Mercedes A Class w168 1.7cdi - replacement of the head gasket
maverick747 8148 4
  • #1 16339139
    maverick747
    Rate: 11
    Hello, I would like to ask if anyone of you may have the instructions for replacing the head gasket in a Mercedes A class w168 1.7cdi.
    Thank you and best regards
  • #2 16339627
    pioart
    Help: 343
    Rate: 1473
    What instruction is it about? In principle, you can watch it without removing the engine.
  • #3 16339821
    kortyleski
    Help: 957
    Rate: 3860
    I did without taking it out. It is possible but it is easier to remove the motorbike, the rest as in every car
  • #4 16341832
    drdrug
    Help: 25
    Rate: 178
    You're pulling the engine. you set the OT mark on the pulley to the marker to the timing cover, pull off the valve cover, in the gears gathered from the camshafts there are holes for the locks, when you have the OT on the pulley set holes in which you insert the pins into the locking screws, they will be directed to the right :-)
  • #5 16613958
    maverick747
    Rate: 11
    Hello, I managed without pulling the engine, without problems except removing the injectors over which the mechanic spent almost a week, but managed to calmly and gently came out all but the pullers had to make some extra money. the rest as standard. thanks greetings
