Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue?
Fidelis 44769 20
Why does my Kärcher K 2.110 pressure washer keep running and fail to switch off when I release the trigger?
The problem is usually not the electrical pressure switch itself; on this washer the shutoff is mechanical and depends on pressure in the pump/head, the check valve/non-return valve, and the lance trigger mechanism [#18006699][#16475964] A dirty inlet check valve or a valve that does not hold pressure can make the washer keep running because the pump cannot build the pressure needed to trip shutoff [#16402908][#16474039] In the reported case, the real fault was that the plug/sliding stem in the trigger switch had slipped out, and the straight lance nozzle was clogged enough to keep the rod from returning after pressure dropped [#18008580] Cleaning or replacing the nozzle/lance and checking that the trigger plunger moves freely fixed the issue [#18008580] If it still runs continuously after that, inspect the check valve and pressure-valve parts for leaks, cracks, or worn seals [#16475964][#16474039]
  • #1 16393245
    Fidelis
    Rate: 140
    The washer worked flawlessly for two seasons. Currently, after connecting the water and switching the selector to ON, the washer does not turn off, i.e. regardless of whether the water intake from the lance is or not - the pump is constantly working. Where can the problem be? In the pressure switch?
  • #2 16402908
    RAFAŁ.M
    Level 19  
    Help: 21
    Rate: 61
    I had a similar problem in a small washer. The reason was a dirty check valve at the pump inlet from the water supply side.
    It is best to connect the washer to the power supply through a water filter.
  • #3 16402975
    Fidelis
    Rate: 140
    Considering how fast the submersible pump "grows" with iron and manganese, it can be like that. I will check and let you know. Thanks for the tip ...
  • #4 16458900
    Fidelis
    Rate: 140
    I looked at the filter sitting in the water connection. It was admittedly a bit contaminated with stone, but after cleaning the washer still does not turn off ... Maybe it is a problem with the pressure switch?
  • #5 16473129
    tobiasz86
    Rate: 39
    The motors often "fall" in these washers, and specifically the contacts on the commutator break off.
  • #6 16473347
    REMUR.
    Help: 143
    Rate: 255
    Fidelis wrote:
    the pump works all the time
    tobiasz86 wrote:
    The engines often "fall" in these washers
    @ tobiasz86 , please read with understanding.
    Fidelis wrote:
    Maybe this is a problem with the pressure switch?
    This is one of the symptoms.
  • #7 16473387
    tobiasz86
    Rate: 39
    The engine starts but does not generate pressure? Is that it?
    If so and no water leaks are visible, the problem is either the gearbox or the pump is worn out and it is not able to pressurize the device.
    Write if it generates pressure and ew at what level it is.
  • #8 16473988
    Fidelis
    Rate: 140
    Vice versa. After "releasing" the button on the lance, the engine should automatically turn off (due to the increase in pressure) and not turn off. Ie. water from the lance does not fly and the engine is running.
    There are no leaks. I don't know what the transmission has to do with the shut-off automaton, but the pump as such works without reservations. "Does pressure."
    Pump worn out? I used this washer maybe a dozen times for 7 years.
  • #9 16474039
    tobiasz86
    Rate: 39
    If the pump works and assuming that it constantly generates pressure, then something must happen to it - it returns to power. Does not hold a check valve. The problem is definitely not on the switch side. If the pump were fully functional and the pressure switch was defective, the engine would eventually get stuck or damage the gears.
    The fact that the washer is used sporadically does not mean that it should "walk" not this model ...
  • #10 16475045
    Fidelis
    Rate: 140
    ... and before that the safety valve worked, if I understand correctly. Or so ?
  • #11 16475122
    tobiasz86
    Rate: 39
    I don't know anything about a safety valve. When the trigger is released, the pressure increases and this leads to the engine starting and can be considered a safety valve. It takes a split second, you get the impression that the trigger turns the engine on and off - it regulates the pressure inside the head.
    One hundred damaged k2 hands passed through. In most cases engines fall, especially on newer models, second place cracked pump housing, several damaged gears and only one piece with damaged switch
  • #12 16475159
    Fidelis
    Rate: 140
    I don't know the design of this module. In the offers found in the network "Karcher check valve" (included in the price of the whole washer) I read:
    "The valve has two basic functions:
    1. Safety valve. The accumulated excessive pressure as a result of damage to the switch is transferred to the water inlet.
