[Solved] THOMSON 32HA3103: Voice Fades After 15-20 Mins, Sound Issues & No Remote Control - Solutions?
11111olo 11325 11
Why does the TV sound stop after 15–20 minutes and briefly return after a power reset, and what should I check or replace?
Check the audio amplifier section around the TPA3110 and its nearby SMD parts; the intermittent mute is most likely caused by a fault there rather than firmware or the missing remote. A suggested repair is to replace the TPA3110 itself, but several replies point to the nearby 1 µF SMD capacitor(s), including C138 and the capacitor on pins 4 and 11 of the TPA3110 [#17141222] [#17145970] [#17146579] Another useful check is Q101, Q102 and D101 and their surroundings, because touching them with a meter can temporarily bring the sound back even though the parts may test normal [#17145356] One user also reported success by shorting one leg of the transistor near the TPA to ground [#17146756] Heating the amplifier section was suggested as a way to reproduce the fault quickly for diagnosis [#17141222]
  • #1 17141148
    11111olo
    Rate: 797
    Patient as in the subject. Turns on normally and displays image properly. After about 15-20 minutes, the sound stops playing - there is complete silence. Turning up the volume changes nothing. A momentary shutdown restores the sound for a minute or two.
    I don't have a remote control and I can't upload the latest firmware.
    Do you have any suggestions apart from a possible CD replacement?
    Plate markings: 40-mt31epa-mab2hg
  • #2 17141222
    Adewag
    Help: 36
    Rate: 251
    TPA3110 for replacement. For checking, heat up with a hotem, the fault will be right away.
  • #3 17142028
    11111olo
    Rate: 797
    If this power amplifier heats up so much, maybe it would help to stick the heat sink?
    Adewag
    Help: 36
    Rate: 251
    The pad should be soldered with the entire surface. The heat sink probably won't hurt.
  • #5 17142184
    11111olo
    Rate: 797
    It's probably soldered - that's how it came out of the factory.
  • #6 17142279
    Adewag
    Help: 36
    Rate: 251
    You solder the pad wrong, and the heat sink may not help. I have had several such cases. Someone replaced the amplifier and soon the fault returned. Especially when, for example, the volume of the TV volume is at maximum, and the decoder is at least. It does not matter what the volume level satisfies the user.
    The so-called stereo audio power amplifier module power amplifier working in digital class D. Amplifier circuit based on the TPA3110 integrated circuit. The maximum output power is 15W for each left and right channel. The supply voltage to the system with a voltage ranging from 8V to 26Vdc.
  • #7 17142290
    11111olo
    Rate: 797
    I understand it all.
    It is rather unlikely that the power amplifier will bend badly on the conveyor belt as it passes through the furnace.
    I'll take care of it after Christmas and let you know the result.
    Adewag
    Help: 36
    Rate: 251
    You misunderstood me. I am not suggesting that the factory soldered badly. :wink: The rest in # 6
    happy :D
    Józef Kłeczek
    Please carefully check Q101, Q102 and D101 and their surroundings. Most often, touching the tip of the meter to any of these elements restores the voice for a moment. The measurement with the meter does not show any damage to the element, while the replacement restores the voice permanently. Heating the audio amplifier circuit actually accelerates its decay, but the elements Q102 Q102 and D101 are so close that it increases their temperature causes the sound to drop out.
    best regards
  • #10 17145970
    badael
    Help: 137
    Rate: 215
    Replace SMD cond. with 4 and 11 pin TPA3110 (1uF 16V).
  • #11 17146579
    karelkarel
    Rate: 66
    I have this tv model in the workshop. In my case, the SMD C138 (1uF) capacitor was faulty.
  • #12 17146756
    11111olo
    Rate: 797
    I shorted one leg of the transistor to ground near the TPA and that resolved the matter.
The THOMSON 32HA3103 television experiences sound issues where audio fades after 15-20 minutes of operation, with volume adjustments having no effect. A temporary fix is achieved by momentarily shutting down the device. Suggestions for resolution include checking and potentially replacing the TPA3110 power amplifier, inspecting components Q101, Q102, and D101, and replacing SMD capacitors associated with the amplifier. Users recommend soldering techniques and heat management to address the problem, with some reporting success by shorting a transistor leg near the TPA. The discussion emphasizes the importance of proper soldering and component integrity in resolving audio issues.
TL;DR: 15W-per-channel TPA3110 class‑D amp is central here; "Amplifier circuit based on the TPA3110." If your THOMSON 32HA3103 loses sound after warm‑up, rework or replace the TPA3110 and inspect its 1 µF support caps and soldering. [Elektroda, Adewag, post #17142279]
Why it matters: This helps 32HA3103 owners and bench techs fix recurring audio dropouts without needless board swaps or firmware hunts.
What causes the THOMSON 32HA3103 sound to vanish after 15–20 minutes?
