Mini Coolant Running Low Repeatedly - Possible Causes & Solutions (Loss, Leakage, Overheating)
Piekarz09 8886 4
  • #1 16424973
    Piekarz09
    2 months ago, while driving, I had full heating, I immediately checked that I was missing a liter of coolant, I was driving for 2 months, but today the same problem again.
    What could be the cause?
  • #2 16425017
    decybel91
    Help: 1024
    Rate: 4231
    Either it leaks or the engine eats up the fluid (head gasket).
    Put the cardboard under the car overnight. If there is a leak, you have a cause.
  • #3 16425026
    rafik$
    Help: 13
    Rate: 52
    If the cardboard is dry, for confirmation, go to a mechanic who has a co2 tester and you will know everything, best regards
  • #4 16425088
    Piekarz09
    I will do as you say, the car has never smoked, does not take a gram of oil, and the gasket is probably a more serious thing?
    If a liter goes down for 2 months, you probably won't even notice anything on that carton :D
  • #5 16440170
    rafik$
    Help: 13
    Rate: 52
    The oil does not have to take, and with such a leak you should be able to see, especially when cooling, if there is a leak of course. And with the head gasket, it will be a bit of work and costs too. greetings
