Opel Meriva 1.4 Z14XEP - Fan Not Starting, Engine Overheating, Gasket & Thermostat Replaced
schalker 18393 16
At what coolant temperature should the fan start on an Opel Meriva 1.4 Z14XEP, and is 102°C normal?
Yes — on this Meriva, fan activation around 102°C is considered normal, and the engine computer controls the fans from the coolant temperature sensor in the head, not from a separate radiator fan sensor [#16319588][#16319654][#16319693][#16319780] Some replies note that GM systems vary, with thermostats opening around 92°C on some cars and fan switch-on temperatures around 102°C on others [#16319588] One participant adds that a radiator sensor may exist on some radiator versions, but it is not the usual setup for Meriva and can be just a plugged hole on certain radiators [#16319967][#16320258] If you want to verify operation, let the engine idle and watch the actual coolant temperature; if the fans still do not come on by roughly 90–102°C, check the sensor, wiring, and coolant circulation/water pump before driving it further [#16319222][#21584798]
  • Questioning radiator fan activation temperatures around 98–102°C
    #1 16319073
    schalker
    Hello!
    I have a problem with the recently purchased Meriva 1.4 Z14XEP, 2008.
    Once, after driving 2 km, the refrigerant liquid broke out, the engine overheated.
    The head gasket and thermostat have been replaced. The mechanic noted that the fan does not turn on.
    The fan is OK, control from the computer level = 1st and 2nd gear are working.
    On the net I found information that the fan should turn on at 98 or 102 degrees (depending on what sensor was inserted in the radiator)
    Can anyone confirm this?
    I don't want to heat the engine unnecessarily and expose myself to another overheating ...
    Something does not suit me here, on the temperature gauge 102 degrees is already a step from the red field ...
  • #2 16319222
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    I do not think that after driving 2 km, the engine overheated, as for the sensor, it may be damaged. Starting from the computer will check the correct operation of the fans. Make a jumper on the radiator sensor and see if the fans start. Then you have the answer.
  • #3 16319566
    schalker
    The engine has overheated because the thermostat has failed - and so unfortunately that in the closed position ...
    the radiator sensor I just checked - it turns on the fan at 102 degrees - and this is what slightly bothers me ... isn't it too much?
    Regards
  • #4 16319588
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    All cooling is controlled by the engine computer, drive a bit and see if it indicates the correct temperature.
    Yes these are the right temperatures, glad you have a thermostat at 92'C there are such cars which opens at 102'C.
  • Confirming the cooling fan activation temperature at 102°C
    #5 16319592
    schalker
    I know, I know - in Zafira 1.8, the thermostat is fully open at 105 degrees, the fan turns on at 108 degrees, and in addition GM saved a few zlotys without giving the fluid temperature indicator ... massacre.
    I just checked that the fans are ok, the sensor starts the fans at 102 degrees. But from what I was talking with my friend there are distortions between the indicator on the board and the reading from the computer.
    I just wanted to confirm that these 102 degrees are the right temperature ...
  • #6 16319595
    Help: 1405
    Rate: 6430
    But you don't have any fan sensor there.
  • #7 16319608
    schalker
    I meant the coolant temperature sensor at the radiator.
  • #8 16319621
    Help: 1405
    Rate: 6430
    And where do you see him there, because I've never met in Meriva.
    And if you have it and connected in addition, you have a nice wire made.
  • #9 16319648
    schalker
    the water temperature sensor must be - maybe I was wrong and it's in the engine block, not in the radiator. The sensor was checked by my friend and maybe I assumed that it is next to the radiator ...
  • #10 16319654
    Help: 1405
    Rate: 6430
    It is the engine computer that decides everything in this car for the second time.
    I wonder how?
  • #11 16319657
    schalker
    Ok, I know that the computer decides, turns on the fans, etc., and how does the computer know what the coolant temperature is?
  • #12 16319693
    Help: 1405
    Rate: 6430
    Has a sensor in the head.
  • #13 16319780
    frankrom
    Level 19  
    Help: 23
    Rate: 151
    I have also never seen Meriva with a sensor in the radiator.
  • #14 16319967
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    See colleagues at all .... auction number 6734202664. cyt CORE DIMENSION; 608 x 350 x 24
    PART NUMBER ; 1300413
    ENGINE VERSIONS 1.6
    CHEST ; MANUAL
    RADIATOR WITH SENSOR HOLE
    I absolutely do not question your opinion, but there is a version with a sensor.
  • #15 16320258
    frankrom
    Level 19  
    Help: 23
    Rate: 151
    ENGINE VERSIONS 1.6
    CHEST ; MANUAL
    That's right, but this hole is originally plugged with a large Allen cap. This specific cooler is new, so it is
    "Bare".
  • #16 21184491
    kubuswujo
    Rate: 71
    has the subject been resolved?
  • #17 21584798
    iuliancristian
    Is the water pump working properly? Does it have flow? Are its vanes made of plastic or metal? Before driving it, test it in the garage, let it idle until it reaches 90 degrees. If the fans don't turn on, take action. But don't drive it and then boil the engine.
The discussion concerns an Opel Meriva 1.4 Z14XEP (2008) experiencing engine overheating after 2 km of driving, with coolant leakage. The head gasket and thermostat were replaced, but the radiator fan does not activate despite being functional and computer-controlled. The fan is reported to engage at approximately 102°C, which raises concerns about whether this temperature is too high, as the dashboard temperature gauge shows 102°C near the red zone. It is clarified that the engine control unit (ECU) manages fan operation based on coolant temperature data from a sensor located in the engine head, not the radiator. Some debate exists about the presence of a radiator sensor hole, but it is typically sealed. The thermostat in this model opens around 92°C, and fan activation temperatures vary by vehicle, with some opening at higher temperatures (e.g., 105-108°C in a Zafira 1.8). Additional advice includes verifying water pump operation and ensuring proper coolant flow to prevent overheating. Testing fan activation by jumpering the sensor is suggested to confirm fan function.
