Voice communicator (something like Skype) for Windows XP and without SSE2 suppor
Nemo 2817 3
  • #1 16360413
    Nemo
    Help: 9
    Rate: 72
    As from today (on Thursday 16/03/2017 it was still working) it was not possible to log into the old Skype 7.5.0.102, it was necessary to update. Unfortunately, the program does not install, probably due to the lack of SSE2 (Athlon XP machine, Windows XP SP3). I suppose this problem cannot be solved - the support for Skype versions below 7.17 has ended, and this version also does not install.
    So what can you use instead of Skype? Let me remind you, the messenger must run on Windows XP and old CPU without SSE2. It can also work as a p2p messenger.
    Mainly it is about voice calls with several friends, but not all at the same time - they all have Neostrada, so no fixed IP, although it is possible to configure port forwarding on the router.
    Replacing the computer is not an option.
    What to use instead?
    Greetings.
  • #2 16360498
    Kasek21
    Help: 4981
    Rate: 3547
    GG (or its derivatives) is not enough for voice calls?
  • #3 16360661
    DriverMSG
    Help: 3984
    Rate: 4883
    Alexander Graham Bell once came up with a cool device - it still works and doesn't require SSE2. :D
    If you add WhatsApp to it, you are ready.
  • #4 16360909
    Gelip
    Level 36  
    Help: 324
    Rate: 611
    Try TeamViewer or Radmin 3.5
