Seeking Windows 7 64bit Drivers for Asus A555L - USB Functionality Issues
kamilek71 17265 19
How can I get Windows 7 64-bit drivers for an Asus A555L when USB is not working?
Yes, but you need to install the drivers one component at a time from Device Manager, usually after unpacking the EXE package and pointing Device Manager to the driver folder as the source [#16388690][#16388623][#16388729] For the Intel chipset/USB stack, use the chipset package for VEN_8086 DEV_9CB1, the Intel DPTF package for VEN_8086 DEV_1603, and the Intel USB 3.0/xHCI controller driver [#16388690][#16388729] Install the Atheros Wi‑Fi driver for VEN_168C DEV_0036, the NVIDIA graphics driver for VEN_10DE DEV_1299, and the Intel MEI driver for the PCI Simple Communications Controller [#16388690][#16388729] If MSFT0101 remains in Device Manager, Windows 7 does not support it; disable PTT in BIOS so it disappears [#16388729] The thread also recommends installing ASUS ATKPackage and SmartGesture if you want hotkeys and touchpad functions [#16388729]
  • #1 16387762
    kamilek71
    Looking for drivers for windows 7 64 bit ?? even USB is not working, are there such drivers?
  • #2 16387784
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Provide device identifiers for which drivers are missing.
  • #3 16387794
    kamilek71
    Seeking Windows 7 64bit Drivers for Asus A555L - USB Functionality Issues the point is ?
  • #5 16387815
    kamilek71
    I have tried to install these drivers and constantly crashing Seeking Windows 7 64bit Drivers for Asus A555L - USB Functionality Issues
  • #6 16387818
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Have you installed Sp1 to W7 and other updates from Windows Update?
  • #7 16387829
    kamilek71
    i don't know the computer has no internet connection where can I check it?
  • #8 16387833
    Kasek21
    Help: 4981
    Rate: 3547
    Post screen from My Computer -> Properties.
  • #9 16387842
    kamilek71
    this is how it looks Seeking Windows 7 64bit Drivers for Asus A555L - USB Functionality Issues
  • #10 16387846
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Start by installing a lan or wifi card and download the updates.
  • #11 16388511
    kamilek71
    I have updated and further crashes that the system does not meet the minimum requirements.
  • #12 16388546
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Then do not install the drivers for the chipset or download other versions from the Intel website.
    Install other devices.
  • #13 16388579
    kamilek71
    I can't install anything, even usb. Internet only works over the cable
  • #14 16388623
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Install from the device manager, choosing driver updates and pointing to the driver directory as the source.
    It is a pity that you did not want to provide device identifiers.
  • #15 16388682
    kamilek71
    System management bus controller
    PCI \ VEN_8086 & DEV_9CA2 & SUBSYS_1A6D1043 & REV_03
    PCI \ VEN_8086 & DEV_1603 & SUBSYS_1A6D1043
    PCI \ VEN_8086 & DEV_9CA2 & CC_0C0500
    PCI controller for data collection and signal processing
    PCI \ VEN_8086 & DEV_1603 & REV_09 & SUBSYS_1A6D1043
    PCI \ VEN_8086 & DEV_1603 & CC_118000
    PCI \ VEN_8086 & DEV_9CA4 & SUBSYS_1A6D1043 & REV_03
    PCI \ VEN_8086 & DEV_9CA4 & CC_118000
    PCI \ VEN_8086 & DEV_9CBA & SUBSYS_1A6D1043 & REV_03
    PCI \ VEN_8086 & DEV_9CBA & CC_078000
    Network controller
    PCI \ VEN_168C & DEV_0036 & REV_01 & SUBSYS_213A1A3B
    PCI \ VEN_168C & DEV_0036 & SUBSYS_213A1A3B
    PCI \ VEN_168C & DEV_0036 & CC_028000
    Universal USB serial bus controller
    PCI \ VEN_8086 & DEV_9CB1 & SUBSYS_201F1043 & REV_03
    PCI \ VEN_8086 & DEV_9CB1 & CC_0C0330
    3D video controller
    PCI \ VEN_10DE & DEV_1299 & SUBSYS_1A6D1043 & REV_A1
    PCI \ VEN_10DE & DEV_1299 & CC_030200
    Unknown device
    ACPI \ INT3400
    * INT3400
    Unknown device
    ACPI \ MSFT0101
    * MSFT0101
    sorry I thought that this first photo was enough.
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8291
    I have been forewarned, so I will leave my list as a possible alternative.
    Chipset: https://downloadmirror.intel.com/20775/eng/Chipset_10.1.1.42_Public.zip
    - alternatively: http://dlcdnet.asus.com/pub/ASUS/nb/DriversFo.../Chipset/Chipset_Intel_Win7_64_VER9401027.zip
    Intel DPTF: http://dlcdnet.asus.com/pub/ASUS/nb/DriversForWin8/DPTF/DPTF_Intel_Win7_64_VER7102105.zip
    Intel MEI (PCI Simple Communications Controller) - attached (MEI), installation by device manager
    Network controller: In attachment (Atheros), installation by device manager
    USB controller: https://downloadmirror.intel.com/22824/eng/In...Xtensible_Host_Controller_Driver_4.0.6.60.zip
    3d controller (Nvidia GT920M): http://www.nvidia.pl/download/driverResults.aspx/116451/en
    You probably need to have previously installed drivers for the Intel graphics card, if in the graphics cards section you have standard graphics controls instead of Intel HD then install the drivers from the Intel HD card before: https://downloadmirror.intel.com/26228/eng/win64_154028.4501. exe
    For * MSFT0101 there is no support under Windows 7, disable PTT in BIOS (Platform Trust Technology) and should disappear from the manager.
    It is also worth installing Hotkey related tools: http://dlcdnet.asus.com/pub/ASUS/nb/Apps_for_Win8/ATKPackage/ATKPackage_Win7_64_VER100033.zip
    If you work on a touchpad, it is also worth installing a driver for the appropriate model of the touchpad: http://dlcdnet.asus.com/pub/ASUS/nb/DriversFo...SmartGesture/SmartGesture_Win7_64_VER2214.zip (for scroll to work and other advanced functions).
    • atheros-win7-10.0.0.336-whql.zip (2.54 MB) You must be logged in to download this attachment.
    • MEI.zip (191.51 KB) You must be logged in to download this attachment.
  • #18 16388775
    kamilek71
    something new popped out after the USB installation:
    USB2.0-CRW
    USB \ VID_0BDA & PID_0129 & REV_3960
    I can't install it, it can't detect drivers.
    DriverMSG
    Help: 3984
    Rate: 4883
    • USB Realtek-10.0.10125.31214.rar (1.84 MB) You must be logged in to download this attachment.
    • Intel-1.2.3.2005.rar (44.65 KB) You must be logged in to download this attachment.
  • #20 16388831
    kamilek71
    thanks a lot gentlemen, everything is flying fast :)
The discussion revolves around the search for Windows 7 64-bit drivers for the Asus A555L, particularly addressing USB functionality issues. The user reports that USB ports are non-functional and seeks assistance in finding the appropriate drivers. Various responses suggest checking device identifiers for missing drivers, installing necessary updates, and using the device manager for driver installation. Specific driver links for chipset, network controller, and USB controller are provided, along with troubleshooting steps for installation failures. The user eventually reports successful installation of drivers, resolving the initial issues.
