Asus F555L Laptop: Win 7 USB Driver Issues, Compatible Models & Solutions (F555LF, F555LB, F555LN)
lisek100 6279 2
  • #1 16746145
    lisek100
    Please help me find drivers for my laptop.
    The laptop model is ASUS: F555L slinger i3 processor
    On the asus website, if I want to download drivers, I give the F555L model, it finds other F555LF F555LB F555LN
    Will these other drivers also match?
    The laptop was based on a Win8 upgrade to Win10. I decided to format the disk, remove the recovery partition and upload win7. After installation, only the drive was working and I installed it with it lan LAN and then Driveboster. All of them rudders found drivers but USB 2.0 and 3.0 not working.
    bios The BIOS can see them and Win cannot. Please help.
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8290
    Welcome. Yours will also be LF, LB or LN, see the sticker on the bottom. What processor? If it is Intel's i3-4xxx / 5xxx and USB 3.0 then https://downloadcenter.intel.com/download/228...Xtensible-Host-Controller-Driver-for-Intel-8- 9-100-Series-and-Intel-C220-C610-Chipset-Family is the driver, if not installed, enter the identifier of this device.
    And don't use apps like Drivebooster. Some wonderful apps of this type can do more harm than good.
  • #3 16747638
    lisek100
    Thank you for what you sent, I fit. The markings are only F555L, so I don't know which one it is, but no matter what the ground that helped thank you. I close
