Looking for a male and female PCB receptacles to mate with female and male plugs
387 7
  • Use keyed 2-pin PCB headers with latch
    #1 21681772
    Mike Soultanian
  • Molex connectors suggested for board and inline use
    #2 21681773
    David Ashton
  • Panel mount connectors with short pigtails recommended
    #3 21681774
    Elizabeth Simon
  • TE Mate-N-Lok connectors suggested for board and cable use
    #4 21681775
    David Ashton
  • Using a keyed 4-pin connector with jumper plug
    #5 21681776
    Mike Soultanian
    #6 21681777
    Mike Soultanian
  • Forum tip on editing or deleting duplicate posts
    #7 21681778
    David Ashton
  • #8 21681779
    Mike Soultanian
The discussion addresses the need for male and female PCB-mounted receptacles that mate with corresponding female and male crimped plugs on power cables, enabling the cable to be cut and reconnected without using gender-changer adapters. Molex connectors were suggested as a potential solution, with a wide variety available for both inline and board-mounted applications. An alternative approach involves using panel mount connectors wired to the PCB via short leads for improved mechanical stability. TE Connectivity's Mate-n-Lock series was also recommended for keyed, locking rectangular power connectors suitable for this purpose. A key insight was to use a single 4-pin keyed connector (such as Molex Mini-Fit Jr) instead of two separate 2-pin connectors, simplifying the design and preventing incorrect mating. This approach allows creating a jumper plug to complete the circuit when the cable is used standalone, enhancing usability and board layout. The discussion also noted the absence of retaining clips on some PCB-mounted connectors and the importance of specifying current rating, number of ways, and locking features when consulting manufacturers.
