[Solved] Volvo XC90 - replacement of the factory radio with another one
Andrzej Ł 21477 13
Can I remove the Volvo XC90 factory display and audio components if I bridge the CAN wires, and what should I do with the fiber-optic loop and antenna tuner?
Yes — the panel/display can be removed if you preserve CAN continuity by shorting green to green and white to white in the green/white twisted pair, after which the panel cube can be unplugged [#16888787][#17049669] The fiber optics run only within the audio components, so they can be left as-is or removed; no special fiber-optic bridge is needed once the display/audio stack is gone [#16888787] For the retrofit, make ISO power and speaker plugs, take ignition and backlight from the panel connector, and extend the speaker wires under the seat to the amplifier connector [#16888787] The original antenna tuner can be removed too; the antenna lead was routed through a homemade crossover that summed the VHF and AM circuits, then into a universal car antenna amplifier [#16888787][#16979091]
  • #1 16426350
    Andrzej Ł
    Help: 27
    Rate: 106
    I remove the factory audio system from the above 2004 cars.
    The client got a set of fiber optic connectors, a console frame and an antenna amplifier. On English-language videos with YT, they leave everything plugged in, the display is hidden in the console. The received set can allegedly disconnect all components connected by fiber optics, i.e. the radio panel, cd drive, amplifier, tuner with antenna in the roof.
    I discovered from the display it is impossible to unplug because it is some kind of CAN node (green and white cables) - after unplugging CZ does not work, cabin lighting and the pillow error pops up.
    The cables are on the go in display 1 to 1. Now questions to experts on the subject:
    1. If I ensure continuity of this CAN line, can I eliminate the display?
    2. Does the fiber optic circuit only close on these audio components (if I eliminate the display, you can skip fiber bridging)?
    3.If the display has to stay, and I conclude that it is a master, it is not enough just to make a fiber optic loop from its output (short loop).
    I removed the antenna tuner and after analyzing the antenna inputs I made a grommet with an adder / crossover that I connect to a universal antenna amplifier, with the antenna and from there I put the coaxial cable to the radio.
    I think that it will be a smarter and more professional solution instead of gluing the antenna to the glass like in YT videos.
    I am asking for help from subject experts
  • #2 16886664
    lukaszsbv
    Rate: 18
    Hello, I see that nobody helped ... You got the answer to one of your questions, if so please help because I have the same task.
  • #3 16887484
    Andrzej Ł
    Help: 27
    Rate: 106
    Yes, I solved everything myself. Info on priva.
  • #4 16888369
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    According to our regulations, a solution should be given on the forum, not on PW.
    3.2. The author of the topic, after receiving the answer that is the solution to the problem, is obliged to provide a summary with an indication of the solution and lock the thread by clicking the resolved button.
  • #5 16888787
    Andrzej Ł
    Help: 27
    Rate: 106
    OK for everyone:
    The panel can be removed, it is necessary to ensure continuity of the CAN line, for this purpose you need to short the green veins and the white veins in the green / white twisted pair, after which you can remove the cube from the panel. You can then get rid of the panel and the rest. Optical fibers run only within the audio components , you can also leave it or separate it and throw it away.
    we make ISO current and speaker cubes, we take ignition and backlight from the panel cubes, we extend the speaker cables under the seat and connect to the amplifier cube.
    I dragged the antenna + control cable to the antenna, removed the entire tuner module, I made the crossover sum of the antenna circuits myself, because there are two for VHF and one for AM, the signal from the crossover I immediately let into the universal car antenna amplifier (in the form of a tube like VAG separators) ). Through this procedure, the antenna behaves like other typical roof active antennas, the reception is excellent, it catches all AM and FM stations, even in the garage.
  • #6 16947036
    lokac
    Hello. Could I ask for details of such a procedure, i.e. exactly with the drawing. I would gladly exchange the radio in my xc90 2003 for new non-factory ones.
  • #7 16951336
    Andrzej Ł
    Help: 27
    Rate: 106
    I do not know what to draw, everything was written, determine the appropriate cables is no problem, for someone who has an idea about auto electrics / car audio. For the rest there are radio assembly service outlets.
  • #8 16951543
    lokac
    Thanks for the answer. I think that after careful analysis I will manage. greetings
  • #9 16956389
    lokac
    Welcome back. I am only at the stage of buying 2DIN radio. When I get to the car mounting, and I suppose it will be in the spring, if I have problems, could I count on help, tips?
  • #10 16963808
    lokac
    Hello. How to make a crossover summing up the antenna / FM and AM circuits?
  • #11 16979091
    Andrzej Ł
    Help: 27
    Rate: 106
    Diagram of my crossover. Disconnect the antenna foil cable from the tuner and connect it with the goldpin connector to the crossover board. I made it universal in 5 minutes.
    Diagram of the connector and the crossover.
    • Volvo XC90 - replacement of the factory radio with another one Volvo XC90 zwrotnica antenowa.png (9.5 KB) You must be logged in to download this attachment.
  • #12 17025431
    lokac
    Hello. "close green veins and white veins in green / white strands" green with green and white with white or alternating green with white? :)
  • #13 17049669
    Andrzej Ł
    Help: 27
    Rate: 106
    green to green white to white
  • #14 17049840
    lokac
    Thanks a lot. greetings
The discussion revolves around replacing the factory audio system in a 2004 Volvo XC90. The user faces challenges with the fiber optic connections and the CAN bus system linked to the display. Key solutions include ensuring continuity of the CAN line by shorting the green and white wires, allowing for the removal of the audio panel and associated components. The fiber optic circuit is confirmed to only connect audio components, enabling their removal. Users also discuss creating a crossover for the antenna circuits and the importance of proper wiring for the new audio system. Additional inquiries about the procedure and diagrams are made, with responses emphasizing the need for knowledge in auto electrics.
