Audi A6 2.0 TDI 2004 (140km) Stalling during Drive: Fuel Pump or Other Cause - VCDS No Errors
sebastianpr 7728 3
  • #1 16390718
    sebastianpr
    Rate: 53
    Hello, I have a problem with the audi a6 2.0 tdi 140 km. The car goes off while driving after driving about 50 km. After it goes off, it spins the starter a few times and fires normally. VCDS does not see any errors. I think about the fuel pump in the tank, but I'm not 100% convinced
  • #2 16390785
    mysz777
    Help: 5
    Rate: 9
    Hello, a little imprecise description of the subject "fades".
    if there are any jerks, chokes, etc., the fuel system to be checked, if nothing happens at all and suddenly STOP is the control. if the computer shows no errors, you have to look for what it does not see: shaft position sensor, relay, ignition.
  • #3 16391188
    sebastianpr
    Rate: 53
    the shaft sensor would trigger an error, when the lights go off, they are lit as well as the relay on the ignition hmmm. I will try to drive with the computer and see if it loses connection.
  • #4 16391260
    MobilTruck
    Help: 139
    Rate: 963
    When it goes out, it is enough to turn on the ignition again and listen to whether the pump in the tank works for a while. I suspect that it is the finishing touch, recently to me, a lot of B6 has been affected by this ailment.
