Seicento 900 (2002) - Flushing Refrigeration System, Thermostat Replacement, & Maintenance Insights
8244 9
Should I flush the cooling system of a Fiat Seicento 900 before refilling it with new coolant, or is it enough to drain and refill it?
You do not need to flush the system with tap water; if there is no visible sludge in the system, it is usually enough to drain it and refill it with the proper coolant, and if you really want to rinse it, use distilled water instead [#16576808][#16576092] The brown color in the reservoir can come from old water use or from mixing different coolants, especially green and pink types, rather than from a serious internal fault [#16576343][#16576479][#16576808] Fiat is said to use Paraflu/pink coolant, so refilling with the correct coolant or concentrate is recommended [#16576517][#16576713] If you decide to flush anyway, disconnect the heater hoses and flush both directions until clean water comes out, then let everything drain before refilling [#16578149] Cleaning the expansion tank separately can also help, because the tank itself may be dirty even when the coolant is not badly contaminated [#16576517] Poor heating at low speed may still point to the pump, thermostat, or a clogged heater, but a small difference can also be normal [#16576808]
  • #1 16576014
  • #2 16576090
    kalumet
    I rinsed the system with a rinse and then with water from a hose
    And after some time the fluid in the reservoir is dirty again
    But not like before replacement
    This water exchange is a waste of time
    Stone turns into ordinary water
    Where do you have it, attach the hose and flush the system
  • #3 16576092
    moto-kord
    Help: 137
    Rate: 505
    Hello, if you want to flush the system, pour it with distilled water.
  • #4 16576343
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    This brown color of the coolant may also indicate that normal water was used instead of the coolant in previous use.
  • #5 16576398
  • #6 16576479
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    Or maybe different green and pink fluids were mixed there. Drain the liquid with new one and after trouble.
  • #7 16576517
    kalumet
    Fiat floods the system with pink liquid
    I also have green liquid
    If you have time, unscrew the tank and clean it when changing the fluid
    I cleaned it with rice
    I don't know how you are, but I got tired of getting rid of the rice from the tank
    But it gave an effect
    The tank is transparent as if he left the factory
  • #8 16576713
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    Fiat is flooded with Paraflu fluid. If you want, buy a concentrate and fill it. A 1: 1 concentrate costs around PLN 30.
  • #9 16576808
    helmud7543
    Help: 1216
    Rate: 1564
    By. me no or little sense. Flushing with tap water will introduce an additional shit, you can rinse with distilled water - only if it makes sense. I would simply mention. Perhaps the unusual color is the result of a mixture of different liquids (as classes are the same, such a mixture does not matter). If you don't see the muck in the system, I would simply exchange the fluid.
    Poor heating at low speed - pump, thermostat, clogged heater or, if the difference is small, quite normal.
  • #10 16578149
The discussion revolves around the maintenance of a 2002 Fiat Seicento 900, specifically focusing on flushing the refrigeration system and replacing the thermostat. The user notes the car's history of multiple owners and its current condition, including oil consumption and coolant clarity. Participants suggest flushing the system with distilled water to avoid contamination from tap water and recommend checking for mixed coolant types, as the brown color observed may indicate improper previous maintenance. Cleaning the coolant reservoir is also advised, with one user sharing a method using rice for effective cleaning. The importance of ensuring the correct coolant type, such as Paraflu, is emphasized, along with the need to check the water pump and thermostat for optimal heating performance.
