Raspberry Pi 2 and PuTTy - can't connect, error: Connection refused
Towr 6954 6
  • #1 16340408
    Towr
    Rate: 46
    I wanted to connect my printer to Raspberry Pi 2 using a CUPS server. There are a lot of tutorials on the internet, how you can do it, I chose the configuration through the PuTTy program and here the error crashes right from the start and I can't go any further.
    I uploaded the "RASPBIAN JESSIE LITE" SD card, connected the Raspberry to my router, the router displays the IP of my Raspberry, I entered this IP in PuTTy and immediately crashes like "Network error: Connection refused" and after playing.
    My router is: Netgear DG834G
    What am I doing wrong? Connecting the monitor to HDMI, the system loads properly and you can log in using the login "pi" and password "raspberry", but for nothing I can get from an external computer to the raspberry.
  • #3 16340440
    Towr
    Rate: 46
    I'm a little green in it because I've been Raspberry for half a year, but I've never had time to play with it. Everything I wrote above I do in the same network. I don't know how to check these packages etc. I would like to ask for some more info.
    Added after 45 [minutes]:
    After entering the IP from Raspberry in CMD:
    grko
    Help: 247
    Rate: 141
    @Towr You must enable SSH connections on your Raspberry Pi. There is a nice tool on the raspberry for this:
    Code: Bash
  • #5 16340627
    Towr
    Rate: 46
    grko thank you very much :) Now it is working :)
  • #7 16340806
    Towr
    Rate: 46
    I know that for some things can be so simple and obvious that the question about them in the forums is a slight exaggeration. Uncle google, of course, I was looking for before I started this topic, but as it usually happens with me - if I'm looking for something, I can never find it, and if I don't need it, it is found ;)
    Thank you again for your help and any links.
    I close the topic.
The discussion revolves around a user experiencing a "Connection refused" error while trying to connect to a Raspberry Pi 2 using PuTTy for printer configuration via a CUPS server. The user confirmed that both the Raspberry Pi and the external computer are on the same network and that the Raspberry Pi is properly set up with Raspbian Jessie Lite. A key solution provided was to enable SSH connections on the Raspberry Pi using the command `sudo raspi-config`, which resolved the connectivity issue. Additional resources for SSH and VNC setup were also suggested for further assistance.
