Premium DXI 410: Understanding Performance Loss Message, Error Codes MID 128 SID 32 FMI 5
adam7m 13638 1
  • #1 16372172
    adam7m
    Hello. In Premium DXI 410, the message "performance loss" appeared. Error code:
    MID 128, SID 32, FMI 5
    MID 128, PSID 98, FMI 1
    What does it mean? Thank you in advance for your help.
  • #2 16373460
    Cobrat
    Help: 35
    Rate: 500
    MID 128, SID 32, FMI 5 - System controlling the discharge valve outlet current below normal or open circuit. (Possible electrical failure of the valve from the mountain brake),
    MID 128, PSID 98, FMI 1 - the error concerns the air charging system (check the air inlet for leaks, sensor and its bundle, turbine).
