Mozilla Secure Connection Issue: Login Pages, Kaspersky Settings, Mobile Router vs Modem
eeeewa 3681 5
  • Mobile router likely causing certificate warnings
    #1 16640715
    eeeewa
    Today I turned on my computer and on every page that requires logging in (google, gmail, FB, YT, etc ..) there is an info that the connection is not secure:
    I scanned Kasperski and found no viruses.
    One of the solutions is an instruction on how to change the settings in Kasperski.
    Question: is it safe?
    Mozilla Secure Connection Issue: Login Pages, Kaspersky Settings, Mobile Router vs Modem If I then go to my bank's website to make a transfer, I should understand that this connection will no longer be encrypted or what?
    And one more thing: I have been using mobile internet with a router for almost two weeks. When I switch to the old modem that I used before (rechargeable net), the above-mentioned problem disappears! I can go to any page without any problem.
    So I wonder if it's some network bug (if so, how to fix) or some "third party" activity - and I'm afraid to touch anything in the settings.
    What should I do?
    Check system time and run malware scans
    #2 16640855
    RADU23
    Help: 2428
    Rate: 1732
    Have you set the time and date correctly in your system? Check it out.
    Then =>
    Perform MBAM and ADWcleaner scans and remove anything they detect
    https://www.malwarebytes.com/dl-confirm/
    http://www.bleepingcomputer.com/download/adwcleaner/
    Download Farbar Recovery Scan Tool http://www.bleepingcomputer.com/download/farbar-recovery-scan-tool/ compatible with 32-bit or 64-bit system version.
    Run FRST and click "Scan". Insert the FRST and Addition report as attachments.
  • #3 16641038
    eeeewa
    Date and system - approx.
    I deleted my browsing history and it started working again.
    However, I did it all according to the instructions - Malwarebytes detected something, deleted it. In the attachments, the FRST report.
    • FRST.txt (60.05 KB) You must be logged in to download this attachment.
    • Addition.txt (37.1 KB) You must be logged in to download this attachment.
    FRST fixlist to remove autorun entries
    #4 16641168
    krzychupar
    Help: 1490
    Rate: 633
    Otwórz notatnik systemowy i wklej:
    HKLM\...\Run: [] => [X]
    HKU\S-1-5-21-2051140457-2844106054-1565599238-1000\...\MountPoints2: {66df9838-ffe2-11e6-86f6-b86b23b4b282} - G:\autorun.exe
    HKU\S-1-5-21-2051140457-2844106054-1565599238-1000\...\MountPoints2: {8894d715-fb2b-11e6-888b-b86b23b4b282} - E:\AutoRun.exe
    HKU\S-1-5-21-2051140457-2844106054-1565599238-1000\...\MountPoints2: {93e70b3c-79c5-11e7-9aa6-b86b23b4b282} - E:\AutoRun.exe
    HKU\S-1-5-21-2051140457-2844106054-1565599238-1000\...\MountPoints2: {bea2b107-6da6-11e5-a13c-d07e3516b0e3} - E:\AutoRun.exe
    HKU\S-1-5-21-2051140457-2844106054-1565599238-1000\...\MountPoints2: {bea2b11e-6da6-11e5-a13c-d07e3516b0e3} - F:\AutoRun.exe
    HKU\S-1-5-21-2051140457-2844106054-1565599238-1000\...\MountPoints2: {cb5358de-8052-11e7-9fc8-b86b23b4b282} - E:\AutoRun.exe
    HKU\S-1-5-21-2051140457-2844106054-1565599238-1000\...\MountPoints2: {ff5e4efd-7c1b-11e5-9864-d07e3516b0e3} - E:\AutoRun.exe
    HKU\S-1-5-18\Control Panel\Desktop\\SCRNSAVE.EXE ->
    ShortcutTarget: Wysyłanie do programu OneNote.lnk -> C:\Program Files (x86)\Microsoft Office\root\Office16\ONENOTEM.EXE (Brak pliku)
    SearchScopes: HKLM -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
    SearchScopes: HKLM-x32 -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
    SearchScopes: HKU\S-1-5-21-2051140457-2844106054-1565599238-1000 -> DefaultScope {1B1923B5-4708-4C00-901A-E158965087A7} URL =
    SearchScopes: HKU\S-1-5-21-2051140457-2844106054-1565599238-1000 -> {1B1923B5-4708-4C00-901A-E158965087A7} URL =
    CHR HKLM-x32\...\Chrome\Extension: [lifbcibllhkdhoafpjfnlhfpfgnpldfl] - hxxps://clients2.google.com/service/update2/crx
    CHR HKLM-x32\...\Chrome\Extension: [ofoeigeaodhbjogdigckajfhjbonaofg] - hxxps://clients2.google.com/service/update2/crx
    2017-08-13 23:25 - 2017-08-13 23:27 - 000000000 ____D C:\AdwCleaner
    EmptyTemp:
    Plik zapisz pod nazwą fixlist.txt i umieść w folderze obok FRST.exe.
    Uruchom FRST i kliknij w Fix/Napraw.
  • #5 16641321
    eeeewa
    I did, the problem is gone.
    Thanks to you! :)
  • #6 16644050
    RADU23
    Help: 2428
    Rate: 1732
    Delete the C: \ FRST folder and that's it.
