Experiencing Power Loss and Check Injection Message on Renault Scenic II 2007
ottoadam 50271 11
Why did my Renault Scenic II show a "check injection" warning and briefly lose power, then seem normal again after restarting?
That warning means there is a fault in the engine management/injection system, and the exact cause has to be found by reading the stored error codes with diagnostics [#16346914][#16346362] Even if the message disappears after a restart, the ECU can still keep the fault in memory, so a scan is the right first step [#16346260][#16346522] In the reported case, diagnostics found two intermittent faults: a short circuit or break in the turbocharger pressure sensor circuit, and too-high pressure in pressure control [#16401543] Another similar case in a Megane II was caused by a poor fuel line connection and leakage at the fuel filter [#16346880]
  • #1 16346212
    ottoadam
    Rate: 14
    Hello, while driving, about 10 minutes after the ignition, the message "check the injection" and the car lost its power? Driving the bypass after the message the car did not accelerate as fast as before the message. After reaching the place and extinguishing the car and re-launching to today or two days, about 200 km. there is no silence, no message even once. Can anyone have such a message or know what it could have been? please help. Adam.
  • #2 16346260
    Qbuś
    Help: 380
    Rate: 876
    It would be good to check the injection.
  • #3 16346281
    ottoadam
    Rate: 14
    I understand. It's quite logical because it was even written. I'll start by connecting my computer. I guess. Because check the injection? But which message is not general? for several things in total?
  • #4 16346318
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    I always send you to the instruction manual, seriously.
    The owner should know what these messages mean.
    If there is no time for such crap, unfortunately a visit to the workshop. :)
    And I do not write this maliciously.
  • #5 16346343
    ottoadam
    Rate: 14
    Do you think that the manual would be written what does this message mean? hm ... maybe right. But with about 20 cars in my life I have never had any instructions for use. Maybe because they were not new or I did not need it. I wrote this thread on the forum to find out faster than I would search for instructions on the net and read it otherwise, I guess such forums are there to help myself by communicating with each other and asking. But ok, what's right is right and you have the equipment and you want to use it "first read the operating instructions". Thanks to the valuable fact.
  • #6 16346362
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    But I write seriously.
    Check the injection as it is in the old car, the engine failure light is on.
    Do you think that without equipment?
    Now there are awfully intelligent engine controllers, they remember even the number of starts of the starter, not to mention such crap like any malfunctions causing the engine malfunction indicator to light up.
    So the forum will not help without the particulars of the diagnosis.
  • #7 16346416
    ottoadam
    Rate: 14
    Ok, thank you for your help, a hint. Tomorrow I will hook up the computer and read the errors. It will be a little brighter. Adam.
  • #8 16346522
    kamiloskop
    Help: 42
    Rate: 279
    No one will guess what may be the cause of your problem and will present you with a diagnosis and I will sign for it and say that it is sure in 99% you will not check the car itself under the appropriate diagnosis and not some Chinese sell only the best clip-em. Your car even if it will to walk around it will remember the early occurring errors and it will help a lot. Please save the current errors and errors that are left in memory but do not occur at present.
  • #9 16346680
    ottoadam
    Rate: 14
    I am scheduled for service in Gdansk today for 14 for error reading and general car diagnostics. I have an appointment now. Will write in the evening what mistakes were and what they said.
    And when I wrote that I was connecting the computer, I meant a visit to the website, but I did not write it. Sorry, my mistake. Adam.
  • #10 16346880
    zulusj23
    Help: 90
    Rate: 103
    A few days ago, a friend in Megane II 1.5 dCi had the same message. It turned out in the workshop that due to poor connection of the fuel line, the injection system was injected on the fuel filter. After the removal of the leaks, it's supposed to be calm for a week. But in his case, the renegade completely refused to smoke, and it was necessary to call a tow truck to deliver the car to the workshop.
  • #11 16346914
    mario 77
    Help: 66
    Rate: 335
    And from this you should start and if there is any ambiguity in the diagnosis or lack of ideas for removing the fault then write on the forum.
    ottoadam wrote:
    and the message is not generic? for several things in total?
    Yes, this is just a message to the driver that there is a malfunction in the engine management.
  • #12 16401543
    ottoadam
    Rate: 14
    I am sorry that I have not been answering for a long time.
    I was on the site to read errors and showed up two:
    - Turbocharger pressure sensor circuit short circuit or circuit interrupted.
    - Pressure control too high pressure.
    Both errors were "not always."
    I was told that I have nothing to do with this for now because the message lit the orange "service". And just when it turns red it must be replaced after that since then there is silence, this error did not appear.
    And this service was a post-warranty service, it was not a Renault dealer.
    Thank you to all who have guided me to solve the problem.
The discussion revolves around a power loss issue in a 2007 Renault Scenic II, accompanied by a "check injection" message. The user experienced a significant drop in acceleration after the warning appeared but noted that the issue resolved itself temporarily after restarting the vehicle. Forum participants suggested checking the vehicle's diagnostic codes, emphasizing the importance of using proper diagnostic equipment to identify the root cause of the problem. One user shared a similar experience with a Renault Megane II, where a fuel line connection issue led to injection system problems. Ultimately, the user reported two diagnostic errors related to the turbocharger pressure sensor, which were deemed non-critical at the time, and indicated that the issue had not recurred since the service visit.