    2. Smooth pressure control valve. Using the knob you can precisely regulate the pressure transmitted from the head to the outlet (gun).
    Perhaps the bidder actually describes the operation of the pressure switch (pressure switch) as the functionality of the safety valve. Or I don't understand something.
    You see, and I - a layman - would say that this is how a pressure switch works. As for controlling the operation of the hydrophore. Because the safety valve in the nose should have if the engine still works or not. Regardless of the operation of the electronics / electrical system, in emergency mode (above a certain pressure) it mechanically and automatically, reduce the pressure without going into details (as in central heating installations).
    This washer was used several times. Each time a few minutes were used to rinse garden furniture or remove dirt from birds. More unfolding than work. That something is happening to her at all is a shame and no excuse for Karcher. Because such a basic model? OKAY. And what? The perfect model for my home requirements, but that does not mean that if basic, it has the right to fall under such intense "consumption". Just like the green "renowned" Bosch product line - when I turned up the drill, I could not be surprised that the German could afford the production of such crap. Unless specifically for our market ... Of course I don't blame you. Such a loose reflection ... ;-)
    Today I do not have time to start, but I will definitely take her on this season. The whole valve (possibly) needs to be replaced? Maybe some spring is blocked? As it happens in check valves ...
  • #13 16475249
    tobiasz86
    Rate: 39
    Zerkne tomorrow, and out of curiosity check at home what is made in ...
    Often in our supermarkets there are some china or taiwana, I have washers from the uk and there are only italy or germany, it is so green bosch on our market ... something in this we get chlam ...
  • #14 16475964
    REMUR.
    Help: 143
    Rate: 255
    For a better understanding of the pressure washer, I put a description.
    I note that this is a Makita HW130 washer, I think that other companies' solutions are similar.
    The washer is connected to the water intake through the filter 1 (strainer), then the water goes to the pump and from it under increased pressure it is pumped through the pressure valve 8 and the check valve to the lance. From the non-return valve, water is also fed through the channel to the chamber 9 to the piston 13 of the pressure valve. The pressure valve consists of a piston 13, a spring and a cone valve 10, which is closed during the operation of the washer. A cone valve 10, M3 thread, is screwed onto the stem 12, the aim being to accurately set on / off. washer.
    Fig. A shows the washer during operation. When we close the lance (release the trigger), the pressure will increase in the system, also in chamber 9, the valve will open as shown in fig. B and turn off the washer by disconnecting the switch 17. Opening the valve 10 will cause the water pressure from the pump and the pressure valve to escape through cone valve and channel 11 for water intake. In the chamber 9 and in the pressure hose, the pressure will remain high, which will not allow the washer to turn on, this is prevented by a check valve 16. It can be seen that the washer left in the "stand by" state will occasionally start automatically for a while and this is because the pressure in chamber 9 and the hose will drop, due to leaks. What happens now, when the pressure valve fails (the conical valve closes endlessly, leaking orings, in the washer the stem is cracked at the transition from fi 4mm to fi 3mm). After pressing the trigger 15 lance, the pressure in the chamber 9 drops, the spring closes the valve, the engine starts, the pump generates pressure, water goes to the lance and through a closed cone valve to the outlet through channel 11, as a result of which the lance has low pressure. When we close the lance now, the washer will not be turned off because the pump cannot build pressure in chamber 9 enough to push the pressure valve, because all the water is pushed into the outlet of the network, which is illustrated in Fig. C.
    In this condition the washer can work without any damage.
  • #15 16478695
    tobiasz86
    Rate: 39
    In k2 there is no regulation valve, the ones you write about are for hd washers for a few thousand.
    Parts from the site are rather not calculated to buy because they exceed the value.
    The only sensible option is to buy the washer alone without the equipment or sell the washer for parts separately and go for new ones.
  • #16 16479778
    Fidelis
    Rate: 140
    Made in Germany. Where to look at the box or on the nameplate ...
  • #17 18006652
    Fidelis
    Rate: 140
    Could you indicate which element is responsible for measuring and switching off the pump?
    Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue? Karcher K 2.110 Pressure Washer: Constant Running, Pressure Switch Issue?
