    Electrolux
    Mastercook
    Before buying the board after the Mastercook failure (I finally repaired it by buying the whole power module - used) I wrote with the service technician of such equipment, because I liked Sharp, he
    The fact that the brand is known, but from RTV equipment, less mobile phones, because it was mainly produced for the Asian market. Household appliances are only 4-5 years old.
    I will not speak about Sharp, because I was only in 4-5 devices. But the build quality is average. The fact that the purchase and then parts are not expensive.
    As for Amici, she used to do pretty good inductions. Now everything comes from China and the quality has dropped significantly.
    As for the Amica, Sharp service, it all depends on the specific service point and service technician. The fact that someone in some service point did not fix or something else does not mean that the given brand is bad. If you take Amica, you have to take into account that often the delivery time for parts is quite long (2-3 weeks). I see that most of the parts for the Sharp board are off-the-shelf (e.g. one power module: Link). To Amici: Link). So you can see that it is made to order and the price is much higher, but here I see that it is still on these good EGO modules (but they also fail. I have such a board myself, but with normal dimensions and one field does not work (always the front right one)). But for me it doesn't bother me at all. Who cooks more than 3. Usually 1-2 fields are occupied.
    AEG / Electrolux is on the Tiger series modules. e.g.: Link. 9 out of 20 such discs have a trivial defect. This 1 is the fault of the service module (usually those that have sensors in the lower right corner). But so far I've had 2 or 3 such glitches.
    Bosch / Siemens has recently had a slip-up with the inductor connector burning out. Mostly expensive repair (about 3/4 of a new slab). Or I disconnect one damaged one and the client continues to use 3 fields.
    Beko is the same manufacturer as Sharp and it is also different here. Some hob models cannot stand ordinary enamel pots.
    Candy/Hover used to be good, now comparable to Beko.
    Whirlpool in older models usually flew the left module. But the shipwrecks were relatively cheap, so it was reasonable to repair it.
    Samsung is one big failure. It breaks down to power, and the price of parts knocks down.
    Teka either has a construction like the above Amica or Whirlpool, only the price x1.5, for the fact that the inscription TEKA, and the module is the same. Once a client agreed to a repair - a new module for over PLN 2,000 and I came up with it, because something TEKA is screwing up....
    Indesit / Ariston - I will not say, because maybe I had 1-2 and it was a long time ago.
    Miele, Smeg - I didn't.
    Kernau - trash.
    Zelmer - The older one was based on the design of the old Candy, the newer one is a total China.
  • #14 19054498
    Piotr1.
    Rate: 139
    Regards, I close the topic.
    SQ8AGH
    No. Elektrolux and AEG are the same company as Bosch and Siemens.
  • Sense Boil omitted from AEG due to reliability concerns
    #16 19055183
    Piotr1.
    Rate: 139
    When it comes to Bosch and Siemens, I agree, while Electrolux and AEG are supposedly the same but apparently not. When I started digging into the subject, an Electrolux employee told me that it was the same as Tmoyota and Lexus. He's probably exaggerating a bit, but that's about it. Apparently, AEG products are made in Germany and Electrolux products are not necessarily. AEG products are sold for kitchen studios and not all of them can be found in stationary stores. That's all I found out. I was just wondering why Electrolux has an induction hob with such a function as Sense Boil (detection of water boiling and reduction of hob power so that it does not boil over), and AEG does not have it. This function does not work as it should and maybe that's why we won't find it in the AEG.
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    I assure you that this is one dog that only has a different external design. They are daughter companies and operate like BSH. To the family of AEG and Electrolux you can add Zanussi and Privileg, which also have only a different exterior and common guts.
    IKEA hob shares the same internals as AEG and Electrolux
    #18 19067545
    abuhamza
    Help: 383
    Rate: 1032
    Yes, I confirm. And the IKEA plate has the same center as AEG, Husqvarna or Elux. For the last three you will pay extra for this inscription on the glass and ikeła will be cheaper without the inscription ?
