Replacing gas pipes with copper and transferring the meter to the staircase
programosy.pl 26907 3
  • #1 16389530
    programosy.pl
    Rate: 8
    Hello, I bought a flat in a 2-storey block (a housing community). I am doing a general renovation and I want to replace the old copper gas pipes and move the gas meter to the staircase. The gas in the apartment is used to heat hot water using a junker. Heating in the apartment is urban. The housing community has agreed to such an operation -> More specifically, I wrote a letter of permission, and they agreed. Well, I wonder if this is enough, and whether I should not sometimes apply for conditions to the community. I also asked in PGNiG if they saw the problem and said in a word that I would do a new installation, i.e. new pipes, leave the cage and report them and the worker will come and move the meter and flow to the new installation. Hmmmm, everything is too beautiful and too easy. So I decided to ask in the same way in writing - and even they did not accept such a letter, but finally they accepted and said they would write back, but it is not for them to decide on permits and conditions only to write to the Housing Community.
    Well, the matter is that if I have permission from the community, now I should call a licensed gas distributor and he will distribute such pipes to me through the apartment and from the hallway to the kitchen where there is Junkers and gas cooker, and then I call someone from PGNiG and this someone has to pass the gas meter outside the cage and finish.
    If so, it would be great, but knowing the bureaucracies of our country is probably something goes wrong and there will be stairs in the form of a lack of building permit, design and God knows what else ... I am asking for a specific answer and hints what to do next to do this. I care about replacing these pipes and moving the gas meter to the cage, but I do not want to have problems.
    PS. In the previous apartment I was doing a conversion of heating from coal to gas, I know that it was necessary to carry out the project, building permits, construction manager and a few other necessary permits and expert opinions. However, in the current apartment the situation is completely different, hence my request for help.
    wzielonymgaju18
    Help: 32
    Rate: 110
    Modernization of the installation does not require permission from the staroste (building permit).
    If you have Community approval (preferably in writing) then you can move the meter to the staircase.
    Installation after the meter is your property and you can modify it, move it as you like. However, the installation (pipes, meter) in front of the meter is owned by PGNiG, and they should make the alteration.
    Some distributors are demanding a modernization project.
    Ask PGNiG for a contractor for such a modification and guidelines, maybe they have specialists, what will come and bring you the meter to the cage and possibly distribute the installation around the apartment.
    Because doing the installation before the meter transfer operation is a bit risky (PGNiG may create some problems), but when they arrive and put the meter on the cage and seal it, you can still distribute the installation with the help of any specialist and PGNiG.
  • #3 16404454
    programosy.pl
    Rate: 8
    Today I called the City Hall and told me in the appropriate department that the meter's transfer to the staircase requires the consent of the community (it is obvious) and the project ... In general, the same procedure as when replacing heating from coal to gas. Hm, this is very sick: - / Perhaps there is some legal regulation, an article that allows you to omit these sick recipes, or maybe the clerks just clatter stupidity. I have no nerves for this - everywhere they say differently. PGNiG says that no projects are needed only for approval from the Community.
  • Seeking easier formalities for a 55 cm gas meter move
    #4 19506831
    odyss77
    I have a similar problem with bureaucracy. Except that he wants to move the gas meter with the box on the wall about 55 cm horizontally.
    A kind of simple thing. PGNiG demands a modernization project made by an architect - the cost is about PLN 1000, which must be approved by the Architecture Department of the District Office. The cost of the transfer itself is about PLN 250. Isn't that sick? Does anyone know a recipe that would make the formalities easier?