    The only switch is the one integrated with the white plug / stem coming out of the housing of the dispenser responsible for sucking in cleaning chemicals.
  • #18 18006699
    tobiasz86
    Rate: 39
    There is no measurement, it is purely mechanical. You release the gun trigger, the pressure in the pump - actually, between the pump and the gun increases and mechanically pushes the mushroom mentioned by you turning off the engine, after pressing the trigger and thereby reducing the pressure in the system the mushroom returns to the position of starting the engine. Often in cheap washers it happens that the engine starts automatically for a short time, it is caused by a leak in the gun and this is manifested by passing water to the lance when the drain is in the off position or what more often happens water is passed to the supply hose in this case not we have no leakage outside the device. I don't mention broken pumps because it's obvious.
    What is your problem with the washer?
  • #19 18008580
    Fidelis
    Rate: 140
    As I wrote above:
    " Currently, after connecting the water and switching the selector to ON, the washer does not turn off, i.e. regardless of whether the water intake from the lance is or not - the pump is constantly working "
    Of course, I still used the damaged washer: I just tried to wash so that the water was pumped all the time, i.e. it had an outlet - I had the trigger on the lance. Everything so that the water pressure does not burst the device.
    A few days ago it became impossible. One dish turned on the washer, the pump literally worked for a second, then turned off. She didn't react to ON / OFF. I thought I burned the rotor winding. I dismantled the whole thing and check it in turn: where it needs voltage, power switch OK, I connected it briefly and it turns out that the pump also works. And I got rid of it. I turned the whole thing on again and after about a second of work the pump switches off again and the changes on the switch stop responding.
    I took a closer look at the pressure switch mechanism and it turned out that the plug had slipped out of the trigger switch and the switch was still OFF. And why after a while the washer turned off, I do not know myself. It also turned out that the straight lance was clogged to such an extent that the sliding stem of the switch pulled out the trigger rod and turned off the washer, but did not retract after the pressure drop. Ot and the whole secret.
    The worst thing that I fixed one - the washer's automat works, but wanting to clean the nozzle of the end lance I put a skewer there, which turned out to be too large, and I pushed the nozzle a bit. Well, at the moment the washer washes and only washes - and that's a good word; does not clean as it has so far. Question, whether this yellow nozzle is unscrewed and replaceable, or is the entire end lance replaced (without a gun, of course)?
    And the second thing: I noticed a disturbing difference in the color of the stator winding: one winding is golden copper and the other falls in deep red. Is it normal ? (photos of windings attached)
    Thanks again for your interest in the case.
    tobiasz86
    Rate: 39
    Which lance you use, you can repair it by rotating by replacing the entire nozzle / this cone, I don't know what to call it, but the cost is not low, you can't fix it flat, it is adjustable, it is disassembled, but I don't know if you can buy nozzles you would have to ask the service.
    Several dozen k2 damaged pieces passed through my hands and there was no winding problem in the government, there was a stator failure, problems with the pump itself, such as cracks, leaks, or transmission between the motor and the pump - unfortunately the plastic modes in one case had a broken switch.
  • #21 18008807
    Fidelis
    Rate: 140
    I have a basic one, which is flat. Well, of course - I will buy some used rotary one now. They are at similar prices.
    To these faults I would add unbelievably poor quality plastic threads (now changed as I can see to the click fittings) e.g. between the connector coming out of the pump and the nut of the lance hose. I do not know if the reason for the weakness of the thread is vibration or contamination getting there between the threads and after twisting and unscrewing several times. Anyway, this plastic is not suitable for use here. My connection during washing disconnected so often that I finally glued them with resin and I didn't find cheap used ones. And it works ...
    thanks
The Karcher K 2.110 pressure washer has been reported to have a persistent running issue where the pump does not turn off after the water is connected and the selector is switched to ON. Users suggest potential causes including a dirty check valve, issues with the pressure switch, or motor problems. The pressure switch is suspected to be malfunctioning if the pump continues to run without generating pressure. Other users noted that the washer's design may lead to common failures, such as cracked pump housing or worn-out gears. The discussion also highlights the importance of using a water filter to prevent contamination and the potential for mechanical failures in the system, particularly in cheaper models.
