Premium dni 450 immediate stop - Blad mid 140 psid 227 fmi 12
Sm123456 15267 7
  • #1 17021917
    Sm123456
    For a few days I have been popping up from time to time katrolka immediate stop in the circle the inscription air and an error mid 140 psid 227 fmi 12 maybe someone had to deal with this problem and would be willing to help in advance, thank you
    Added after 5 [minutes]:
    I will add that the main brake valve was replaced recently, it had leaks, now it is new, original
  • #2 17022728
    Dagomir
    Help: 42
    Rate: 191
    The Mid 140 deals with the instrumentation panel (display, clock) as who called it. Unfortunately, I have no way to check the rest of the code. Check if the APM system reports something when the error occurs, it will allow you to more accurately determine the cause. Generally, if there were large air leaks, it would be appropriate to replace the dryer, calibrate it and restart the compressor. Of course, everything requires the use of a diagnostic interface. Describe if the message lights up in specific conditions?
  • #3 17022978
    Sm123456
    The amp works properly, it does not give any errors, but I noticed that this error is more intense when the ambient humidity is high, i.e. it is snowing
    Apm and compressor ok checked, I will replace the apm filter at the most, but I will do it at the weekend
  • #4 17023122
    Cobrat
    Help: 35
    Rate: 502
    MID140 PSID 227 FMI 12 - Data link, air dryer (APM)
    DTC
    FMI 12
    Conditions for the DTC:
    Expected signal is not reaching the device.
    Possible Cause:
    Wiring harness fault.
    Connector malfunction.
    Control unit reaction:
    the DTC is set
    There is no lighting function.
    Adequate control:
    See service information, group 3711, information type "Diagnostics", "Data Channels, Troubleshooting".
  • #5 17023383
    Sm123456
    What does it mean "no lighting function"
    Dagomir
    Help: 42
    Rate: 191
    "There is no lighting function" It's probably just a matter of translating the service. Check, buddy, CAN bus harness from APM to the tractor, maybe worn braid in contact with moisture generates errors. Also check CANs for short circuits to plus and vehicle weight.
  • #7 17050226
    Sm123456
    The plug on the amp was frozen and not properly tightened, the error disappeared ok thank you all
  • #8 17051020
    Cobrat
    Help: 35
    Rate: 502
    We helped? All you need is gratitude in the form of marking a given post as "helpful".
The discussion revolves around an error message related to the MID 140, specifically the PSID 227 FMI 12 code, which indicates a data link issue with the air dryer (APM). The user experienced intermittent "immediate stop" alerts and noted that the error intensified in high humidity conditions. Responses suggested checking the APM system for errors, inspecting the wiring harness and connectors for faults, and ensuring proper connections, particularly in moist environments. The user later identified that a frozen and improperly tightened plug on the APM was the cause of the error, which was resolved after addressing this issue.
