Facebook Unresponsive, Other Sites Accessible: MTU Modification Attempt Failed, Day 2
Gregorius9 16230 9
How can I fix Facebook not opening in my browser while other websites still work?
Facebook was not loading because of AdBlock/uBlock Origin in the browsers, so remove those extensions from all browsers first [#16394408][#16394584] If that does not help, uninstall the browser, delete its profile folder, and install it again; in this case, reinstalling Chrome fixed the problem [#16394584][#16394637] The remaining guess was that a plug-in had updated itself and started misbehaving [#16394731]
  • #1 16393775
    Gregorius9
    Hello. I've had a facebook problem for 2 days. I can not read this page. I've already searched the forums for changing MTU but still nothing works. Below I paste the picture. Is anyone able to help me? I will add that I do not know about such things, so please explain how layman. Thanks Facebook Unresponsive, Other Sites Accessible: MTU Modification Attempt Failed, Day 2
  • #2 16393925
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    @ Gregorius9 place the required logs from FRST in the CLOTH.
  • #3 16394151
    Gregorius9
    Is it about the Farbar Recovery Scan Tool?
  • #4 16394178
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Yes, you have it given in every thread in this section, including hanging ones.
  • #5 16394340
    Gregorius9
    That's all ?
    • FRST.1.txt (114.16 KB) You must be logged in to download this attachment.
    • Addition.txt (31.07 KB) You must be logged in to download this attachment.
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Facebook does not open under Opera, IE, Chrome and Firefox?
    AdBlock changes to uBlock Origin in all browsers.
    Next to frst.exe, create a Fixlist.txt file with the contents:
    Task: {5D90A9CB-0823-411D-9694-5738C7B057D1} - System32 \ Tasks \ Opera scheduled Autoupdate 1485379580 => C: \ Program Files \ Opera \ launcher.exe [2017-02-27] (Opera Software)
    AlternateDataStreams: C: \ ProgramData: gs5sys [2816]
    AlternateDataStreams: C: \ Users \ All Users: gs5sys [2816]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio: gs5sys [3074]
    AlternateDataStreams: C: \ ProgramData \ Application data: gs5sys [2816]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ Cookies: gs5sys [3074]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ Application data: gs5sys [2048]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ Templates: gs5sys [3074]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ Local Settings: gs5sys [3074]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ Desktop \ desktop.ini: gs5sys [3074]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ AppData \ Local: gs5sys [3074]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ AppData \ Roaming: gs5sys [2048]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ AppData \ Local \ Application data: gs5sys [3074]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ AppData \ Local \ History: gs5sys [3074]
    AlternateDataStreams: C: \ Users \ Grzechu - Pedzio \ Documents \ desktop.ini: gs5sys [3074]
    AlternateDataStreams: C: \ Users \ Public \ Documents \ desktop.ini: gs5sys [2560]
    On other computers / telephones connected to the same router, FB opens up?
  • #7 16394564
    Gregorius9
    So. Opera and Chrome do not load and silt. I checked on IE and amazingly works! The phone works normally on Wi-Fi.
    • Fixlog.txt (3.31 KB) You must be logged in to download this attachment.
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Have you removed Adblock? You have it in both browsers, in Chrome even twice.
    This is the only thing that can cause a problem with what I see.
    Alternatively, you can download the bookmarks from Chrome, uninstall the browser, delete the profile directory: C: \ Users \ Grzechu - Pedzio \ AppData \ Local \ Google \ Chrome \ User Data \ Default and install Chrome again.
  • #9 16394637
    Gregorius9
    I did everything as you said. I have uninstalled and reinstalled Chromie and everything works correctly. I will uninstall the opera. Thank you very much for help. Can you know what was causing? I have used browsers for a long time and it has only happened for 2 days.
  • #10 16394731
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    I do not know, if I guess it was a plug, it could update itself and it went bad.
The user experienced issues accessing Facebook for two days while other websites were functional. Initial troubleshooting involved modifying the MTU settings, which did not resolve the problem. Subsequent responses suggested using the Farbar Recovery Scan Tool (FRST) to analyze system logs. The user confirmed that Facebook was inaccessible on multiple browsers (Opera, Chrome, Firefox) but worked on Internet Explorer. Recommendations included removing AdBlock and reinstalling Chrome, which ultimately resolved the issue. The user speculated that a plugin might have caused the problem due to a recent update.
