Microphone Noise Issue on Skype and Games with Windows XP Sound Max Card
30092 6
  • #1 9888608
  • #2 9888832
    Platon
    Help: 744
    Rate: 170
    This is how you mute the microphone in the playback mixer.
    In the recording mixer, select the microphone instead of what you probably have "stereo mixer" or "what u hear".
  • #3 9888856
    cepilek
    Help: 62
    Rate: 194
    Also try like this: in the right corner at the bottom of the screen, click twice quickly with the left mouse button on the loudspeaker, give: Options / Properties / Recording, select Microphone and OK, then Options / Drivers / Advanced and in the Mic Boost field, give a tick and close - enjoy microphone in Skype at will ...
  • #4 9888964
  • #5 9889249
    Grubskee
    Help: 8
    Rate: 54
    Of course, the microphone under the red input and the speakers / headphones under the green?
    vodiczka
    Help: 1185
    Rate: 4311
    you may have knocked down the input if you turned the microphone plug on and off while the computer was running. I did my laptop and had to buy a microphone with a USB output, it was cheaper than the repair.
  • #7 9889592
The discussion revolves around a microphone noise issue experienced by a user on Skype and in games while using a Windows XP system with a Sound Max digital integrated audio card. The user reports that their voice is not audible, only background noise is picked up, and a yellow triangle with an exclamation mark appears next to the microphone in the Sound Max control panel. Various suggestions are provided, including muting the microphone in the playback mixer, adjusting settings in the recording mixer, and ensuring correct input/output connections. The user suspects potential driver issues or a malfunctioning microphone input, considering switching to a USB microphone as a possible solution.
