Lark FreeBird 50.9 BT Navigation Update: Download Maps from Navigo.pl Alternative Site
arek9797 13125 9
Where can I download map updates for the Lark FreeBird 50.9 BT navigation now that navigo.pl no longer works?
You can update it from mapamap.pl, and the thread later says the old navigo.pl data was moved to sklep.techvigo.pl, where you can log in with the same login and password as before [#16574400] [#16621760] If you need the serial number for the update, it should be in the navigation’s Settings/System menu or on the sticker on the housing [#16574435]
  • #1 16574371
    arek9797
    Good day. I would like to update the Lark FreeBird 50.9 BT navigation. Recently, I downloaded maps from the navigo.pl website. Today this site is not available or does not work, I do not know. I would like to know if now I need to update it from a different page. I apologize if I put the topic in the wrong section.
  • #2 16574400
  • #3 16574403
    arek9797
    Will you tell me where I can find the 12-character serial number?
  • #4 16574435
  • #5 16574463
    arek9797
    I fired and I do not see any serial number that would consist of 12 characters or 4x5. The page says so. Serial no .: 12 characters, letters AF (af) and numbers 0-9 or 4 x 5 characters (in the format xxxxx-xxxxx-xxxxx-xxxxx) any letters and numbers
  • #7 16574926
    japycz321
    Help: 92
    Rate: 141
    Maybe a colleague try to contact the producer. Unfortunately, but my experience with this company shows that the chances of success are negligible. There is also a chance that it is just a momentary failure and the page will appear again in a few days.
    nutergsm wrote:
    You can also purchase any navigation program.
    ... operating under windows CE.
  • #8 16621760
    camil88
    I had exactly the same problem and just a moment ago I found a page from which you can download the latest update.
    https://sklep.techvigo.pl/
    The migration of all existing data has probably been carried out, you do not need to register again - you can log in with the same login and password as before.
  • #10 16621829
    jajacekpl
    Help: 65
    Rate: 268
    So a colleague has a Larkmap or Navigo program, so stop giving him advice on the MapMap upgrade
The discussion revolves around updating the Lark FreeBird 50.9 BT navigation system after the navigo.pl website became unavailable. Users suggest alternative sources for map updates, including mapamap.pl and a new site, sklep.techvigo.pl, where the latest updates can be downloaded without needing to re-register. Additionally, users discuss locating the 12-character serial number required for updates, which can typically be found in the device settings or on a sticker on the device. Some users recommend contacting the manufacturer for assistance, although experiences suggest limited success in this regard.
