Identifying and Purchasing a Flat Key for Cable Connector Enclosure Door
bartsed 7146 12
What is the professional name of the flat key for opening this cable connector enclosure, and where can I buy one?
It is most likely a 9081 or 9082 type key, a common flat key used for electrical boxes, and you can buy it at an electrical wholesaler for about PLN 5 [#16424498][#16424691] It does not look like a special patent insert, but rather a typical key for this kind of enclosure [#16424498][#16424429] Even so, only the owner or an authorized technician should open the connector or switchboard [#16424390][#16424429]
  • #1 16424274
    bartsed
    I am looking for a technical key that I can use to open the enclosure door from the cable connector and administrative board from the photo below. This is not a typical key that usually occurs with cable connectors, because it is a flat key and I do not know what it is called professionally.
    It will open the lock from the photo below. Someone associates something like such a key is professionally called and where such a key can be bought?
    Identifying and Purchasing a Flat Key for Cable Connector Enclosure Door Identifying and Purchasing a Flat Key for Cable Connector Enclosure Door
  • #2 16424290
    opornik7
    Electrician specialist
    Help: 316
    Rate: 1569
    To open a cable or TA connector, you must have the right to do so. Then you must have a qualification certificate.
    For a bystander - down with your paws ;) or read the label on the connector.
  • #3 16424297
    zbich70
    Help: 1171
    Rate: 6668
    Why do you want to look there?
    Are you entitled to this?
  • #4 16424365
    radex324
    Help: 50
    Rate: 206
    Maybe the security has worked and he is looking for help, in the blocks they even want PLN 20 for silly turning on esa. (Although we are waiting for the author's reply)
  • #5 16424370
    bartsed
    He works with a colleague entitled designer, a colleague born in 1939 does not use a computer. He designs on paper and I transfer it to a computer.
    From the board from the photo, a colleague wants to power the designed lighting, but there is no key to open it and inventory. A cable line reconstruction project will also be made, hence the need to look into the connector.
    Can anyone say something about the key now?
  • #6 16424381
    radex324
    Help: 50
    Rate: 206
    A colleague calls the technical department of the administration and they will arrive by *.
  • #7 16424390
    opornik7
    Help: 316
    Rate: 1569
    The connector can be opened by its owner, i.e. probably the power industry. TA can be opened by an electrician (since TA, I guess it could be some block or other object). Two telephones and it's over.
    You better not move it. I know what I write because I once saw the effect of opening the connector by the designer. Unfortunately, one hinge was rotten and the door fell on the rails. Heap of fire, ZK interior for exchange. Burn designer.
  • #8 16424417
    Turysta_
    Help: 7
    Rate: 19
    A strange topic. It's like approaching a neighbor's door and asking in the forum what key to open :D
    Certainly, the keys of the estate are technicians of the estate administration, if it is the estate. It happens that the keys of the cage also have such keys.
  • #9 16424429
    zbich70
    Help: 1171
    Rate: 6668
    Someone commissions these projects to your colleague.
    So let the contractor provide access to the connector and switchboards.
    By the way - there are patent inserts instead of the usual pads for "squares" or "triangles".
    mawerix123
    Help: 482
    Rate: 951
    The insert looks like a key 9081, 9082 or this type so no patent or rather typical. Which does not mean that everyone can look there.
  • Wait for technical staff instead of buying an unknown key
    #11 16424675
    bartsed
    Theoretically, it should be like this, but here it is a little different and I do not want to explain what and how. In short, the contact person from the Investor's side is temporarily unavailable and that's why I thought there might be some public key that you can buy.
    I didn't think there could be so many types of keys. In that case, I will not take anything blindly and we will wait for a technical person.
    Thanks to everyone for the comments and observations, although I think some were unnecessary ;)
    mawerix123
    Help: 482
    Rate: 951
    The 9081 key most commonly used for electrical boxes can be obtained at any electrical wholesaler for around PLN 5.
  • #13 16424719
    bartsed
    Thanks for the specific answer. I will buy and maybe it just fits.
The discussion revolves around the identification and procurement of a flat key required to open a cable connector enclosure door. The original poster seeks assistance in finding the correct key, which is not a standard type. Responses highlight the importance of having the right qualifications to access such enclosures, with suggestions to contact the technical department for assistance. A specific key model, the 9081, is mentioned as commonly used for electrical boxes, available at electrical wholesalers for a low cost. The poster decides to wait for a technical person before proceeding with any purchases, acknowledging the variety of key types available.
