De Longhi Prima Donna S vs. Express: Disassembling & Cleaning Guide
alfredor 6135 1
  • #1 16378711
    alfredor
    Rate: 66
    How to undress, De Longhi Prima Donna express?
  • #2 16382078
    gaarth
    Rate: 116
    1. Open the top cover.
    2. Use a screwdriver to pull apart the hinges on the springs and it should come out.
    3. There is plastic between the hinges, it needs to be prized up and it will pop out.
    4. There are 2 screws under it. After removing them, the rear casing slides upwards and there is access to the insides.