  • #19 19246187
    Piotr1.
    Rate: 139
    I chose an Electrolux induction hob. I'm closing the topic
The discussion centers around the reliability of two induction hob models: Electrolux EIS62441 and Bosch PXE631FC1E. Participants express a preference for Electrolux, citing its durability and lower repair costs compared to Bosch, which is associated with higher failure rates and expensive repairs. Users note that both brands share similar internal components, with Electrolux and AEG being part of the same parent company. Concerns about the functionality of induction hobs, such as power regulation and features like Sense Boil, are also raised. Ultimately, the consensus leans towards Electrolux for its perceived reliability and performance.
TL;DR: Choosing between Electrolux EIS62441 and Bosch PXE631FC1E? One tech reported “a slip‑up with the inductor connector burning out,” and saw 9 of 20 Tiger‑module hobs with trivial defects; the forum leans Electrolux for serviceability. [Elektroda, cuuube, post #19052854]
Why it matters: This FAQ helps homebuyers who want a reliable, repairable 60 cm induction hob and need clear guidance fast.
Which induction hob is more reliable: Electrolux EIS62441 or Bosch PXE631FC1E?
Veteran members advise Electrolux. “Electrolux without a doubt.” Pick EIS62441 if reliability and repair cost matter most to you. [Elektroda, abuhamza, post #19051348]
Do AEG and Electrolux hobs have the same guts?
Yes. “This is one dog that only has a different external design.” Internals are shared across AEG, Electrolux, Zanussi, and Privileg. [Elektroda, mrice, post #19066891]
Is Bosch the same as Siemens (BSH) inside?
Yes. BSH covers Bosch, Siemens, Küppersbusch, and Gaggenau. Hardware platforms are shared; the badge and price vary. [Elektroda, abuhamza, post #19052287]
What failure has been seen on Bosch/Siemens models, and what does it cost?
A tech noted “a slip‑up with the inductor connector burning out.” Repair often runs about three‑quarters of a new hob. Some technicians temporarily disconnect one inductor so three zones keep working. [Elektroda, cuuube, post #19052854]
How do Electrolux power modules compare for durability?
Electrolux/AEG use Cheetah/Tiger modules. A technician reports never replacing their transistors. Other brands see pricier semiconductor failures. [Elektroda, abuhamza, post #19052287]
What does Cheetah/Tiger mean on Electrolux hobs?
They are Electrolux‑group power‑module families. Techs rate them highly within the Elux concern. Expect fewer catastrophic power‑stage faults. [Elektroda, abuhamza, post #19052287]
Are slider controls on Electrolux easy to use?
One user finds sliders fiddly versus +/- keys and field preselection. They felt Bosch’s select‑zone‑then‑power approach could be a pain. Try the UI in person before buying. [Elektroda, cuuube, post #19052854]
If a Bosch/Siemens inductor burns, can I still cook? (How‑To)
Yes, as a temporary measure: 1. Have a technician disconnect the damaged inductor. 2. Use the remaining three fields. 3. Plan a repair or replacement promptly. [Elektroda, cuuube, post #19052854]
Does buying AEG over Electrolux improve build quality?
No. Contributors say internals are the same; differences are exterior design and sales channel. You pay mainly for the badge. [Elektroda, mrice, post #19066891]
Is IKEA‑branded induction a worse choice?
No. A technician confirms the same core as AEG, Husqvarna, and Electrolux appears in IKEA models. Expect lower prices without the premium badge. [Elektroda, abuhamza, post #19067545]
How long should I expect modern hobs to last?
A repair pro warns against expecting decades like old units. “Now the equipment is to work for a maximum of several years and after a new one to the store.” [Elektroda, adamjur1, post #19050667]
What did the original poster finally choose?
They chose an Electrolux induction hob and closed the topic. That mirrors the reliability advice shared by technicians. [Elektroda, Piotr1., post #19246187]
