Audi A6 C7 Not Starting: Ignition Issues, Key Recognition & Dashboard Connection
kita18 18402 3
  • #1 16328162
    kita18
    Rate: 30
    Hello . I have a problem with my Audi, so after pressing the Start button, the car does not respond (ignition does not turn on). After pressing the button several times and opening it from the remote control at the same time, it is displayed that the system does not recognize the key and I have to put it with my back to the place indicated by the appropriate picture (this does not give no result). I would add that the car was damaged and about a month ago after connecting the battery the ignition was on all the time even when the key was not around. Today, when I installed the dashboard and connected the battery as usual, the emergency blinking started and the ignition was on, I pressed the clutch and squeezed the Start button (and the linden display closed and the ignition turned off and on it does not go. Errors do not go to read because there is no ignition .
    I will add that it does not go to close either with the remote control or with the key, the opening works because you can hear how it opens. If you hold the door opening, the windows open and vice versa, if you hold the door closing, the windows close.
    When you press the start button on the remote control, the LED blinks twice.
    Anyone have any ideas?
  • #4 16329760
    kita18
    Rate: 30
    Tomasz Sadowski you were right the problem lay in all this Steering lock bolt. I just didn't have my ankle fixed ... After plugging in, the ignition is on and the car is lit. Thank you very much for help . Subject to close