Thermal issues around the audio amp path trigger muting or loss. Check Q101, Q102, and D101 near the TPA3110. Touching them with a meter tip often briefly restores audio, indicating sensitivity. Measurements can look normal, yet replacing those parts restores sound permanently. Heating the amplifier area accelerates the dropout, which implicates nearby components thermally. Focus inspection and rework on that cluster before replacing the main IC. This targets the most heat‑affected nodes first. [Elektroda, Józef Kłeczek, post #17145356]
How do I quickly confirm the TPA3110 is the culprit?
Use heat to provoke the failure. 1) Warm the TV until audio is stable. 2) Gently heat the TPA3110 with hot air while monitoring sound. 3) If audio cuts immediately, the amp path is implicated. As one expert put it, "TPA3110 for replacement." This test isolates the thermal sensitivity and avoids lengthy guesswork. Keep airflow moderate to avoid collateral damage. If the fault appears instantly, proceed to rework or replace and verify support parts. [Elektroda, Adewag, post #17141222]
Should I add a heatsink, or resolder the TPA3110’s thermal pad?
Prioritize resoldering the thermal pad across its entire surface. A heatsink won’t help if the pad isn’t properly bonded to the PCB. One expert advises, "The pad should be soldered with the entire surface." Good pad contact improves heat spread and long‑term stability. Reflow with adequate flux and pressure, then retest. Add a small heatsink only after ensuring correct pad soldering. This sequence prevents repeat failures. [Elektroda, Adewag, post #17142172]
Which small capacitors commonly fail and mute the audio?
Replace the SMD capacitors tied to TPA3110 pins 4 and 11. Use 1 µF, 16 V parts. These caps are part of the amp’s control or input filtering and can drift with heat. Failures here manifest as intermittent or timed audio dropout. Swapping them is low cost and fast, making it a strong first step. Recheck sound stability after replacement under warm conditions. [Elektroda, badael, post #17145970]
Is capacitor C138 involved in this model’s sound failure?
Yes, in at least one workshop case, SMD C138 (1 µF) was bad. Replacing C138 restored stable audio. If pins 4 and 11 caps don’t solve it, check C138 next. Heat and age can push these tiny capacitors out of spec. Mark orientation and value, then replace and retest after warm‑up. [Elektroda, karelkarel, post #17146579]
Will replacing only the TPA3110 always fix the issue?
Not always. If the thermal pad is poorly soldered, the failure can return even after IC replacement. An expert noted cases where the amp was replaced and the fault soon recurred. Also avoid stressing the amp with extreme volume mismatches. Verify pad reflow quality and surrounding passives before calling it done. This prevents costly repeat repairs. [Elektroda, Adewag, post #17142279]
Do I need a remote or firmware update to restore sound?
No. The fixes documented here are hardware‑level. Users restored audio by replacing small SMD capacitors connected to the TPA3110. No firmware update or remote control interaction was required to resolve the dropout. Focus on component replacement and solder rework. Software actions did not feature in the successful repairs reported. [Elektroda, badael, post #17145970]
What are Q101, Q102, and D101, and should I replace them?
They are small transistors and a diode near the audio path. Probing with a meter tip often restores audio briefly, signaling marginal behavior. Measurements may show no obvious fault, yet replacing them can permanently fix sound. Check their solder joints and surrounding traces for heat stress. If intermittent, replace all three together for reliability. [Elektroda, Józef Kłeczek, post #17145356]
What power specs should I verify on the TPA3110?
Confirm the amplifier’s supply is within the typical 8–26 V DC range. The TPA3110 is a class‑D device rated around 15 W per channel. If the supply sags or runs hot, audio instability can worsen. Verify ground integrity and decoupling near the IC. Stable supply rails reduce thermal excursions and dropouts. [Elektroda, Adewag, post #17142279]
What tools are best for diagnosing this at home?
Use a heat source, such as a hot‑air gun, to provoke the dropout. Applying heat near the audio amplifier speeds up the failure, confirming a thermal fault. Control airflow and temperature to avoid PCB damage. After confirming, plan rework or replacement. This approach minimizes guesswork and speeds repair. [Elektroda, Józef Kłeczek, post #17145356]
Can shorting a nearby transistor leg to ground restore audio?
Yes. One user resolved the dropout by shorting one leg of a transistor near the TPA3110 to ground. This suggests a control or mute node issue in that area. Use this only as a diagnostic clue, then repair the root cause. Trace that transistor’s function and replace affected parts. [Elektroda, 11111olo, post #17146756]
Which mainboard does the THOMSON 32HA3103 use?
Reported board marking for this set is 40-MT31EPA-MAB2HG. Use this ID to locate board diagrams or parts. It helps when ordering a replacement TPA3110 or associated SMD capacitors. Document the board code before starting the repair for reference. [Elektroda, 11111olo, post #17141148]
