Huawei B593-S22 Firmware Update: Slow LTE Internet & Printer Connection, Digital Polsat
bossqbanysa 7731 6
  • #1 16245815
    bossqbanysa
    Hello, I want to update the firmware in huawei b593-s22 - firmware from digital polsat because the LTE internet works extremely slowly and I can not connect the printer. I downloaded various software also dedicated to CP routers and every time I get the wrong file format information, what could be the reason ??
  • #2 16246142
    matek451
    Help: 4352
    Rate: 5808
    And what will change FW in terms of speed? What are your parameters now, what LTE signal parameters do you use LTE800Sferii or LTE1800Aero2, how far to BTS? Do you have an outdoor antenna, what street in Nysa? What version of FW on B593s-22?
  • #3 16247444
    KOCUREK1970
    Help: 3858
    Rate: 5486
    bossqbanysa wrote:
    wants to update the firmware on huawei b593-s22 - firmware from digital polsat
    You need to talk to CP.
    How different soft is to match each of their equipment - how does the engine equipment from the truck fit the Fiat 126p engine?
    That's it when it comes to making the user aware.
    The rest probably as colleague writes @ matek451 - oh this great internet in CP / Plus ...
  • #4 16248658
    bossqbanysa
    I live outside Nysa, I have an external antenna, LTE range up to 3 lines. The current software does not work with the printer and often breaks the connection to the internet. How can I upload new software and what ??
    Product information
    Model:
    B593s-22
    Serial number:
    S2Z8W14C26001519
    Hardware Version:
    Ver.B
    Firmware Version:
    V200R001B180D20SP05C69
    Firmware Build Date:
    Aug 1 2013 / 19:14:59
  • #5 16248726
    matek451
    Help: 4352
    Rate: 5808
    So what, did I ask about it? You have current FW. Bars don't interest anyone, B593 has advanced LTE / 3G signal diagnostics. What antenna is it? Breaking the connection has nothing to do with FW. On FW from Plus, the printer does not work on B593s-22.
  • #6 16249864
    Rognor
    Help: 78
    Rate: 120
    Look for my posts, e.g. https://www.elektroda.pl/rtvforum/topic3044698.html
    There you will find links to all relevant topics, read with understanding, everything, zero upload (and especially Austrian firmware).
    The basics are:
    1. You need to upload with the tip SP05C69 (the latest is B270).
    2. Change makes sense mainly if it breaks wifi fault.
  • #7 16918486
    mar1181
    Hello, could anyone help in pointing out software that would help solve the problem of wi-fi breaking in my router
    I will add that it is from the network plus. Of course, Huawei can not help but buy new equipment or return to the site for a fee.
The discussion revolves around issues with the Huawei B593s-22 router, specifically regarding slow LTE internet speeds and difficulties connecting a printer. The user seeks to update the firmware from Digital Polsat to resolve these problems. Responses highlight the importance of using the correct firmware version, with suggestions to consult CP (the service provider) for compatibility issues. The user reports having an external antenna and decent LTE signal strength but continues to experience connectivity issues. Recommendations include checking firmware versions and considering the impact of the router's configuration on performance.
