PUNTO II: Brown Liquid in Radiator After Mechanic Visit, Coolant Issues, & Radiator Replacement
11111olo 17679 18
How do I flush a car cooling system that has turned brown after a mechanic visit, and what should I refill it with?
Rinse the cooling system thoroughly, then refill it with proper coolant instead of water. The brown color is most likely from mixed cooling fluids or dirty residue, and the fix is a careful flush of the whole system [#16404753] [#16405938] If you want a deeper flush, remove the thermostat and disconnect the lower radiator hose so you can flush from the thermostat side; most deposits collect in the engine block and heater core [#16408668] After flushing, fill with the correct coolant and avoid leaving plain water in the system even temporarily [#16404753] [#16406077] If you still want peace of mind, check the coolant for oil or CO2 contamination [#16405816]
  • #1 16404719
    11111olo
    Rate: 797
    A week ago I picked up a car from a mechanic who exchanged the box and all the sealants because it was oil.
    I also found out that the blue liquid turned into a brown liquid from the cooler :(
    There was always a poured cooler fluid.
    About a year ago, the radiator was replaced with a new cooler so it was not rusted.
    I flooded him a week ago with water, I rode a little, and today I flooded again with water.
    Are there any ways to deal with it?
    piotrek22101
    Help: 695
    Rate: 1421
    Rinse the cooling system well, then pour the liquid, not water. The coolers in most cars are aluminum, they do not rust. If something rusts, it's a water pump, maybe some tubes.
  • #3 16404755
    11111olo
    Rate: 797
    I will see for a week what the color will be.
    Is it better to rinse under running water?
    piotrek22101
    Help: 695
    Rate: 1421
    There are means for cleaning cooling systems. Usually, water is enough.
  • #5 16404799
    KarizmoGSM
    Help: 95
    Rate: 292
    The color changed because it flooded, or rather, they added up and mixed up the cooling fluids, as they would fit, for example, pink and red, you will have a brown crap. Wash the fresh root and the problem of the head!
    KariMax Paweł Kalkowski
    Kronikarska 8, Łódź, 92-624 | Company Website: www.cfiat.pl
  • #6 16404807
    11111olo
    Rate: 797
    What they shed into the canister has a lot of brown deposits. Nobody added liquid to me.
    They replaced the radiator with me and flooded with coolant (blue). Nobody added anything after that.
    I do not know if I'm storming in a glass of water, but maybe if they pulled out the engine, it got something from the fuser, etc., it got stuck there, so much of that crap was there?
  • #7 16405816
    lookashECL
    Help: 8
    Rate: 60
    The brown color is rather confused colors of cooling fluids. And if you want to sleep peacefully, do it test whether there is no oil or CO2 in the liquid.
  • #8 16405871
    11111olo
    Rate: 797
    Today, I have changed water twice in the radiator and it is much better.
    This color is evidently rust.
    KarizmoGSM
    Help: 95
    Rate: 292
    This color is the effect of the mixed fluid, standard, rinse the system well and it will be ok.
    Exactly rust-colored color is done when the wrong liquid is added.
  • #10 16406077
    tzok
    Help: 3176
    Rate: 6549
    When you were doing something with the engine, you probably dropped the liquid, and then instead of replacing the whole thing, they just replenished the others they just had. Do not pour water into the cooling system, even "for a moment".
  • Repeated warm-water flushing nearly cleared the cooling system
    #11 16406991
    11111olo
    Rate: 797
    tzok wrote:
    If you were doing something to the engine, you probably dropped the liquid,
    They were pulling out the engine so they dropped it.
    tzok wrote:
    and later instead of replacing the whole thing, they just complemented it with others,
    It later dragged on for three days and flooded with water.
    today 4x I changed water (after warming up the engine). It's almost clean.
    2-3 more times and I will pour petra.
    Why? As it has already rusted, it will not change anything.
  • #12 16407196
    tzok
    Help: 3176
    Rate: 6549
    Flooding the system after running on the liquid will always end up with a brown mash in the equalizing tank ...
  • #13 16407434
    11111olo
    Rate: 797
    Do I write in Chinese? Since I have this car, no one poured water into the radiator. The mechanic showed me what he had poured from the radiator and it was a brown liquid with some sediment.
    The water is now pouring to rinse it.
    How I'm going to flood my petry.
  • #14 16408490
    tzok
    Help: 3176
    Rate: 6549
    ... and how do you know what he poured between removing the engine and draining the fluid? It's enough to pour a different liquid without first rinsing the system.
    Honestly, it's a bit like that ... ;)
  • #15 16408626
    KarizmoGSM
    Help: 95
    Rate: 292
    tzok - water probably will not give such an effect, from what I know it is only when mixing liquids such circuses are happening.
  • #16 16408668
    bodom
    Level 30  
    Help: 118
    Rate: 232
    The most deposits are in the engine block and in the heater. Remove the thermostat, disconnect the bottom hose from the radiator and pour water from the thermostat side.
  • #17 16408808
    11111olo
    Rate: 797
    Which one again? As I took out the engine, I did not see it, but when it stopped turning after inserting it, it flooded the radiator with 100% water.
    I do not know how you imagine it, but when he took out the engine, he did not put it in and he did not pull it out again.
    In one day it's possible, but why would he do it? And I sincerely doubt that the whole cooling system is so wide.
    After 6-7 water changes it is almost perfectly clean. Even 2-3 times and it will be ok.
  • #18 16409117
    tzok
    Help: 3176
    Rate: 6549
    In that case, I do not understand what was happening there, once you write that it flooded with water, then it did not flood, I do not understand it. Your statements do not contain information about the time or sequence of events you describe. The only described consequence is that you picked up the car from the mechanic and after a week you learned that the liquid was made of blue brown ...
    You gave the car to the mechanic, he had to dismantle the engine, so he drained the fluid (it was already brown then?). He took out the engine, did what he had to do and put it back. After putting in the engine, poured in liquid or water? How long has the engine become "dry"? When did you notice that the liquid (water?) Turned brown?
  • #19 16409386
    11111olo
    Rate: 797
    I've almost flushed the cooling system so I close. I do not want to argue with a moderator who is somewhere wrong. Maybe a little rest from the forum may be useful.
The discussion revolves around a user's experience with a Punto II car after a mechanic replaced the radiator and coolant. The user noticed a brown liquid in the radiator, which was initially blue, and sought advice on how to address the issue. Responses suggested that the brown color could result from mixing different coolant types or rust, and recommended thoroughly rinsing the cooling system with water and using proper coolant. Several users emphasized the importance of not mixing different coolant types and suggested that deposits might be present in the engine block or heater. The user reported improvements after multiple water changes, indicating that the system was becoming cleaner.
