TCL F40b3803 TV: Sound Cuts Off After 20-30 Minutes, Updating Software Didn't Fix Issue
haker1005 8793 3
  • #1 16404838
    haker1005
    I have a TCL F40b3803 TV set. For some time the TV started to cut off the sound. More precisely, after starting everything works nicely and after about 20-30 minutes the sound breaks continuously - as if it "frames" the sound, you hear jerks, sometimes it completely mutes for about 1-2 seconds.
    I tried HDMI connections, "Euro connector" and still the same.
    I bought a used TV set, so it has no warranty. I've been using it for about 3 months - the problem has been around for 2-3 weeks.
    I updated the software from the manufacturer's website, but that did not solve the problem.
    Have any of you experienced a similar condition? Can anyone determine what the problem may be?
    Thank you in advance for your help ;)
  • #2 16825316
    Golkowis
    Help: 18
    Rate: 66
    I have the same problem whether you coped.
    Peter
    Added after 34 [minutes]:
    TPA3110D2 power amplifier to be replaced
  • #3 16825393
    haker1005
    I gave the TV to a friend who had much more knowledge than me. From what he gave me, he replaced all the capacitors on the power supply (total cost about PLN 50 - from what I remember). Currently, the TV is working properly - so rather an accurately diagnosed cause.
    I hope it can be fixed as well ;)
  • #4 16825404
    Golkowis
    Help: 18
    Rate: 66
    And yet a mistake - replacing the C138 did the trick
    Power system ???? monolith capacitor for surface printing, that is, the cause of sound breaking, etc. ailments.
    There is a / capacitor / near the power amplifier and heating with a hot air fooled me a bit.
    It can be removed and nothing is mounted
    But it's already OK
