[Solved] Renault Master 07R 2.5DCI 100 - disappearing fluid from the cooling system ..
danyxm 27987 18
How do I diagnose coolant loss with no visible external leak on a Renault Master 2.5 dCi, and what was the real cause in the end?
The thread points to an internal leak rather than the radiator, so the recommended checks were to bypass the EGR cooler, test the coolant for CO2 to rule out a head gasket or head crack, and inspect the cabin heater area; a removed radiator is hard to prove on the bench, though you can blow through it under water [#16590111][#16590121] One reply also said the water pump in this engine cannot send coolant into the oil pan; if it fails, the fluid should escape through a drain channel [#16630609] In the end, the owner reported that the car had increased oil level, found sludge in the oil cooler, and the repair that solved the problem was replacing a worn water pump and an oil cooler [#17573211] The mechanics did not see any clear signs of a head-gasket failure [#17573211]
  • #1 16587159
    danyxm
    Rate: 21
    Welcome!
    Day already matches with the fault in the master. Before I decide to spend more I decided to seek your advice.
    Namely: for several weeks the fluid from the reservoir has disappeared. About a liter for 700-1000km. The engine has been viewed many times - no leaks. The mechanic washed the engine and zorbil 4 thousand km and we were looking for a leak - nothing.
    At some point we found butter mayonnaise in a turbo radiator pipe.
    In the net I found that it could be the exhaust gas cooler of the EGR valve.
    The new cooler for this model is PLN 2,100, we also came up with a mechanic to buy a utility and mount the utility.
    We did so too. Unfortunately, the fluid is still decreasing, especially when driving around the city - as if less on the route (and this master makes routes after 1-2 thousand km at a time).
    Engine: zero problems He works as he worked, does not smoke, everything is as it was, low combustion - normal. In the morning it fires without smoke. The car is from 2007 and has traveled almost 600 thousand km, of which it has been making routes for 1-2 thousand km on highways for 4 years. The engine was only replaced candle, turbo (checked now - it is dry and good), and air flow.
    and now a series of questions for you:
    1. How to diagnose a damaged radiator? I have a radiator removed from my car, I wonder how to determine this leak?
    2. how to clean the inside radiator?
    3. are there any services regenerating exhaust gas coolers?
    4. Can it be the head gasket? How to diagnose it correctly? because again I will go to the mechanic and it will break with 2 thousand and if the radiator is damaged then the problem will remain
    I offer good Scotch whiskey for helping me diagnose correctly :D
    Best regards!
  • #2 16589270
    rafcio_21
    Help: 137
    Rate: 299
    The liquid disappears and what comes with oil, you checked the oil level
  • #3 16590060
    danyxm
    Rate: 21
    From what I checked - no. But I will look more closely. The coolant is not dirty or stinks either.
  • #4 16590111
  • #5 16590121
    WędkarzStoLica
    Help: 146
    Rate: 300
    Close one hole and blow into the other - of course under water, just like you are looking for a hole in an inner tube.
  • Oil level drop and gray sludge in turbo hose
    #6 16593442
    danyxm
    Rate: 21
    Thanks gentlemen!
    I looked a little bit, I answered - answering your questions:
    1. I don't see any liquid in oil, rather oil has been lost rather than arrived, although I do not know exactly. I changed oil about 7,000 km ago, it is usually 3/4 on the indicator, today I said it is 1/3 on the dipstick. That is normal.
    2. is the gray butter in the pipe going (I think) to the turbo radiator
    3. exhaust pipe - black and dry, soot only
    4th buddy was there and he went to the pneumothorax - there was some butter there too - so much that the car has been charged 600,000 km and nothing was ever done there
    5. I have removed the cooler, soaked the solvent in a solvent, tomorrow maybe I can somehow test or liquid.
    I bought 3 coolers from the momentum, I also want to test the one I took from my car and some other.
    It's all about diagnosing - leaking or not leaking.
    I would prefer it to be liquid:]
  • #7 16593501
  • #8 16596293
    danyxm
    Rate: 21
    The oil filler cap has no tarnish or sludge. Fluid loss is greater in the city than on the route.
    I checked the refrigerator - the test consisting of blowing in it and checking for leaks was successful - because I have no idea how to check its tightness otherwise.
    A friend told me to pour some liquid to repair the gaskets and thus check if it will be a gasket or not - a good idea? Flood and if you stop taking the liquid just go to replace the seals?
