Huawei B593s-22 Router: Firmware Update for HP Deskjet 1050 - J410a USB Printer Connectivity
prwerti 11289 16
How can I update a Huawei B593s-22 router firmware to enable USB printer support for an HP Deskjet 1050 J410a, and where can I find the correct firmware for my unit?
The thread does not provide a safe, guaranteed firmware link for enabling USB printer support on the B593s-22, and even a specially prepared file can still brick the router [#16311899] The only concrete advice given is to use the forum search and read the related firmware threads linked in the reply [#16310165] In other words, updating may work, but there is no risk-free package offered here and the danger of “freeing” the router remains [#16311899]
  • #1 16310074
    prwerti
    Hello. I would like to change the firmware in the router mentioned above to the one with which I will connect the HP Deskjet 1050 - J410a USB printer. Current firmware is: V200R001B180D20SP05C69, which does not have this function. I have seen many posts and I know that there is a risk of freeing the router, so could I ask for a link to the software that will be properly prepared for my router. Thank you in advance.
    Below is a photo showing the USB printer connection.
  • #3 16311899
    KOCUREK1970
    Help: 3834
    Rate: 5428
    But you realize that such a prepared file can do it anyway! Don't save you from "freeing" the router?
    Many things can go wrong.
  • #4 16315897
    klampek
    Rate: 12
    I thought I liberated the router by doing an original update through the router configuration page ..
    After 5 minutes it was UPDATE FAIL but it has restarted and everything works and I have the latest soft already with e.g. LTE band selection :P
    But there is nothing, for a while I had full pants: - /
  • #5 16466776
    student11
    Help: 14
    Rate: 28
    Siemandero!
    I have a router with a plus but I want to change something with it to choose the bandwidth etc for some of the latest best
    I currently have installed Huawei B593s-22 Router: Firmware Update for HP Deskjet 1050 - J410a USB Printer Connectivity
    trying to upload B710C0UPDATE_V200R001B236D30SP05C69 but after dropping it after pouring and updating from the file it seems that it is ok but it doesn't change soft ...
    what is wrong
  • #6 16466815
    KOCUREK1970
    Help: 3834
    Rate: 5428
    student11 wrote:
    what is wrong
    Maybe branded.
    You need to change the equipment ID.
    Don't ask me how - I'm not playing such things right now (I finished playing on E220 ;) ).
  • #8 16680797
    peres12
    Help: 19
    Rate: 19
    Hello everyone, I have a strange situation with my b593s-22, so I don't want to upload another software to it. I tried not branded soft several versions such as downgrade_vodafone_270_to_universal
    V200R001B270D10SP00C00
    V200R001B236D30SP00C00
    of course, I changed the xex editor and popped up UPDATE FAIL and nothing too I tried updating B710C0UPDATE_V200R001B236D30DM09C11 and the same UPDATE FAIL also tried multicast no error crashes.
    I have such a soft V200R001B270D25SP01C11 soft is from August 2015 ver.B SN: S2ZDW14417000442. Maybe someone here will tell me how to upload this crap soft. I fought over the weekend but I could not do it. I also wrote in the forum without cables and there I learned that there may be some watchdog blocking. How to do it, how to turn it off, someone will direct how to do it .
    Best regards Peres12
  • #9 16836788
    jumbo8
    Help: 9
    I have a similar problem, except in soft V200R001B270D25SP01C26. I also tried to upload probably all available versions of the software without effect. This "watchdog" is a rather different problem, because when you change the Cxx hexeditor we cannot calculate checksums. While some soft versions do not have a problem with this, the Scandinavian versions are protected. Similarly, there is no communication via SSH or telnet. For willing (Cyrillic) descriptions on 4PDA. In the Russians the topic was developmental, but there is no cash either.
  • #10 16894237
    Grzesiek_1969
    Welcome,
    There was such a problem with the s22 router as with the colleague coupe25. Power LTE in Plus began to lose wifi every several minutes. I uploaded the V200R001B236D30SP00C801 firmware and the transfer practically stopped. The range is only one dash, while it was 3 - 4. Before, I tried to go back to the previous firmware and the effect is: file verification failed. That is exactly as described.
    I am repeating this topic because it has been some time since this discussion, so maybe some solutions appeared?
    kisses,
  • #11 17013822
    Re.Mastered.M
    Rate: 24
    as for the "shortcomings" of WiFi - a colleague tried to replace the power supply with another one (maybe the current one can no longer bear the load)?
    For counting FW checksums, I recommend looking at: https://www.elektroda.pl/rtvforum/topic3292226 and download the attachment / guide -> there is how to calculate checksums using the free "HxD".
    For the sake of accuracy, I closed that topic because of a lack of interest, however, that I have made enormous progress in disassembling the FW code of the entire B593 series of routers, I will soon present my application giving practically unlimited configuration options for this device :D
    PS.
    At the moment I can:
    - Decrypt and modify configuration files
    - Decrypt and modify ALL passwords (CLI and TELNET also :D )
    - Modify the router's "default configuration" (e.g., replace the password from the device distributor's "sticker" with a different one, etc.)
    That's all soon.
    GREETINGS
  • #12 17016304
    dt1
    Admin of Computers group
    Help: 7289
    Rate: 8238
    Although the B593 is no longer the youngest equipment, this information will definitely be useful to many people. I hope that my colleague will be able to present his progress :)
  • #13 17080788
    Re.Mastered.M
    Rate: 24
    in thread: https://www.elektroda.pl/rtvforum/topic3438655.html I present part of the procedure regarding deciphering the configuration file and passwords contained in it.
    I recommend you take a look - this information is only available in this forum.
    Greetings.
  • #14 17134482
    czaczus22
    Rate: 25
    Hello, I have a broken router. Only the power LED and mode LED are permanently lit, the computer detects but only an unidentified network pops up. How to upload the software to this router. Multicastem I can upload the firmware, but the router does not get up. Does not give any effect.
  • #15 17135340
    Re.Mastered.M
    Rate: 24
    you looked here: link .
    Apparently there was a way of holding the WPS + WLAN + POWER buttons down, but I can't find it right now ...
  • #16 17139682
    czaczus22
    Rate: 25
    The router does not get up also with the key combination.
    You can flash it but it doesn't work. Reset doesn't work.
  • #17 17145531
    Re.Mastered.M
    Rate: 24
    check if the router has open ports: "21", "22", "23"
✨ The discussion revolves around updating the firmware of the Huawei B593s-22 router to enable USB connectivity for the HP Deskjet 1050 - J410a printer. Users express concerns about the risks of "freezing" the router during the update process, with some sharing experiences of failed updates and the challenges of using non-branded firmware. Suggestions include searching for specific firmware versions and modifying equipment IDs to bypass restrictions. Several users report issues with firmware verification and the presence of a "watchdog" that complicates the update process. There are also mentions of tools for calculating firmware checksums and decrypting configuration files. Overall, the conversation highlights the complexities and potential pitfalls of router firmware updates.
