ASUS X540SA: Seeking Windows 7-Compatible Drivers for Intel Celeron N3050, 4GB RAM Model
Bartek00.92 8325 14
How can I get Windows 7 64-bit drivers working on an ASUS R540SA/X540SA with an Intel Celeron N3050 when ASUS only offers Windows 10 drivers and basic devices like USB and the touchpad are missing?
You need to match each unknown device by its hardware ID, extract the driver EXE with 7-Zip, and install it from Device Manager by pointing Windows to the extracted folder [#16304364] For the listed IDs, use Realtek LAN for PCI\VEN_10EC&DEV_8136, Realtek Wi‑Fi for PCI\VEN_10EC&DEV_B723, and try the Synaptics or ELAN touchpad packages for PCI\VEN_8086&DEV_2292 [#16304342][#16304364] For ACPI\INTL9C60, use the Intel chipset package; for ACPI\ATK3001, use the ASUS ATK package; and for ACPI\MSFT0101, apply the update linked in the thread, with Intel Platform Trust Technology optionally disabled in BIOS [#16304364][#16304554][#16304621] The remaining ACPI\808622C1 entry has no Windows 7 driver according to the thread [#16304554] If the touchpad still does not work after trying the other packages, it likely will not work under Windows 7 on this model [#16305088][#16305135]
  • #1 16303879
    Bartek00.92
    Rate: 20
    Hello everyone with a new problem
    Patient: ASUS r540sa
    Processor: Intel Celeron N3050
    RAM: 4 GB
    Description: I am the owner of the new equipment described above. Due to the white fever I have to use Windows 8/10, I installed Windows 7 64. The problem is that unfortunately I can't find drivers anywhere, they are only for Win 10. The problem lies even in such basic drivers as USB or TouchPad (these devices do not work). I know that there are a lot of forum members who are smarter than me, which is why I am asking you.
    If you could match drivers from another ASUSA, or if anyone else has heard about the matching drivers for this model, I will be extremely grateful for even any piece of information / bearing on such.
    PS, if you need any more information about this equipment, I will be happy to answer.
    EDIT: I found USB and WLAN drivers under the link below that work (finally I can use the mouse)
    http://windows7forum.pl/problem-z-instalacja-windows-7-blad-0x0000007e-49774-t-2
  • #2 16304255
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Provide device identifiers for which drivers are missing (ven and dev or pid and vid).
  • #3 16304342
    Bartek00.92
    Rate: 20
    I have several devices with a yellow exclamation mark in the Device Manager, below their numbers:
    PCI \ VEN_10EC & DEV_8136 & CC_0200
    PCI \ VEN_8086 & DEV_2292 & CC_0C05
    PCI \ VEN_10EC & DEV_B723 & CC_0280
    and several devices called "Unknown device" but under the Equipment ID tab there is only:
    ACPI \ INTL9C60
    * INTL9C60
    In addition, there are many things like a graphics card for which I did not install the driver and the exclamation mark is not there. Despite this, you can even see the start bar at the bottom of the screen that something is wrong with the graphics because it is not as it should be "translucent".
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
  • #5 16304438
    Bartek00.92
    Rate: 20
    Graphics Card:
    PCI \ VEN_8086 & DEV_22B1 & CC_0300
    as soon as I download it and install it, I will write about the effects :)
    EDIT: Kolobos you are the Master, so far everything is installing without any problem. Will you say how you search for these drivers for children?
  • #7 16304497
    Bartek00.92
    Rate: 20
    It's still these three pieces and for now it would be everything.
    ACPI \ ATK3001
    * ATK3001
    ACPI \ MSFT0101
    * MSFT0101
    ACPI \ 808622C1
    * 808622C1
  • #9 16304616
    Bartek00.92
    Rate: 20
    An error occurred during installation for ACPI \ MSFT0101 ASUS X540SA: Seeking Windows 7-Compatible Drivers for Intel Celeron N3050, 4GB RAM Model
    I also noticed that the "Fn" function keys do not work. It's probably also the driver's fault but I don't know which one because we've already installed the keyboard.
    EDIT: however, "Fn" works, not just the touchpad.
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    For ACPI \ MSFT0101 check the updates given here:
    https://www.elektroda.pl/rtvforum/topic3134892.html
    Anyway, Intel(R) Platform Trust Technology can be turned off in the bios.
    Install everything I gave and just check what works and what doesn't.
  • #11 16304768
    Bartek00.92
    Rate: 20
    The update helped, that is, the ACPI \ 808622C1 remained, which, as you said, there are no Win7 drivers.
    I installed everything you gave me and checked what came to my mind.
    The touchpad is not working yet (did not work during the Windows installation)
  • #13 16305058
    Bartek00.92
    Rate: 20
    Kolobos wrote:
    Which drivers did you install for PCI \ VEN_8086 & DEV_2292?
    These from the first link (http://drivers.drp.su/Touchpad_Synaptics/Syna...ptics-NTx64-OEM_nb-Pegatron_19.0.9.20-drp.exe)
  • #14 16305088
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Check the other two. If the touchpad still won't work, it probably won't.
  • #15 16305135
    Bartek00.92
    Rate: 20
    Unfortunately it didn't help. I see that I have to bite my lips and accept W10 :(
    Anyway, thank you for your help, without you Kolobos I wouldn't even install half of these drivers.
The discussion revolves around the challenge of finding Windows 7-compatible drivers for the ASUS X540SA laptop, which features an Intel Celeron N3050 processor and 4GB of RAM. The user initially struggled with basic drivers, such as USB and TouchPad, after installing Windows 7. Forum members provided assistance by identifying device identifiers and suggesting specific driver downloads for various components, including LAN, Wi-Fi, TouchPad, and graphics. Despite successfully installing many drivers, the user faced ongoing issues with the TouchPad and some ACPI devices, ultimately considering reverting to Windows 10 due to compatibility problems.
