ASUS R540L: Seeking Driver Updates After Win7 x64 to Win10 Upgrade - USB Ports Issue
blackb 12102 17
How can I find and install the correct Windows 7 x64 drivers for an ASUS R540L after the upgrade, especially for the USB controller and other missing devices?
Install the missing devices manually from Device Manager using the extracted driver packages: the ACPI\MSFT0101 USB/ACPI device should use Microsoft’s xUSB driver, and the Intel 1603/INT3400 items need Intel DPTF/chipset drivers [#16414637] For the network controller, unpack the Wi‑Fi driver EXE with 7‑Zip and point Device Manager to the extracted folder when updating the driver [#16413929] The PCI device VEN_10EC&DEV_5286 is the Realtek card reader and can be installed the same way with its driver package [#16414637] ASUS also provides additional support packages for this laptop, but the final advice in the thread was that the touchpad will not work under Windows 7 on the ASUS R540L, so you may have to use a mouse [#16414816][#16414984]
  • Lists hardware IDs for missing Windows 10 drivers
    #1 16413268
    blackb
    Hello, after installing Win7 x64 with Win 10 I have a problem with the drivers, especially with the USB ports.
    Here is the complete list:
    System management bus controller:
    PCI \ VEN_8086 & DEV_9CA2 & SUBSYS_10D01043 & REV_03
    PCI Data Acquisition and Signal Processing Controller:
    PCI \ VEN_8086 & DEV_1603 & SUBSYS_10D01043 & REV_09
    PCI \ VEN_8086 & DEV_9CA4 & SUBSYS_10D01043 & REV_03
    PCI Simple Communication Controller:
    PCI \ VEN_8086 & DEV_9CBA & SUBSYS_10D01043 & REV_03
    Network controller:
    PCI \ VEN_168C & DEV_0036 & SUBSYS_213A1A3B & REV_01
    Universal Serial Bus Controller:
    PCI \ VEN_8086 & DEV_9CB1 & SUBSYS_201F1043 & REV_03
    3W Video Controller:
    PCI \ VEN_10DE & DEV_1299 & SUBSYS_105E1043 & REV_A1
    PCI device:
    PCI \ VEN_10EC & DEV_5286 & SUBSYS_528610EC & REV_01
    Unknown device:
    ACPI \ MSFT0101
    ACPI \ INT3400
  • #2 16413441
    LA72
    Help: 648
    Rate: 1657
    Link to Asus's website with drivers.
  • #3 16413470
    blackb
    Installing Chipset Crashes Error:
    This system does not meet the minimum requirements for installing this software.
    The installer will end.
    The same applies to Lan controls
    TouchPad installation crashes error:
    ASUS Smart Gesture does not support your device's touchpad function.
    The installation process is stopped.
  • #4 16413568
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Start by installing an update to your system from Windows Update.
  • #5 16413750
    blackb
    "Windows cannot search for new updates.
    You must be connected to the internet to search for updates. "
    How can I search if I do not have network drivers .......
  • #7 16414483
    blackb
    I am after the win 7 update, some drivers have been installed before, I have these:
    PCI device:
    Unknown device:
    ACPI \ MSFT0101
    ACPI \ INT3400
    Manual driver installation for Realtek, Intel, and ACPI devices
    #8 16414637
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
  • #9 16414698
    blackb
    Thanks, they all installed nicely, but there was a small problem;] the touchpad still does not work
  • Install Intel MEI, ATK Package, and Smart Gesture drivers
    #10 16414816
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
  • #11 16414858
    blackb
    Upon installation, MEI_Intel crashes:
    When installing ATK:
    Another version of this product is already installed .......
  • #12 16414895
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Can you see the touchpad in the device manager?
    On some laptops, especially the newer ones, the touchpad does not work under W7, this may be the case here.
  • #13 16414902
    blackb
    Under "Mouse and other pointing devices" there is only HID compatible mouse, there is no Touchpad and nothing is lit in yellow.
  • #14 16414930
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Do you have a USB mouse connected? If not, this HID is a touchpad.
    Does the laptop have any buttons to enable the touchpad?
  • #15 16414939
    blackb
    I have a mouse connected to the USB and the button to turn on the touchpad is not visible here :(
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Looks like you'll have to use a mouse.
  • #17 16414951
    blackb
    In the BIOS the "Internal Pointing Devices" option is turned on ehm
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    The touchpad will not work under W7, the forum is full of threads for this model.
    You gave a model with an error in the subject and it confused me! ASUS R540L is the correct designation.
After upgrading from Windows 7 x64 to Windows 10, the user encountered driver issues, particularly with USB ports and other components on the ASUS R540L laptop. The user provided a detailed list of problematic devices, including the System Management Bus Controller and various PCI devices. Initial suggestions included downloading drivers from the ASUS website and using Windows Update, but the user faced installation errors due to minimum requirements not being met and issues with network drivers. Further assistance involved downloading specific drivers for the network controller and other components from external links. Despite successfully installing some drivers, the touchpad remained non-functional, with no recognition in the device manager. The discussion highlighted that the touchpad may not work under Windows 7, and the user was advised to use an external mouse.
