Windows 10 Pro Version 1703 Build 15063.447: Disable Login Password for Local Account after Update
9900 11
How can I disable the login password for a local Windows 10 account after an update removed the password-removal option?
Install Windows first with a Microsoft account, then switch the account to a local account; after that, the password can be turned off [#16580612] The thread’s solution was discovered after a clean Windows 10 install on a new SSD: installing directly with a local account made the “remove password” option disappear, but doing the Microsoft-account-to-local-account switch restored it [#16580612]
  • Local account password removal option missing after update
    #1 16557771
  • #2 16558364
  • #3 16558415
  • #4 16558446
  • #5 16558464
    Dra98
    Help: 1321
    Rate: 1076
    What does the window look like after typing netplwiz [start run or Windows + R].
  • #6 16558504
  • #7 16558536
    Dra98
    Help: 1321
    Rate: 1076
    Basically it should be unchecked -> apply, enter password and confirm. Login should work without a password.
  • #8 16558609
  • #9 16569297
  • #11 16570483
  • Install with Microsoft account before switching local
    #12 16580612
The discussion revolves around an issue with Windows 10 Pro version 1703, build 15063.447, where users are unable to disable the login password for a local account after a recent update. Initially, users had the option to remove the password but found it missing post-update. Various suggestions were made, including checking settings in "netplwiz" to uncheck the password requirement. Some users reported complications with multiple accounts and issues with Windows Defender and search functionalities. A solution was discovered where installing Windows with a Microsoft account first, then switching to a local account, allowed for the password to be disabled successfully.
