Kazam x5.5 Phone: Best External GPS Antenna Options Under PLN 40 or DIY Approach?
Korsir 3210 4
  • #1 16352975
    Korsir
    Hello !
    I have an old Kazam x5.5 phone
    I decided to convert it to GPS for offroad. Unfortunately, the range is very poor.
    I have already located the GPS location and now I have a few questions:
    1. What antenna to buy for this?
    2. What do you recommend up to PLN 40?
    3. Maybe it's better to do it yourself, only I heard that a wrongly calculated one does not give you anything.
    actin
    Help: 187
    Rate: 799
    Do you only use GPS or A-GPS?
  • #3 16357888
    Korsir
    Probably only GPS, and what is it basically different?
    I want to use the Locus map free app, so only GPS
    avatar
    Level 36  
    Help: 159
    Rate: 415
    As long as the phone has BT, it makes no sense to buy an external GPS receiver and pair it with the phone?
  • #5 16358880
    Korsir
    This is also a way out. And how much is something like this and what is the best choice up to PLN 70 (rather to buy a used one)?