    I can do the exchange only in the middle of August - it would be good if the car could reach this exchange ..
    The engine does not smoke, it evenly runs, nothing happens ...
  • #9 16596835
  • #10 16597544
    danyxm
    Rate: 21
    Thanks. I ordered a liquid to "repair" the gasket and I will start looking for a mechanic on the spot, or maybe I would risk and go to my own in Poland.
    If I knew any home method to check this cooler it would be after the problem ...
    Best regards!
  • #11 16600334
    danyxm
    Rate: 21
    Gentlemen - and the water pump?
    will not give similar symptoms?
  • #12 16630476
    danyxm
    Rate: 21
    I drove I drove and fluid started to deplete more.
    At the moment, it is clearly seen that the amount of oil in the drier has increased - this can be seen on the dipstick, and butter appeared under the oil filler cap.
    Earlier the cork was very dry.
    In the meantime, I found a place of fluid loss - the vent on the coolant tube, but apparently this was not the only place of loss.
    Gentlemen - I repeat the questions - can the water pump in these engines, its damage, affect the water supply to the oil pan?
    Is this a head gasket?
    From one engineer I heard that it was rather a water pump, from the other - from such a possibility would not be possible through the water pump, the water from the cooling system got into the oil.
    The pump in my engine is driven by the sprocket teeth and lubricated with oil - that's what I read on the net.
    I would be very grateful for the info, because I do not know which of the mechanics to listen to.
  • #13 16630609
    pp_pablo
    Help: 93
    Rate: 405
    Can't If the pump squats, the fluid is drained out through a small channel. I'll just add that you can disassemble the pump without disassembling the timing, but when removing some fluid will pour into the bowl, so it's better to drain the oil.
  • Questioning engine rebuild versus replacement at 700,000 km
    #14 16683569
    danyxm
    Rate: 21
    Thanks gentlemen!
    The car is standing and waiting for repair - I changed the oil and filters, the fluid consumes a lot and the amount of oil increases. That is a gasket.
    Another question - maybe the last one?
    Buying a new engine - using and inserting, or renovating this "mine"?
    The utility is a lottery, it is hard to hit generally, for refurbishment, one thing is a well-kept car and at least you know what's in it. I don't know if it makes sense to resuscitate this engine at around 700,000 mileage.
    If renovation is where?
    And so I will - if already - for repair engine sent on a pallet to Poland.
    Thanks for the hints :)
  • #15 17412406
    danyxm
    Rate: 21
    The car year was waiting for me to go to it ... and today I removed the cooling system - and found sludge in the oil cooler - the one in which the oil filter is screwed.
    Could this be the reason for the loss of fluid and oil?
  • #16 17432209
    dominic16
    Hello, the oil cooler is probably broken and oil fluid gets into it.
  • #17 17432555
    danyxm
    Rate: 21
    Off-site, where is it possible to buy a set of gaskets connecting the filter body with the heat exchanger?
    The service wants to sell me a lot ...
  • #18 17573207
    danyxm
    Rate: 21
    after a year of fun and exploration - finally a happy final.
    Used oil pump was responsible for oil leakage.
    Perhaps there is also an oil cooler in which the oil filter is screwed in - but here there are no clear indications. The pump was broken, let loose bearing.
    So it's worth replacing from time to time.
    In fact, access after removing the wheel is cool, you can quickly make a diagnosis.
    The mechanics were saddened that there was no visible head gasket. :)
  • Worn water pump and oil cooler replaced
    #19 17573211
    danyxm
    Rate: 21
    I replaced a water pump that was worn out and an oil cooler that could also leak - problem solved :)
The discussion revolves around a Renault Master 07R 2.5DCI 100 experiencing coolant loss, approximately one liter per 700-1000 km, without visible leaks. The engine has been inspected multiple times, and while no leaks were found, mayonnaise-like sludge was discovered in the turbo radiator pipe, suggesting potential issues with the EGR cooler. Various diagnostic suggestions were made, including checking for leaks in the cooling system, using a CO2 tester for head gasket failure, and examining the oil for coolant contamination. The user reported increased oil levels and sludge under the oil filler cap, indicating possible coolant mixing with oil. Ultimately, it was determined that a faulty oil pump and potentially an oil cooler were responsible for the fluid loss. The user replaced the worn oil pump and oil cooler, resolving the issue.
