Comparing Tagred 50L 2T Compressor and Bass 50L 8bar Compressor for Home Workshop
Perła1985 22023 9
Which compressor should I choose for a home workshop: the Tagred 50L 2-cylinder model or the Bass 50L 8 bar oil-free model, if I’ll mainly use it for inflating/purging now and small painting jobs later?
Choose the oil-lubricated two-piston compressor rather than the oil-free Bass, but the thread’s main advice is that both of these cheap units are poor value and their advertised power/performance is exaggerated. One reply says the real performance is only about one third of the claimed figures and that either model is basically suitable only for inflating tires occasionally [#16413761] Another recommends avoiding oil-free designs that use "oring" instead of proper rings, and instead looking for an oil compressor with a viewing window and oil gauge [#16413814] A better direction suggested in the thread is a used Polmo/HS14-type compressor or another unit with a crankshaft running no faster than 1440 rpm, supported on both sides and lubricated with normal oil, ideally with a separate motor [#16413814][#16413928]
  • #1 16412343
    Perła1985
    Rate: 36
    I am looking for a compressor of up to PLN 1000 for a home workshop.
    For now, the equipment will be used for pumping and purging, but in the future I will definitely want to use it to paint some small elements.
    I was already determined for this compressor
    http://allegro.pl/kompresor-sprezarka-tagred-50l-2t-separator-24-gw-i6023498380.html
    but I came across one
    http://allegro.pl/bass-cichy-kompresor-bezolejowy-sprezarka-50l-8bar-i6702905912.html
    Please help in choosing.
  • #2 16413296
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    However, I would choose the one with two pistons
    Lower price but better performance
    Added after 45 [seconds]:
  • #3 16413385
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1132
    Two pistons have both, but if they write the truth is the one that you also indicated to me better fit because the description shows that the engine stronger - Engine power: 3,0 KW / 4,1HP, and the other - Engine power: 1,25 KW, then however, there is a difference (of course if it is true).
  • #5 16413761
    bearq
    Help: 414
    Rate: 1612
    - strong 3kW at 1f and in addition with engine size 0.5 kW
    - efficiency of 23m3 / h, you can easily take real performance at the level of 1/3 of this
    - there is probably about 3k of turnover ...
    No matter which one you choose, it is still one garbage suitable only for inflating the wheel twice a year. The compressors themselves are no different except for stickers, and the seller's imagination has the biggest display here.
  • #6 16413781
    Perła1985
    Rate: 36
    So I take the cheapest and it will be used once in a while.
  • #7 16413814
    bearq
    Help: 414
    Rate: 1612
    Exactly, just take the "oil" with the window and the oil gauge. The oil-free ones that instead of rings have "oring" avoid like fire.
    Unless you look for the used "Polmo" on an HS14 compressor, I think. You can buy one for 500 PLN, compressor parts to choose from for color and for funny money. Vitality several times higher than a quinole.
  • #9 16413928
  • #10 16414193
    Perła1985
    Rate: 36
    I bought this Tagred. If it's one Chinese then it makes no sense to spend more money. Thanks for the help.
✨ The discussion revolves around selecting a compressor for home workshop use, specifically comparing the Tagred 50L 2T and Bass 50L 8bar models. Users highlight the Tagred's dual piston design and stronger engine power (3.0 kW) as advantages over the Bass model (1.25 kW). Some participants express skepticism about the overall quality of both compressors, suggesting they may be suitable only for infrequent use, such as inflating tires. Recommendations include opting for oil-lubricated models over oil-free ones, with a preference for compressors with lower RPMs for durability. Ultimately, the original poster decided to purchase the Tagred model, citing cost-effectiveness given the similar quality of both options.
