Force Password Change Every 10-30 Days in Windows 10 Home without PRO Version
DjAlcon 41358 10
How can I force Windows 10 Home to make a local account change its password every 10–30 days without upgrading to Pro?
You can do this for local accounts from an elevated Command Prompt; it does not work for Microsoft accounts. Use `wmic UserAccount set PasswordExpires=True` to enable password expiration for all local accounts, or target one user with `wmic UserAccount where Name='Bob' set PasswordExpires=True` [#16399742] By default the expiry interval is 42 days, and you can change it for all users with `net accounts /maxpwage:60` or another value you want [#16399742] For a single user, the thread suggests using the `wmic UserAccount where Name='Bob' ...` form rather than `net accounts Bob /maxpwage:30` [#16401659][#16399742] `net accounts` also shows the current settings, and it can configure things like saved password count and minimum password length, but the Home version thread did not provide a way to require complex passwords via built-in tools [#16399742][#16401745]
  • #1 16399701
    DjAlcon
    Rate: 38
    I have a problem to solve:
    - I need Windows 10 Home for every 10-20-30 Days to change the login password to the system.
    Does anyone know a way to solve this without the PRO version?
    Thanks for the help in advance.
    greetings :) .
  • #2 16399742
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    Welcome. This action will of course be possible only on local accounts, not on Microsoft accounts. Works on Win 7 and Win 8, and Win 10 should also be used in Home versions.
    Run the command line as an administrator .
    Command net accounts will display the current settings.
    To force password changes on ALL local accounts: wmic UserAccount set PasswordExpires = True
    To disable forcing password changes on ALL local accounts: wmic UserAccount set PasswordExpires = False
    To force password changes on Bob user: wmic UserAccount where Name = 'Bob' set PasswordExpires = True
    To disable enforcement on this user: wmic UserAccount where Name = 'Bob' set PasswordExpires = False
    By default (which is shown in the first command), the enforcing change is set every 42 days. To change (for all users) for 60 days: net accounts / maxpwage: 60
  • #3 16399787
    DjAlcon
    Rate: 38
    And if I forgot my password is the ability to regain access to this account (Reset password)?
  • #5 16401659
    DjAlcon
    Rate: 38
    In case of forcing change of password (eg every 30 days) only for BOB user, and not for all local users will it be possible?
    net accounts Bob / maxpwage: 30
    How does it look with the command to:
    - amount of saved passwords (after expiration) to the account?
    - Minimum password length?
    - Type of characters used to create a password - Small / large letters, numbers, special characters?
    Thank you for your help.
  • #6 16401667
    dt1
    Help: 7319
    Rate: 8299
    Is there a problem for you to enter such a command and check? :)
  • #7 16401683
    DjAlcon
    Rate: 38
    You're right, I'm talking stupidly! :)
    Yet how it looks with the command to:
  • #9 16415897
    DjAlcon
    Rate: 38
    So I started fumbling in the system and I'm seeing something like this:
    link
  • #10 16416165
    dt1
    Help: 7319
    Rate: 8299
    And what is not understood in this communication?
  • #11 16416196
    DjAlcon
    Rate: 38
    Ok, I've already figured out the Home version does not have this option: lusrmgr.msc
    I solved this through CMD - creating an account and config for passwords, etc.
    Thank you.
To enforce a password change every 10-30 days in Windows 10 Home without the Pro version, users can utilize the command line interface. The commands `wmic UserAccount set PasswordExpires = True` and `net accounts /maxpwage: [number]` can be employed to set password expiration policies for local accounts. The default expiration is set to 42 days, which can be adjusted as needed. However, the Home version lacks certain features like `lusrmgr.msc` for user management. Users can also inquire about password complexity requirements, saved password limits, and minimum password lengths, but these may not be fully configurable in the Home edition.
